Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Is it safe to keep data cable connected without power cable
I have a spare 80GB IDE Barracude drive connected to my computer as a slave. I only use it for keeping backups. Since keeping it connected at all times uses power as well is becoming prone to virus attacks, I was wondering if it is safe to unplug the power cable while still keeping the data cable connected. I don't really want to unplug the data cable everytime, its easier to just pull the power cable out.
I just want to know whether its safe (for the hard disk) to keep the system running with its data cable connected and the power cable unplugged.
Thank you for any help.
  • 5 more comments
  • amit_celebt Sep 26, 2008
    Thank you Palmbeach. That was fast and precise. Exactly what I was looking for. I will remember your advise about shutting down before plugging or unplugging the power cable.
    Thanks again, I really appreciate your help.
    with regards,
  • tech1 Aug 18, 2012
    better, answer, im A+ tech, retired. never hot sway IDE pata drives, never run 2 drives of any kind with one unpowered as that overloads the data buss and cause corruption on the good drive, (see it run slow? sure,) The I/O chips connected must have power.
  • tech1 Apr 25, 2013
    this rule depends on the type I/O port, there are many, SSCI/PATA/ESATA, or avanced Esata , but if using PATA and using the same cable for both drives, pulling power to one will cause data corruption, read the manual of you HDD (or cd/dvd rom) to learn why. The I/o chips of many load the buss. with no power, i can prove this with data sheets, of same.
    hot switching power on devices will blow the chips fast. the exceptions are, SCSI and Esata. hot switch a DC buss is bad practice unless the device was designed for such actions.
    the sata is native hotswap, (may not the controller when the surge hits it, huh)
    the chips on most PATA when one hot connects the Molex, cause the chips to avelance and the blow up. I worked in test engineering for 15 years and know this well. on the hot swap drives snubbers are used to stop this instantainous rise times hot swapped.
    i have esata on my servers, that can be left connected and powered down, (backup) in the old days (pata)we had a special tray and power regultor, that tri-stated the i/o buss and used softpower up and down power drivers, protecting the sensative PATA chips. these are no longer sold. so if using PATA, power down and pull the data cable. if green ?, pull both and power back up.
    An expert who has answered 20 or more questions within one hour.
  • 53 Answers
Bad advice, !! he has PATA drive.!
only the Esata external is hot swappable. as is the old SCSI HDD.
if it has a molex connector , HDD, power, do not hot swap this connector, as you damage the logic, the logic does not allow instant power ups, (hot wiring) it does not.
when you do that the rise time is near the speed of light and the
chips can latch up , then burn.
PATA. when you power down and pull the power connector, dead.
then leave the data cable (parallel cable ribbon) connected
this loads the buss,in an illegal way, this causes other devices on the buss to fail, Data corruptions, like the DVD, CDRom, or the other
hard drive, (i run 2 drives , since 1981 with first ever pc.) IBM.
i have an Esata external drive 2Tb, AND IS hot swappable. RTM.
first read the data sheet on you HDD, see that page?
at seagate? hot swapping power that old drive is not good.
hot swapping data, will no cause damage like above, but will corrupt data, i see tech in the shop wondering why the windows install disc
hangs, i point the the HDD , there, with no power.....
100 of times, ive shown them....
DVD on same cable is dead power drive.
same with 2 HDD on same cable,
some hard drives float the i/o buss and others do not , with power
removed, the data sheet covers this..
A smart tech assumes no float , unless you like , chasing tail all day.
Posted on Apr 07, 2013
  • 1 more comment
  • tech1 Apr 07, 2013
    if you run this back up disk on seperate HDD port, MB conn.just never hot wire swap the HDD. do not.never connect anything electronic, while HOT.USB is one exception as is external Esata.
    the op clearly stated, PATA and it is not hot swappable,
    last answer to OP PATA , it's safe to you !, but not your data. but do not hot swap any PATA molex do not, i watched a guy install xp 5 times, due to dead PATA drive hanging off the CDrom drive (xp intall cd)
  • 185 Answers
It is perfectly safe to remove the power cable from a hard drive but leave the data cable connected. Make sure that whenever you want to connect or disconnect the power cable, your computer has been shut down first. You could do it with the computer powered on as well, but this would not be good practice and you may put errors on your drive.
Posted on Sep 26, 2008
  • Palmbeach
    Palmbeach Sep 26, 2008
    No problem, it was my pleasure.
    Best wishes...
    what does safe mean? do not ever do that, because the I/o chip will load the data bus. , i wont damage the dead drive but will corrupt data on the conencted drive. also never hot swap cables.
I have a working hard drive (Barracuda 7200.7) from a 2007 HP Pavilion a430n that contains files that I would like to retrieve.
Your description has me confused. I'm not clear on which power and data cables you are using. You described pulling one cable from first hard drive and connecting it to your second drive. Extra power connections should have been in a loose wire bundle somewhere in the computer. (Often they are tucked into an unused drive bay.)
