Question about Garden
Mower bades Are the blade bolts reverce threaded on a poulan riding lawn mower?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
I have a 2007 pollan pro 19 hp mower that i have changed the blades on and they were not reversed threads righty tighty lefty loosey
Posted on Sep 26, 2008
How to remove a stuck bolt on blades on riding mower.
The blade bolt can be very difficult to remove sometimes and will require an impact wrench. If that doesn't work, you will need to heat up the nut only with a Ox/Acetylene torch, then it will remove easily. Do not heat the nut too much or it will ruin the thread on the spindle when it comes off. Remember to heat the nut only.
Aug 06, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower runs rough when blade is on
one or both blades are out of balance replace blades could have hit a rock or bottomed out on ground
Jun 19, 2014 | Poulan PO14542LT 14.5 HP 42 in. Lawnmower
Which way do you turn the bolt on the blades of an ariens riding mower
You turn the bolt in the opposite direction on the the way the blades spin.
Jan 26, 2013 | Ariens 42" Riding Lawn Mower Blade ...
I have a cub cedet commercial tank 60 zero turn lawn mower, and i need to change lawn mower blades. Which way should i turn the nut to take the blades off.
As viewed from the bottom, if the blade turns clockwise, then the bolt should have a left-hand thread. A possible exception would be if the blade cannot slip relative to the shaft. This could be the case if the blade (not the washer) has a D shaped hole in it.
Good luck, Al K
Aug 26, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Ihave an old john deere lawn mower 21 inch #GX1458. Is the blade screw left or right hand thread
Always unscrew the bolt in the same direction of blade travel.If the blade travels clockwise,loosen bolt by going clockwise.
Mar 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Poulan 38" 15.5 hp lawn mower cuts off when blades engaged.
you have a bad blad saftey swich that all it is replace that and youll be good to go
Oct 01, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
The star mounts on my poulan 42'' riding lawn mower
Without knowing your mower for sure, I think I know what you may need to do. Most often, you just need to remove the block that the pattern is on. These are most often bolted onto the shaft. If you don't have your parts book for your mower, you may bee able to look it up online.
Jun 07, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan Pro riding mower jerks in forward and the blades engaged
This is a lawn mower catagorized as a chainsaw. We don't answer lawn mower questions ands you don't cut down trees.
Mar 23, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Mower shakes
sounds like you bent the crank - remove the spark plug , tie the shut off handle closed with a rope , then raise mower up so you can spin the blade . look at the blade bolt while you spin blade . if crank is bent the bolt will seem to wobble
Oct 13, 2008 | Poulan "Poulan" Push Mower
Garden Logo
294 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
