Question about Coleman Powermate Premium Plus 6250W Portable Generator
Generator is not working!
Just bought a new Coleman Powermate PM0525202.03 Electric Generator 2 weeks ago and the engine works but not the generator. It worked for about 6 days and then just died one night. What could be the problem?
  • 3 more comments
  • sherri464 Sep 28, 2008
    Yea, that is silly.... We tried everything... Even had an electrician check it, but couldn't find anything wrong. He's not a generator technician though. IT's gotta be something easy...
  • sherri464 Sep 29, 2008
    Wow... I'll try it and let you know... THat would be great if that's whole problem....
  • tkachance Oct 08, 2008
    I have the same problem with a 2500, used it a few times and then the generator won't work. It appears that the armiture is broke?
  • Anonymous Oct 09, 2008
    I had the same problem, after cheking the regulator in side the back cover I found the regulator circuit board fried and shorted-out the gen set. At this time I can not find replacement parts?
  • davenj Dec 23, 2008
    I had the same problem, after checking the regulator in side the back cover I found the regulator circuit board which WAS NOT FRIED but was DOA.
    Replaced works great &
    Best Solution for me was this....Thanks you all
    shoe_protech
    Problem Solver:
  • 8 Answers
Pramac has bought coleman powermate. to order parts call 1-800-445-1805. my guess is the printed curcuit boaed on the back of the gen head is bad if sparking the roter doen't fix it. i hav e had to change alot of these boards out.
Posted on Oct 15, 2008
Had same thing happen. If you read real closely in the manual there will be a brief paragraph about "re-exciting" the generator. Basically you take the plastic cover off that goes over the brushes on the back of the generator. Take a 12 volt car battery and apply voltage to them (mine is negative on left and positive on right). The generator has to be running when you do this and you also have to have something like a light plugged in. The light should begin to get brighter and brighter until the full output of the generator is working. I am not positive but I believe that this is caused by an "exciter" capacitor in the generator getting discharged. Again, if I have understood it correctly these generators need a charge to "jump start" them and it is done via a capacitor. Hope this helps, I know I was going nuts when mine did this and I had no idea what to do.
Posted on Sep 29, 2008
    Problem Solver:
  • 13 Answers
May sound silly but did you check the push button breakers on generator? let me know. troy
Posted on Sep 28, 2008
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Coleman Powermate 5000W Generator Stopped Suddenly
Sounds like you threw a valve push rod, or broke a rod
May 06, 2013 | Coleman Powermate Powermate 5000W...
Generator has been running steady for 2 weeks. It will not start now. It has spark, gas is good, oil is good. It is a 5000 coleman powermate electric generator. Did it die due to a 2 week running? It...
if it doesnt turn over how did you test the spark?
if i have read it wrong then always try a new spark plug, these can fail under compression but will spark happily outside the cylinder.
if it wont turn over then it could be siezed or dropped a valve.
Apr 23, 2011 | Coleman Powermate Powermate 5000W...
Coleman powermate 3750 watt brand new I started it
Check the oil level & try again to start many times until it became loose because the engine became stock up for long time not use.
Mar 12, 2009 | Coleman Powermate Powermate 5000W...
I have a coleman powermate 6200 that puts out no elecietety
Here is a link to a general solution I posted some time ago.
If that doesn't solve the problem let me know.
Regards,
Carl
Feb 22, 2009 | Coleman Powermate Premium Plus 6250W...
No electric power generated from my Coleman Powermate Maxa 5000W.
the gensets on coleman generators are definately nothing to brag about but i would start by checking the windings and make sure the brushes have a clean armature to ride on
Dec 18, 2008 | Coleman Powermate Powermate 5000W...
Brand new Generator not working
first check push button breakers on generator. let me know, troy
Sep 26, 2008 | Coleman Powermate Premium Plus 6250W...
Not a 6250W but a 6500W Coleman Powermate Black Max.
Call Pramac Co. at 770-218-5430. I get parts from them every week. A service center left holding the bag when Coleman/Powermate went out. Ken's Repair
Sep 15, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
644 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
