Question about E-Machines eMachines Desktop PC
I INSERT CD DISC NOTHING HAPPENS
COMPUTER SAYS FUNCTIONING PROPERLY. INSERT DISC , DISC ICON FLASHES THEN GOES AWAY. E-MACHINE 633IS.
  • hbg786283 Mar 23, 2009
    my computer not icon cd drive
  • 35 Answers
Hi there
Thanks for posting your problem on fixya
IT seems that problem your cdrom drivers please go to device manager >> right click on my computer then click on hardware then click on device manager double click to cdrom and uninstall cdrom drivers then reboot and reinstall cdrom drivers. Your cdrom working fine
Don't forget to vote me
Thanks
Robert
Posted on Sep 26, 2008
  • Valifernax33 Jul 10, 2010
    What mean of reboot ?
  • 26 Answers
1st checks your disc condition, do clean that if dirty, 2st remove your cd drive and try that in other pc with other cd , if its ok, your problem is your cd not cd drive, if it is'nt ok problem in yor cd drive you must change with new one. Any case with same problem sometimes caused by socket power cd drive ,by change with other socket frequently solved that problem. If source problem from your cd i thinks that happen caused by too much speed burning in process burning, i hope you use slow speed in process burning, so you get good quality cd and that,s easy to read in every cd drive, ok i hope helped solved your problem, good try
Why won't my Acer laptop play compact discs?
Most units are designed to "autoplay" audio CDs when they are inserted. When they fail to do so, it could be because the CD is dirty or scratched and was bot recognized, the media player that you are using to play the CD was not in a state that it could autoplay the CD, or there could be a problem with the Disk drive or PC itself. Whenever a CD fails to play upon insertion, go to the "My Computer" icon (win7 or below) and see if the CD/DVD drive shows a disk inserted. If so, clicking on the drive will often start the playback.
Dec 30, 2014 | Acer Aspire 5100 Notebook
My e-machines etower 633is won't boot up. The beginning black screen comes up then the E-machines screen and that's as far as it will go. It gets stuck there. Can you give me some idea what is causing...
I cant really seem to understand but if the computer beeps then you should take the RAM out and clean it and re-insert it. and try again. Sometimes the processor can give that kind of problem if it is faulty.But if after cleaning the RAM it still doesnt work please take it to the tech department.
I hope this solution is helpful.
Sep 26, 2010 | E-Machines etower 633is PC Desktop
Nothing happens when disc Inserted
If there are no activity lights, or a rhythmic flashing on the drive, then you may simply need a new drive. Small computer stores are usually the best place to go to get a replacement at low costs.
If you are just popping the disc in and waiting for something to happen, then your computer may not be automatically running the programs from the disc. In which case you will need to manually access the drive and run the correct program.
Good Luck!
Aug 06, 2009 | IBM (92P6581) for ThinkPad T40 (92P6581)...
Hp dvd/rw does not read discs
If the CD or DVD disks you inserted work in some other reader, then your reader is the problem -- even though it is properly connected to your computer, and Windows has the correct device-drivers, it is the "hardware" that is the problem.
When you insert a disk, rotate it to some position, i.e., top-lettering goes in first, and close the drawer. Do you hear the drive start to spin the disk? Open the drawer. Is the disk in the same (non-rotated) position? If so, then the motor that spins the disk is the problem. If the disk does spin, but nothing happens, then it is the "laser" part of the mechanics that is not working.
Replace it.
Apr 21, 2009 | LG GSA-H55N DVD-RAM Burner
Laptop not recognizing CD drive F
the yellow exclamation mark, states that the device is not functioning correctly.
options are:-
1:) go to the manufacturers website, and see if you can download a driver for this.
2:) try uninstalling the device, reboot and see if the device manager, finds new hardware, if so reinstall the device drivers.
3:) eject or remove the device, re-insert ( possible dirty-bad-loose Connection.
Mike @ Compurepair.
Nov 05, 2008 | Medion md40298 Notebook
I am trying to upload a game on my computer but the computer is not even regestering the fact that I've put a disc in. I then inserted a Cd and nothing happened. Not sure what to do?
Try manually looking at the CD by going to the "My Computer" icon, and double-clicking the CD. If you see any files in there called setup.exe, double-click and go. It should startup. If the computer tells you that it can't read the cd, or to insert a cd, then it's possibly it's not the right format for your computer. Either it's a dvd that you can't read, or maybe it's the mac version and you hace a PC, or vice-versa?
Steven
Sep 17, 2008 | Computers & Internet
My Kodak Picture CD will not auto load
If your computer is operating with WINDOWS 95, WINDOWS 98, or WINDOWS NT 4.0 Systems, this CD contains software that automatically launches when you insert the CD. Getting Started:
Insert your Picture CD disc and wait for the software to load (it could take as long as 5 minutes, depending on your machine configuration, CD drive speed, and the number of images on the Picture CD).
Note: This loading process installs some Picture CD program files onto your hard drive. The KODAK Picture CD installer walks you through the steps. The final step may be to restart your computer. If so, be sure to restart to complete the installation.
After your computer has rebooted:
  1. Eject the Picture CD and re-insert it into the CD drive.
    The program should launch automatically.
  2. Click the magazine cover to turn to the Contents Page.
  3. Follow the links to read and do more with your digital photos.
If nothing happens after waiting for the Auto Play, you may need to manually start the Auto Play program. (Auto Play is a program that starts up the CD installation process the first time you use the CD.)
To manually start Auto Play:
  1. Right-click the My Computer icon.
  2. Select Properties from the pop-up menu.
  3. Click the Device Manager tab.
  4. Click the CD-ROM drive icon; click the "+" to view the CD-ROM drive information.
  5. Double-click the CD-ROM driver icon.
  6. Select Properties from the pop-up menu.
  7. Click Settings.
  8. Check Auto insert notification and click OK.
Note: This enables all CDs to automatically run any Auto Play software.
Sep 12, 2008 | Cameras
E-Machines eMachines Desktop PC Logo
1,740 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