The SR1720NX has 2 SATA controllers and two IDE controllers. Thus it can have 2 SATA and 4 IDE devices. The computer sometimes shipped with a SATA hard drive or an IDE hard drive. In all cases, the hard drives must be connected to the data cable (and to the motherboard) and then the power connection from the power supply has to be connected. So there should be 2 cables plugged into each drive. The optical drive is usually an IDE drive for this model, also a master drive.
The IDE power connection is a large 4-pin Molex connector; the SATA power cables are a smaller 5 pin connector. There is also a small 4 pin connector that powers a floppy drive, if present. IDE data cables are a wide 40-pin ribbon cable (sometimes an 80-pin cable for master/slave). The SATA data cable is a 15 pin cable.
First make sure that the jumper on the drive from the A430n is across the two pins in the second position (counting from the side away from the power connection). This is the cable select option. Next make sure that the IDE cable is firmly connected to both drives and the motherboard. (I've sometimes loosened the data cable while connecting the drives.) Finally check that the appropriate power cables are firmly connected to all the drives. Then power up the computer. (With the second drive on the Slave connection, if the device on the Master connection isn't powered up/recognized, then weird things may occur.)
BTW: you should be alert to the power needs for the computer. The original power supply could be overloaded with the extra drive. You might be better off using an external drive enclosure (USB) or a USB/SATA/IDE dongle that leaves the drive out in the open. Connect these with extreme care following the directions for when to connect the power supply. Some enclosures won't work without reformatting the drive - you do not want one of those.
I hope this helps.
Nov 24, 2011 | Seagate Computers & Internet
Dell Dimension 8400 running xp has died. Can I put the hard drive into a spare slot in a Windows 7 PC to get the data off the XP HD?
Two Options:1. Yes you can as long as your Windows 7 PC has the correct connection for your hard drive. Most likely you need an IDE connection. If you have an IDE hard drive and the Windows 7 PC has an IDE connection, then you will need to make sure to "slave" the hard drive by moving the jumper on the hard drive to slave mode.
2. If your Windows 7 pc doesn't have an IDE connection, the purchase a USB to IDE cable adapter:
This way you can plug your hard drive into any computer through USB.
Best regards,AbdielComputer repair plantation
Oct 27, 2011 | Dell Dimension 8400 PC Desktop
Im just wondering why i might need a slave drive, i have a 80 gig master and a spare 80g drive should i put them both in or does it realy matter
slave drive is very handy in backup files you can store data and other software and drivers. it does matter becouse master drive always has the operating system that the virus and error always happen. hard drive with IDE connector has two jumper setting slave and master. connected to IDE cable. sata disk has no master slave..
Aug 18, 2011 | Computers & Internet
I have a 250gb seagate sata but when i put my 80gb IDE hdd it only detects in booting and in bios but after that if i open my computer i cant see my 80gb IDE Hdd and even in device manager my hard disk was...
there was wrong in the set up of jumper in your 80gb hdd. Look closely to the 80gb harddrive, in between the ide cable terminal and the power supply connector you will see 8pin terminals paired together and a jumper use to short the paired terminals. It is most likely that the jumper was configure to detect your hdd as master. If the ide cable you use for the 80gb hdd was also use for the dvd/cdrom drive then it will conflict with it if both jumper setting was set to master. See the description of jumper settings in the sticker of the hdd. Position the jumper to slave.
Reboot your system again and see if the 80gb finally appear in your system. When system boot upon detection of hdd, the primary master should be 250gb while your primary/secondary slave will be read your 80gb hard disk.
Jan 24, 2011 | Seagate 80GB 7200 rpm SATA/150 8MB Serial...
How do I add more memory to my dell dimension 3000 computer thatn has a 34 GB Harddrive?
Go buy an IDE hard drive of whichever size you want, and connect it to the IDE cable that your current drive is connected to inside the computer. If you don't want to reinstall windows, you'll have to either purchase a separate IDE cable and connect the new drive to another IDE port on your motherboard (IDE cables are the thin, flattned cables that are fairly wide) If your current IDE cable has a freed up connection, ensure that your drives are jumpered properly with the master/slave options that should be printed on the drive itself, with a diagram. Your main drive (34GB) should be the master, the new one set to slave - this will keep the computer booting off of your current hard drive. It may seem intimidating, but installing a new hard drive is easy once you open up the computer and start comparing parts, looking for your hard drive ports and power supply cables. Just make sure the IDE cable and the power supply cable are firmly attached to the new hard drive when you install it.(power supply cable usually has a white tip, with four loosely bound wires leading to it) I hope this helps!
Nov 18, 2010 | Dell Dimension 3000 PC Desktop
ASUS K8S-MX Motherboard, but when I connect IDE
How were the partitions created on the SATA? Are they RAID configured from the other system? Does the new motherboard have the same support for your HD as the other system? Check the setup in the BIOS screen on both systems to make them identical as much as you can. According to Tom's Hardware: "In the SATA port configuration place you have up to four "mode" choices: IDE (or PATA) Emulation, native SATA, AHCI, or RAID." Check this section.
