Question about Mitsubishi WD-57732 Projection Television
SCREEN IS BLACK
I TURN ON TV AND SCREEN IS BLACK BUT GET SOUND.
AFTER 1 MINUTE TV TURNS OFF AND RED LIGHT COMES ON
CAN NOT TURN TV ON FOR AT LEAST 10 MIN. THEN THE SAME
THING HAPPENS.
I DON'T WANT TO PURCHASE LAMP UNTIL I KNOW FOR SURE
THIS IS THE PROBLEM.
  • raider316 Dec 06, 2008
    I have the same problem, did getting a new lamp work?
Called a service tech, (for free)
he said it was probably the lamp, and it was an easy fix.
Just have to order the lamp and put it in our selves.
I will let you know if it works or not.
We were told the lamp goes out anywhere between 1000 - 2000 hours.
So we will be needing the lamp regardless.
Posted on Sep 27, 2008
TV wont turn on sometimes. push the on button, light turns from red to blue but no display or sound. If I disconnect the power cord for 15-20 min and plug it back in to the tv it will turn on and stay
My Samsung started doing that and it got worst and worst. Searched the web and find answer. It was the high voltage circuit. All TVs now are like computer and it check for 390 to 400 volts and if it is below, the TV will not turn on. Good thing the Samsung has only one capacitor showing the high voltage circuit. Measure the voltage was 381 volts. The capacitor was rated at 100 uf at 450 volts. From some old TV and power supply, got two capacitors rated 150 uf and 220 uf both at 400 volts. Had to connect them in parallel and took out the old capacitor. Now, my TV works fine.
Nov 03, 2017 | LG 42LG30 42 in. LCD HDTV
Magnavox about 7-10 years old as soon as i turn it on it turns off and stays off
my 42 inch sagem tv is overheating, the red light comes on, then 2 lights come on and then turns off, and light stays on. and only turns off when you disconnect tv. When i turn on the tv after 1 min the light flashes, the tv turns off and the light stays on.
Sep 18, 2011 | Proton MM2701VT 27" TV
Sony kf 50e200a screen goes black and sound turns off for min...
TV has gone into "protect mode" to do just that to protect against the damaging failure that has been detected, you will need a servicer to diagnose the failure. Good luck and Merry Christmas!
Dec 25, 2009 | Televison & Video
Flasing red light where the on light is
I have a philips pf50 9630a/37 tv may come on or it may not unplug it and take a chance then comes the 6 steady red flashes followed by 3 rapid red flashes the screen had been completely replaced by philips a year and a half ago
Mar 22, 2009 | Philips 50PF7321D 50 in. Plasma HDTV
Tv turns on and than red status light comes on and shuts down
it sounds like the 3300uf caps on the power supply have gone bad.look at them and see if they are pregnant. if so change them. while you have the shield off see if any other caps are pregnant, if so you might want to think about having the chassis repaired.
Dec 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Tv will not stay on only for 1 min. then turns red and off
Symptoms shows Red Tube is defective and needs replacement.
Please confirm model number with serial to look for Red Tube in stores.
Thank you.
Dec 17, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony 57" rear prijection TV has a fast flashing light and will not turn on
turn on tv, after a few minutes picture goes black, but still have sound. red light blinks 5 times,turn set off same thing happens when you turn set back on. some times it want do it for 10 min.
Apr 25, 2008 | Sony KP-57WS500 57" Rear Projection...
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Sep 09, 2007 | Hitachi Director's Series 65XWX20B 65"...
Mitsubishi WD-57732 Projection Television Logo
235 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
