Question about Sony Televison & Video
I have a Sony DVD-CX995V disc changer and one of the off white plastic arms that pinch the disc to load it into the reading area has cracked off. It is the female arm that is on the outside of the support screw. What is that part called and how hard of a fix is it? Thank you.
  • 3 more comments
  • adams101 Sep 26, 2008
    I hope this is helpful. The part I am pointing to with the screwdriver in the pic below swivels around the support bolt, is this correct? Thanks again for your help.
    the above pic is where the part should be connected
    Above the number 245 is where the arm should be, to move in tandem with the other arm to load the disc into the scan area
    this is a better pic of the area
    Thanks for the help I am going to order some parts to try and fix this myself. I think the part might be #404 in the pic though, can you send me the part number for that item as well. Also is what is the proper way to replace this item. If that is too involved the part number will do just fine. Thanks again.
    Part #404 has what part number?
  • 10,594 Answers
I need to know what exactly part you required.
Can you provide broken part picture here to help you out.
Posted on Sep 26, 2008
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Sep 26, 2008
    Thanks for pics,
    please identify required part in following 2 pics or give complete mechanism pic to understand where is that part located.
    After identifying part, will provide you part number.
    I been pointed out part which is broken. Please confirm it in below exploded view picture.
    its detail is as ... 401 X-4952-499-1 LEVER (LOCK 400) ASSY
    You are right, its part # 404
    404 X-4952-501-1 HOLDER (DISC L400) ASSY
    Good luck.
    its available here
    Part Store $5.00
Sony DVP-CX995V "cannot play"
you can clean the motor by the back side
Oct 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Sony DVP-CX995V 400 disc DVD Player wont read DVD-
After variety of different tests and findings I have resolved this issue. It appears that the DVD burner was not in good working order and the DVD player was not at fault. Thanks you to all who answered and responded to my problem. Many thanks.
Aug 18, 2009 | Sony DVP-CX850D DVD Player
My sony dvp-cx995v
Seems optical lens of unit is causing problem of No Disc.
Clean optical lens with cleaner disc and then try to play dvd.
If still same problem, take unit to local repair shop for fix.
Feb 12, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Sony CX995v "Cannot Play" message on DVDs but plays CDs O.K.
Hi...
The laser goes thru a different lens arraignment for DVDs.
Take it to a TV shop and have them "blow out" the laser assembly with some CO2 and clean the lens.
Jan 22, 2009 | Sony DVP-CX985V Multi-disc DVD Player
My Sony DVP-cx995v stopped playing DVD's
I had the same "Cannot play" problem - happened suddenly, I don't think I was doing anything unruly at the time.
After checking repair (exchange) prices in excess of $250 from Sony, I decided to open the cover to see if I could see anything wrong - normally a futile exercise with electronics except that in the past I have cleared errant disks that have lodged themselves near the drive/player at the rear of the library.
Upon opening and watching the library try to load and play I noticed the drive itself was not spinning the disk once loaded. It would sit for awhile, thinking about it I'm sure, then would unload and load the next dvd, again failing to spin.
I thought okay, maybe try to spin the dvd while in the player to see if it's jammed or otherwise hard to turn. It was not hard to turn and spun freely. In fact, when I put my finger through the hole at the exposed side of the player at the hub to spin the dvd, clockwise, it suddenly started to spin - and play!
I put the whole thing back together to test and all seems to be working fine at this point. Not sure what would cause the motor to stop spinning and remain in that state through poweroff/on cycles etc. but I'm sure this is not the last time I will have trouble of this kind.
I would note that when replacing the library back in its home on the shelf, be careful not to tip the library, especially toward the player area because the disks will spill out of the carousel near the player and become jammed when you power it on and attempt to load. A final tip of the library away from the player area may clear this if you hear the disks rolling out of their slots and you don't want to open the top again (it's a darned heavy box when fully loaded).
Jan 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Sony DVP-CX995V
Its problem of incomplete unloading of CD tray so system control in player sense it and generate command to close it.
CD Loading mechanism needs service and cleaning to loading belt.
If you have electronics experience, you can make it easily. let me know if you need further info.
Nov 20, 2008 | Sony DVP-CX995V Multi-disc DVD Player
Hdmi output
There is a firmware update available from sony that appears to address this problem. Go to sony and do a search for the model number dvp-cx995v. I have not tried it myslft but the write seems to address your problem.
May 04, 2008 | Sony DVP-CX995V Multi-disc DVD Player
Sony DVP-CX995V will not play through the hdmi output
There is supposed to be a firmware fix for that from sony.
Feb 08, 2008 | Sony DVP-CX995V Multi-disc DVD Player
Televison & Video Logo
121 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