Dec 13, 2009 | ASUS K8S-MX Motherboard
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
Installing a IDE to SATA converter adapter
I have successfully connected a older. 20 GB drive to a computer with a 2. sata connection on the mother board.
Buy trial and error I found that connecting a power cable to the converter and the hard drive was the only way to get the Bios To recognize the drive.
Done sucessfuly with a 40GB drive as well, Set drive to master.
Feb 21, 2009 | Generic Memory (RXD639) Serial ATA...
Hard Drive Installation
Hi emceedrive, I gather you are using ATA/PATA IDE hard disk drives? Each hard disk drive has a large white sticker on it. Listed there are pin settings to set the IDE to Master or slave & Master with a slave. (We want to leave you're drive with windows on it alone). Not changing its jumper or not adding a jumper for now. We are not hooking up you're second drive just yet either.
Oh, please you're not an idiot either.
Unplug the power cable from the PC & open you're case.
Please open you're ASUS P4P800 SE manual to section 2.2.3 Motherboard layout. We want to connect the data cable to SEC_IDE1 first because once PRI_IDE1 is connected you will not be able to connect SEC_IDE1's data cable up to the DVD drive bay.
So grab a data cable for you DVD drive. It may have three connectors on it. Plug the connector that is the furthest from the other 2 connectors on the cable into the motherboard slot named SEC_IDE2. The data cable only goes in one way. Run the remainder of the cable up to the DVD player but do not connect it to the player yet. It is ok to fold the data cable which will help in routing it upwards to the DVD bay. Than connect the data cable to you're primary master IDE drive. (The one with windows already installed on it). The data cable should look just like the DVD data cable. Again you want to connect the furthest connector on the data cable into the MB slot named PRI_IDE1.
For now it’s best not to install the drive into the drive bay. Stand it up next to your case or lay it down flat with a sheet of paper under it. Connect the power cable to the drive. Plug in the PC's power cord & power up the PC & start pressing the delete key every two seconds until the bios main menu loads. You should see the Primary Hard disk drive listed at the main menu. Now go to the title Boot in the bios. Open boot order. The boot order of the devices should be as follows.
Boot device 1. (Floppy Disk Drive)
Boot device 2. (DVD Disk Drive) [None shown it’s not connected to the system].
Boot device 3. (Model number of your Primary IDE Master HDD).
Once this is set, save the bios & exit. The system should auto restart & windows should load. Let windows finish loading. Than shut down windows normally.
Unplug the PC's power cord. Since you had to remove a DVD drive you'll need to set the remaining DVD player's jumper on the drive to a Master & connect the data cable & power cord to it. (You may have to remove the DVD to see where the Master pins are located. It will be marked on the DVD player near the pins).
Now take you're new drive, do not insert it into the drive bay. Look at you're Master drive's white label. Set the jumper on the master drive first. It should be set as a Master drive with a slave.
Connect a jumper for this.
Go to you're new drive. Again look at its white label. Set this drive's jumper as a Slave drive. The Master drive should be connected to the end of the data cable. The new slave drive should be connected to the next in line connector.
Once all data cables & power cables are connected plug in the PC's power cord & boot the system, again pressing the delete key every two seconds until the boot main menu loads. Now you should see the Primary IDE Master drive & you're new Primary IDE Slave drive listed. You should also see the DVD as the Secondary IDE Master. Go to the title "Boot" again. Set the boot order as mentioned above. Save & exit the bios. Windows should load as it did before. Once windows has finished loading open windows Explorer & see if you're new slave drive is listed.
Shut down the system & unplug the power cord. Unplug the slave drive & mount it into its drive bay. Take a black marker & mark the side of the drive as slave. Disconnect the Master drive & connect it into its drive bay. Reconnect the data cables & power cables. Check all connectors before closing the case up. Re-connect the PC's power cord & boot the system. Everything should be fine. If you have a problem getting the data cable connected to the slave drive because its closer to the DVD drive as opposed to the Primary IDE Master drive you can make the slave drive a Secondary IDE Master (Change its jumper setting according to the drive’s label for Master with a slave) & connect the DVD player as a Secondary IDE Slave. (Change its jumper to slave). Change the Primary IDE Master drive’s jumper as a Master with no slave, single drive. That all.
Good luck emceedrive!
Take your time. Any troubles please post here.
You should be fine though.
Aug 11, 2008 | ASUS P4P800 SE (890552603657) Motherboard
My computer won't recognize my new 80GB Seagate IDE hard drive so I need instructions of how to install it properly or some instructions after the install
Go to the bios setup during boot & check whether this drive is shown there. If not, Check whether you have connected the drive rightly. i.e. the connections for IDE cable & power cable are securely connected.
Also, check whether you have setup the master/slave/cable select jumpers rightly..
Set the jumpers on your hard drive for cable select. If you have another drive also connected via same cable, then set the jumpers on that drive for cable select mode.
Alternatively, set one of the hard drives as master & other one as slave.
Also make sure that you have connected the cable in the right direction. Long leg of cable towards the motherboard side & short leg towards the hard drives side.
Hope this helps you friend..
Aug 06, 2008 | Computers & Internet
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
245 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
