Question about Brother MFC 240C All-In-One InkJet Printer
Disassembling the Brother MFC 240c
I saw that you posted pictures on how to disassemble a Brother MFC 240c. I tried to print labels and some of them came off inside the printer and is now clogging the print head. I can see one of the labels but can't get to it. I can't figure out how to take the machine apart to get to it. Can you send me the disassembly photos since the ones on the site are too small to see.
Thanks! Chris cosmicbrewery@mac.com
  • hcplata Feb 05, 2009
    need disgrams to disassemble mfc240.
    thanks
SOURCE: Brother MFC-240C Change Unable 50
I also had this problem, your solution was spot-on, remove the top cover and control panel and re-seat the encoded strip. simple.
boy, are you guys good.
Posted on May 17, 2008
bowdo
  • 78 Answers
This is a common problem with this model. I usually occurs after a jam in which when removing the jam your fingers go too far under the cover towards the front and dislodge the encoder strip. Its the strip that sits just above the carriage and tells its location (ie where to print). 30 is obstruction of the carriage and the 50 is cant find the purge station. It is an easy operation to relocate it after pulling it appart but a very dificult task while it is still together and you will probally put the machine out of alignment. An easy operation for your local service centre and it shouldn't cost too much if out of warranty. One of my favourite faults to fix as its easy as.
Posted on Jan 23, 2008
  • 320 Answers
SOURCE: Brother MFC-235C print head removal
there are no instructions that you would understand and once the print head is clogged up, you can noy mannually clean it , it has to be replaced! sounds like you are using generic ink!
Posted on Jan 17, 2009
SOURCE: red ink nozzle on a brother mfc-240c is clogged
I found an article on how to unclog Brother inkjet nozzles on the InkMagic website. It worked for me.
http://www.inkmagic.com/Articles/Unclog%20nozzles%20on%20your%20Brother%20multifunction%20inkjet%20printer.htm
I'm also using their ink now. I'm a photographer so colour is really important to me. InkMagic ink is as close to the orginal Brother ink as I've found. The MFC-240 cartridges are here:
http://www.inkmagic.com/shopping/shopdisplayproducts.asp?id=1133&cat=Brother+MFC+240c
Hope this helps ... Dale
Posted on Apr 30, 2009
SOURCE: Brother MFC-620CN print head clogged
Open up amd release blue stay at bottom by pressing edges inward and pulling slightly forward. Remove the 4 screws, 2 small plastic covers and the earth screw. Pull out the ribbon connector near the USB plug. Unplug the 2 white and one red connectors, noting how the cables fit in. Fully open the lid and pop the scanner part off. Remove all the ink cartridges. Now using a flat screwdriver unclip the top of the base all the way round and lift off. The print head is now accessible. Rotate the white paper feed cogs to release the print head. Slide it all the way to the right and remove it by tilting the back edge upwards. You mow have access to the print head!!!!
Posted on Jun 02, 2009
How do I scan a printed page into my computor and convert it into a word doc
I am a Brother employee working for the software technical support department.
We have a solution for your issue posted on our solution site.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=200000000431
Description of Problem 100000000379 How do I use the Optical Character Recognition software? (OCR, Word Processor)
Brother Software Technical Support
Frequently Asked Questions
Jun 28, 2014 | Brother Multi-Function Center MFC-240C...
Disassemble Brother MFC 240C
I know this issue may have been resolved by you already, since I am now looking at this issue for you, however I am setting up the answer to help others that may have a similar problem in the future. You will need to reference a Brother servicing manual as it will show you how to remove the printer assembly and includes part numbers that you may need to replace. Hope this is helpful! You can find the manual at: ftp://ftp.brother.co.il/fax/MFC845.pdf
Dec 27, 2013 | Brother MFC 240C All-In-One InkJet Printer
I have a Brother mfc-240c - will not print yellow
The print head is clogged.If not unclogging with cleaning process may you try to clean manualy.You need to dissasembly the hole printer to remove the print head.Put it in hot water.If you don't have a technical skills, don't try anything.
If not help just buy new printer, because the new print head will cost you as much more.
Nov 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Jul 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
WHEN PRINTING CD-LABEL THE PRINTING IS OFF 1/4 INCH TO THE RIGHT
http://safemanuals.com/zearchres_134.php
i recommend the manual online.
Jan 22, 2009 | Brother MFC 240C All-In-One InkJet Printer
MFC 240C won't Print
have you tried to unplug the machine for twenty minutes then plug the machine back so that it will reboot?
Jan 12, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have windows vista and mybrother MFC-240C won't print, Says can't find printer?
first unplug ur usb cable from ur mfc-240c than deinstall all drivers of your printer
than reboot your system
than go here:
http://welcome.solutions.brother.com/bsc/public/midlink3.aspx?prod=mfc240c_all&lang=all&src=DOWNLOAD
click on your country flag and download the latest drivers for ur mfc-240c
install it
than when asked for ut plug in your usb cable from ur mfc-240c
the computer wil find your mfc-240c now whend asked for reboot than reboot
Dec 27, 2008 | Brother MFC 240C All-In-One InkJet Printer
Replacing the cart holder on a Brother MFC 240C
Somethings that have worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
2. The cartridge holder in the printer has an "electronic eye" (light sensor) of some type for each cartridge.
Some users have found that putting either permanent marker/sharpie/black PVC tape either on the area of the ink cartridge that goes near the sensor or alternatively putting tape over the sensor itself allows printing to occur.
The problem with this method is that the printer will no longer recognise near-empty cartridges and so will not warn you to replace them and so the print head may be damaged. This is said to work on LC57 icartridges used with the following models: DCP-330C, DCP-350C, DCP-540CN, DCP-560CN, FAX-2480C, MFC-240C, MFC-440CN, MFC-465CN, MFC-665CW, MFC-685CW, MFC-885CW, MFC-3360C, MFC-5460CN, MFC-5860CN.
Sep 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC 240C yellow
Common error of brother mfc/dcp printers.
Unfurtunately there is nothing what you can do.
Call brother hotline ask for service/guarantee repair.
Dec 06, 2007 | Brother Multi-Function Center MFC-240C...
Brother MFC 240C All-In-One InkJet Printer Logo
1,424 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
