The most likely cause is that the O-rings on the feed pipe from the oil pump to the block have degraded. This can cause a severe drop in pressure, but may only be apparent when the oil is hot and therefore thin
Hi,it sounds from what you are saying that you have a isue with the oil pump,and the noking could be where the oil pressure is down so oil is not lubricating the bearings,to run it in this state could couse intunal damidge to the engine,you need to get this checked out.
all the best.
Sounds more like an engine idle issue than a oil pressure issue. If the engine idle drops too low, the oil pump cannot provide sufficient oil pressure. If there is no oil light when the engine is idling normally, then there is no problem there.
check oil level in sump. You may have to remove the sump to check for cracked oil pick up line . Check oil pump pressure regulator . replace oil filter as it may be blocked and dropping the oil straight back to the sump.
Usually two reasons why oil pressure drops over time,worn engine parts,old oil.Try an oil change with new filter I sometimes use an additive like Restore.Over time the oil will become thinner and less viscous leading to a drop in oil pressure.
Hello mb4494: My name is Roger and I will help you. If by changing the oil pressure sending unit the problem did not change. I would perform a oil pressure test. This is done by removing the oil pressure sensor and inserting a oil pressure gauge. This can be done by yourself or by a repair shop. This needs to be done on a cold engine. Start the engine and observe the oil pressure cold.as the engine warms up observe the pressure. The pressure will drop off as the engine warms up.Should the oil pressure drop below 10 to 12 PSI. then you have internal engine trouble. More then likely a bearing problem. Try dropping the truck into gear and see what the pressure drops off to. Again if the pressure drops below 10 to 12 PSI. you have a problem. I would also check to make sure you have the correct oil switch. a truck with a oil light uses a oil pressure switch. with a gauge you would use a oil pressure sending unit. Sorry for the long reply but want to make sure you check the pressure correctly. Please rate the quality of the answer as this is how we know the answer was correct. Thank You for using Fix Ya. Roger
No it is a fail safe. When your oil pressure drops below (on most cars) 30 psi your computer will shut your fuel pump down until you either let it sit for a while and it resets or until oil pressure builds again. Sorry!
your oil pump is either weak or there is sludge i9n the oil pan. my adives is to have the oil pan dropped . chances are sludge is the culprit. as the oil get's warm the pressure should only drop slightly but pressure is generally dictated by engine rpm. pumps are gear driven so if it was a bad pump your oil pressure would start out very low at start up.
