Question about Canon imageRUNNER C3220 Color Copier
Cannot make copy darker
We've tried using the buttons that indicate you can either darken or lighten, but it just isn't adjusting it at all.
I'm sure its a simple fix. We just figure it out.
  • 67 Answers
Go into service mode second level and adjust your colors
Posted on Nov 27, 2008
How do I adjust the setting to lighten copies?
Canon : PIXMA Manuals : Print Studio Pro : Settings Area ...
ugp01.c-ij.com/ij/webmanual/PrintStudioPro/W/1.3/EN/.../psp-406.html
figure: Settings area (Correction). (1) Black and White Tone Adjustment Area ... Move the slider to the right to darken and left to lighten the color. ... the XPS printer driver (Canon series XPS) for Printer in the Settings area (Print Settings).
Canon : PIXMA Manuals : MX920 series : Adjusting Intensity
ugp01.c-ij.com/ij/webmanual/PrinterDriver/W/.../Dg-c_intensity.html
You can dilute (brighten) or intensify (darken) the colors of the overall image data ...Used Settings, and then choosing Color/Intensity Manual Adjustment under ...
Canon : PIXMA Manuals : Image Settings
ugp01.c-ij.com/ij/webmanual/ScanGear/M/MFP/19.1/.../Sg-930.html
When Image Adjustment is set, the brightness of the specified portion of the ... Use this function to reduce show-through in duplex documents or lighten the base ...
Oct 20, 2015 | Canon PIXMA MG3222 Wireless Inkjet Photo...
How do i make copies darker canon pixma ?
Actually pretty easy to do and just in case someone never gets back to, Cannon does provide an online user manual.
To darken copies: While in copy mode, press the menu button. Next, arrow over to "copy intensity", once there you should make sure that you\'re in manual mode, hit OK. This will bring up a darken/lighten mode and you can make adjustments from there to what you want. If your copier is starting to fade on it\'s initial copy setting, you also may be close to running out of ink if you haven\'t checked it in a while. Even though they shouldn\'t , if you don\'t used it that often, it can still dry out the connections. Hope this helps.
Aug 12, 2014 | Canon PIXMA MX310 All-In-One Printer
Copy darker
go into the menu and look for copy/print settings. you should see an option to lighten or darken the copy. It should look like a ascending /descending slider. tap to the left for lighter or to the right for darker
Nov 27, 2013 | HP Officejet 5610 All-In-One InkJet...
Our Sony Tv RMyD003 screen is darker than we would like and we need to brighten the picture. We are unable to locate our Manuel and would need your help. Thank you
Try going to your menu or input select and you should see a scale to darken or lighten input. The remote should have a button on it to let you get to main menu.
Aug 11, 2013 | Sony RMyD003 Remote Control
Even with new ink cartridge printer prints light
Double click Control Panel.
Double click Printers and Faxes.
Right click your printer and select properties. Now on General tab select "Printing Preferences".
Now select the basics tab and click "Advanced features" found on the right of the page.
Here you will be able to adjust the amount of ink that is used to print a page. Side the bar to the right to increase/darken the print.
Now click OK, followed by Apply.
Take care!
damnor01
Jun 07, 2012 | Office Equipment & Supplies
Toshiba e-studions 230 touch screen went very light where i cant see the screen well how do i make it darker
Hi, If you look under the control panel you should find the adjustment to lighten and darken the display screen.
Hope that helps.
Lbcoast
Jul 13, 2009 | Toshiba e-Studio 161 Copier Copier
Ink tone
Hi Pam -
This is a common problem with the CX 5000 - there is no contrast control (i.e., light/dark) like you would have on a photocopier. But if you use the scanning mode (EpsonScan) instead of the copying mode, there are a couple of alternative options that might help:
1) Brightness - in the EpsonScan program, in Home Mode, under Image Adjustments, there is a button labelled "Brightness." Depending on the colors and contrast of what you're copying, adjusting the brightness may help.
2) Color Restoration - In both Home Mode and Professional Mode, this feature is meant to restore the color to a faded photo - depending on the colors of your document, it may make the copy lighter or darker, but it's an option.
Hope this helps!
Dec 11, 2008 | Epson Stylus CX5000 InkJet Photo Printer
We cannot seem to make a copy darker??
i would suggest that 1st you do the auto gradation adjustment full adjust under add function /adjustment cleaning then under additional functions look for one that says printer settings you can adjust black density under that setting
Sep 26, 2008 | Canon imageRUNNER C3220 Color Copier
Copying from Colored Paper
No..The exposure will only give you an overall lighter or darker copy.. Dave UK
Feb 23, 2007 | Canon ImageRunner C-3170U Copier
Canon imageRUNNER C3220 Color Copier Logo
70 people viewed this question
old marine
old marine
