Question about Minolta Di2510 All-In-One Laser Printer
Error code c0500
I have a minolta di351 copier scanner and printer. It recently started giving me th above error code. The light is flashing on the second paper drawer down as well.
Open back coever then press reset switch from mainboard
Posted on Oct 02, 2009
Don't laugh but might be extremely low on toner, do a service reset and view through vent holes in the fuser upper cover to verify fuser lamp lighting. tray light flashing is paper low indicator. hope this helps. gt
Posted on Oct 31, 2008
You probably have a bad fuser.
Posted on Oct 10, 2008
Machine give a coade c0500
The error code C0500 deals with the fixing unit temperature. I could be a blown fixing lamp or thermal fuse or thirmister. You did not give the model number, so I can not tell you how to reset the error code. Good Luck
Nov 02, 2013 | Minolta Office Equipment & Supplies
Bizhub 350 manual de servicio codigo de error el c0500
In correct code for a Bizhub 350. What is the model # Bizhub Fuser errors start with 34, 37 ,38 for the Bizhub 200/350
May 11, 2013 | Minolta bizhub 200 Copier
Error Codes
Well the C0500 code is the code that is given when the fusing unit is bad (THE HOT PART) to reset that code need to go to the rear remove top rear cover and press the small black button on the control board lower left. The C0400 is Exposure Lamp the bright lite under the big glass. Might need to get a new one try web site below as for the C0500 if it comes back do not reset get Konica Minolta rep to look at the fuser unit. IT can catch on fire and that would ruin a perfectly good day. If parts required see the web site below for a start Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Feb 16, 2012 | Minolta EP1083 CS/PRO Copier
IT AUTO CUTS POWER AND GIVES A CODE THAT IS C0500
i have a SF- 2510 sharp copier that is displaying the error code C0500. What does this code mean and how do I fix it?
Feb 23, 2011 | Konica Minolta DiALTA Di200 Copier
Co510 code
One of the parts in the list below are causing "Low fuser teperature"
C0500: Warming-up failure
C0510: Abnormally low fusing temperature
C0520: Abnormally high fusing temperature
Relevant Electrical Parts
Fusing Roller Heater Lamp H1
Fusing Roller Thermistor TH1
Fusing Roller Thermostat TS1
Fusing Roller Heater Lamp Fuse TF1
Side Cover Interlock Switch 2 S3
Power Supply Unit PU1
Master Board PWB-A
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 03, 2011 | Minolta Di351 All-In-One Laser Printer
Machine trouble
Sir,
To clear the fuser error code, perform the following:
1. Power the machine OFF.
2. Press and hold the STOP key.
3. Power the machine ON. Release STOP after 5 seconds.
Jul 16, 2009 | Konica Minolta Di1610 Copier
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
Bizhub Di1610fp
C0500 code that is fuser.try reset this one first by powering machine on while holding down STOP BOTTON ON THE OP PANEL
hope that help
Oct 10, 2008 | Konica Minolta DiALTA Di200 Copier
Minolta di 2510 code c0500
lo ke pasa es ke mi copiadora ya no responde mas y me sale este error una averia "a sido detectada avice a su servisio tecnio y digalke el codigo c0500" ya no se ke hacer... ayuda por favor..
Jun 24, 2008 | Minolta Di2510 All-In-One Laser Printer
Minolta Di2510 All-In-One Laser Printer Logo
787 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
