Question about InFocus ScreenPlay 4805 Multimedia Projector
InFocus IN72 Multimedia Projector can't handle a bright colour.
Hello.
I have had the InFocus IN72 Multimedia Projector for some time now, but I just got the PS3. However there seems to be a major problem then the picture is too bright. Fx. when I drive directly under a street lamp the picture becomes distorted, like when the TV has a bad reception. Is that a problem with my projector or is it just like that in general?
Thank you for your help!
    Novelist:
    Scholar:
  • 149 Answers
I have the perfect example for you as to why this happens. It is a bit baffling at first but once you think about it it really does make a lot of sense.
IN72 is a great projector. They've bettered the technology with newer technology preventing previous complaints from consumers..which keep in mind its a home theater projector primarily. It's also a great price for what it is which is a huge thing for consumers over the years.
The thing with a home theater pj [pj=projctor] vs.a business one is that the home theater has a lower lumens and a higher contrast ratio to them. However, when you go on the business side it's the complete opposite. The idea on this is, for example:
Conference room: Some ambient light present. Maybe lights unable to dim? Want to show mostly text. Great, business projector is the best solution unless you have a demand for a special connection that only the home theater offers then in that case you might have to go with more of a plasma, or LCD panel instead?
Home/game room combo: Controlled lighting. Great. Has blinds for example. You want to watch it for occasional tv football games, or mostly movies since you would like to have movie nights at your own home vs. going out to a theater? Well then, a home theater projector is ultimately the best solution for this situation.
Why do these situations not want to combine?
Simple actually.
Lumens=how bright the projector is
Contrast ration/ratio: the rating in which compares the black levels vs. lights in a pj
business: brighter for people to read text unless you are using it for video/color purposes.
Home: less brighter but have awesome blacks/whites which people WANT for home theater.
What I'm getting to with this....
When you have a home theater project you do not want any light but maybe a soft light in the room. The projector has this path of which it projects this bright image into your screen. Any lighting passing through that will break it up and make it less. The perfect way to imagine this is get a flash light. You can see it very well with the light off. Perfect, huh? You can see where you are going. Well, when you turn the light on it breaks up the lumens in the flashlight and you can not see it very well if at all.
So any light in your room will desperately influence the picture/image you will get off of the projector. That is why you are seeing the image become more distorted.
If you're going to use this under a well light situation either a super large plasma is ideal to maintain brightness otherwise a bit more expensive higher lumen pj to fix the solution a little bit. You can change all the settings you want, it might make it a bit more brighter which will run out the life of your lamp even quicklier, but there is only so much you can do but change the location of the setting/environment in which it projects.
I'm sure this is a lot of information. Let me know if you have any further questions. Thank you for your time and I wish you the best of luck.
Posted on Oct 27, 2008
How to reset projector hours for Infocus IN72 P720
Hello
To reset lamp hours:
Menu => Settings => Service
In this window; you can select Lamp reset.
Press Enter or OK.
Oct 04, 2011 | InFocus IN72 Multimedia Projector
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
When I connect the IN72 to a Digital TV Terminal I see horizontal moving lines on the screen.
the resolution doesn't match. reset the projector settings to factory default and make sure the settings are correct, and if the projector can handle the digital signal. you can also try swapping the cables.
Mar 07, 2010 | InFocus IN72 Multimedia Projector
Infocus IN72 - blinking RED light
firdt off, did you reset the lamp counter? did you clean the dust out of the projector? it may be overheating as well. if the lamp looks ok, you may have just blown the ballast. try projector doctor online.
Mar 03, 2010 | InFocus IN72 Multimedia Projector
The image via HDMI does not work in projector Infocus IN72
what is the image from? make sure you have the right in put and that the resolution matches. try swapping cables, too.
Feb 08, 2010 | InFocus IN72 Multimedia Projector
InFocus IN72 shuts off after 20 min.
internal error. if the lamp looks ok and it doesn't have many hours on it, it might be the power supply. the capacitors dry out and do not supply sufficient voltage. the in72s do have that problem.
Aug 27, 2009 | InFocus IN72 Multimedia Projector
Infucos IN72 projector
Hi Ronnel
This is a common Mainboard failure on a Projector.
The unfortunate thing is that the Mainboard will either have to be repaired or replaced.
Apr 18, 2008 | InFocus IN72 Multimedia Projector
Infocus IN72 powers up but no image, replaced the bulb but still no image...
Hi there
This is most probably a Ballast ( lamp's powersupply ) problem.
Make 100% sure that this unit is out of warranty because InFocus Projectors come out standard with a 2 year warranty.
Apr 09, 2008 | InFocus IN72 Multimedia Projector
IN72
Try using a different cable.
If the response is the same on a different cable , then the Mainboard might be at fault - this machine should still be under warranty and the warranty will cover repairs.
Apr 05, 2008 | InFocus IN72 Multimedia Projector
InFocus ScreenPlay 4805 Multimedia Projector Logo
146 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
