Question about Samsung Office Equipment & Supplies
Faxes not going through - Samsung Office Equipment & Supplies
    Sergeant:
  • Samsung Expert
  • 406 Answers
Kindly update the model number. and region. Where the problem is.
Are you using any PABX or VOIP line etc.
Posted on Sep 26, 2008
No Incoming or Out going Faxes Out going faxes
Press Setup Button on front panel of printer
Scroll to Fax Settings ( Or Advanced Fax Settings )
You will find ECM ( Error correction mode )
Turn it OFF
Try to receive Fax, IT should work
Jun 25, 2010 | HP Officejet J5780 All-In-One InkJet...
I can't send a fax from my vista program with out printing out the fax first and sending it the old way, and that waste paper. in the xp or word 2003 I can go to the send in the file and the fax wizzard...
You need to go to printers and choose 'add a printer'. Under add printer, choose the printer called "MS FAX." That will install microsoft fax as a printer. Next, print your document by going to File, Print... (make sure it says "PRINT..." then you should see a selection screen, choose ms fax, and there you go. That should do it.
Oct 01, 2009 | Microsoft Windows Vista Ultimate Edition
I am having problems receiving a fax.
Check the number of rings your fax machine is set to. Chances are, the answering machine is set up for 4 rings and the fax machine is set up for 6. If this is the case, change the number of rings on your fax machine to 2 or 3 rings to ensure an incoming fax will go directily to the fax machine. If the fax doesn't recognize the call as a fax, it will go through to the answering machine.
Jul 17, 2009 | HP 1040 Plain Paper Inkjet Fax
Not pausing to acknowledge
Open up the feeder to see if a piece of paper is holding a switch actuator down.
Feb 04, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Answering fax doesn't receive my fax
you need to go into the menu set up where ut says easy receive and hit the set button or menu and then try and have some one fax you something
Jan 04, 2009 | Brother IntelliFAX 2800 Laser Fax
How can I get a fax confirmation, once a paper is faxed?
Press menu and go into the basic fax set up, then go into the sending confirm option and choose on. You can also choose error and it will only print if the fax does not go thru.
Aug 05, 2008 | HP 1040 Plain Paper Inkjet Fax
Fax
HI,
u can press set up go to advanced fax set or basic fax set up and then go to fax logg > press ok on that .
u can get the details of the last 10 or 15 faxes.
Thanks
Apr 02, 2008 | HP Officejet 5610 All-In-One InkJet...
How to not print faxes after hours
simply go into modes Fax/telephone and select telephone mode only instead of fax/telephone mode there is really no way to set the fax to not take faxes after hours automatically as it is designed to receive telephone calls and faxes as the machine reconizes fax tone.
the only disadvantage to doing this is you will have to change mode on a daily basis back to Fax/tel Mode during work hrs and back to telephone mode after hrs or simply uplug the phone cord going to the fax after hours
Jan 07, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Can't get Fax Confirmation page to print
What model brand name something!!!!!!
Nov 12, 2007 | Sharp AR-F152 Fax
57 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
