Question about Insignia 19 in. Widescreen Flat-Panel LCD HDTV
Insignia Ns LCD-19 Turns on but no sound or picture
When I push the power button it blinks several times, but won't turn on, then I push it again and green light comes but there's no picture or sound for a LONG time, 30min - 1 hr, is different every time. Then when I get finally image and sound, I try to change the chanel and the TV marks that the channel changed but it stays in the same one..... Then after a LONG time you are able to change the channels like nothing.
So I did the channel Auto Scan and now is worst, Now after all this long process the only channel I can see is channel 12, tha's the only one that it found and it's connected to the cable, So I put another TV there and connected that one to the cable and it works just fine.... Is there a solution, what can I do??
  • VvSilenced_F Nov 04, 2008
    I have the same problem, it started an hour ago and yet my tv still hasnt turned on ive tried calling geek squad, ive tried insignia and no one is helping me.
  • pekin21 May 03, 2009
    when i turn on my sony 42 i get volume but no picture if i let it sit for awhile then turn it off the picture comes on sometimes i have to repeat this step several times.
  • Insignia Master
  • 10,073 Answers
Insignia is Best Buy's store brand which is an LG tv. The power supply board needs to be tested to see if all the voltages it produces are present. If they are, then look at replacing the main board.
TV Parts Universal TV Stands DLP Chips ShopJimmy will have the parts you need.
Posted on Mar 20, 2017
  • 11 Answers
SOURCE: insignia ns-lcd32
You can download the manuals from the Insignia website at:
Posted on Dec 08, 2008
  • 19396 Answers
SOURCE: 26" Insignia LCD TV will not power up. Green Light Blinks 1x
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on Apr 19, 2009
  • 57 Answers
SOURCE: Insignia TV no audio on non HD channels via HDMI cable.
have you tried to change the audio settings to HDMI on tv? when u have HDMI hookd up u have to change the audio to HDMI also
Posted on May 31, 2009
  • 2326 Answers
SOURCE: No picture, no sound, does light the insignia sign. Why?
In about 90% of the time the power supply is defective if the TV fails to power ON.
I repair these power supplies, if you need further assistance write to
Posted on Jun 29, 2009
  • 60 Answers
SOURCE: No digital channels
  1. Cable company sending something through the line. Also th insigna has a different tuner. Also can the insignia find the digital channels using an antenna?
Posted on Aug 23, 2009
Testimonial: "Thanks. I resolved it by removing a splitter from being in line with the cable itself."
Red flashing power light blinking
These flashes are fault indications, and are called blinking codes. By the number of flashes occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. If you wish to get more details, check the site linked here
Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 10, 2013 | Insignia NS-LCD47HD-09 47 in. LCD TV
Plugged in no power light or picture cord checks out good
replace power supply. multiple components died on power supply to many to replace and some to small for hand solder. cause cheaply made power supply
Apr 27, 2010 | Insignia NS-LCD19 19 in. LCD TV
Locate reset button on insignia ns-ltdvd 19-09, and the reset procedure to follow.
There is not an external reset button on this TV. To reset to factory defaults, enter the onscreen menu system and highlight the OPTION icon using the arrow keys. On the resulting screen, select "Restore Default." I would also recommend power-cycling (turn the TV off and unplug for several minutes) as part of your reset procedure. Additional details can be found in the owner's manual.
Mar 11, 2010 | Insignia NS-LTDVD19-09 LCD TV
No picture but have sound.
There are several possible causes for this problem, so it is best to have a technician diagnose and repair it. You may obtain service by carrying your TV in to the retailer of purchase.
Nov 16, 2009 | Insignia NS-LCD19W-09 19 in. LCD TV
Insignia NS-LCD19 is not producing a picture
You might need to change the input on the TV. I'm almost certain that it will have a DVI and Coaxial input among others.
Check the monitor for an input button or pull up the menu and see if there is different input selector.
Oct 13, 2009 | Insignia NS-LCD19 19 in. LCD TV
Picture won't come up
Insignia is Best Buy's house brand. If it's still under warranty, contact Best Buy. If not, find an electronic repair shop you think you can trust and take it in. There is absolutely nothing you (unless you're an electronics technician) can do to fix it. I know that's not what you wanted to hear, but, that's the way life is now.
Aug 21, 2009 | Insignia NS-L42Q-10A LCD TV
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Insignia 19 in. Widescreen Flat-Panel LCD HDTV Logo
272 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
