Question about Belkin (F5D7231-4) Wireless Router
Port for ward for belkin wireless router
I can not find the utorrent in the list or wot it is named as.
  • Belkin Master
  • 4,338 Answers
Posted on Sep 26, 2008
Need find out how portforward can you tell me how udp and tcp ports open
Here is the solution to help you out to do the port forwarding as you wished sir..
2wire-gateway-1921681254-300x234.png Once you have accessed your default gateway screen for your router, you will then want to click on the firewall tab at the top of the screen. After the firewall summary screen opens, you will then click on the firewall settings tabs to begin setting up an open port on your 2wire dsl router.
2wire-firewall-300x234.png Once the firewall setting screen opens you can then add an open port to your specific pc. Under step 2 you will see a list of predefined applications that have already been created for certain video games, servers and telephony (VoIP) services. Since in my example we are opening a port for Utorrent, we are going to manually configure port forwarding for one of my pc's. To be opening a port for Utorrent, click on "add new user-defined application" you can find the link just below the list on the left side of the screen.
2wire-edit-firewall-settings-300x234.png Once you click on add new user-defined application, you should have a window that resembles the one below. Within this window you should now be able to enter a name for the application that you are opening a port for. Underneath the application name, you know have the choice of either tcp or udp, and then you would enter a port number or a port range that you want to open up.
2wire-add-user-definition-300x234.png For security reasons, you should only open one port, unless the application specifies otherwise. The more ports that you have open on you router, the more doorways you open for hackers and viruses to enter your home network. Since we are opening a port for Utorrent, you are going to want to click on the tcp box and then enter the port number that Utorrent gives you, in my example I am opening up port number 51225. After you have entered you port number, click the add definition button. Once you have added the definition, you are going to then click on the back button.
2wire-utorrent-open-tcp-port-300x234.png After you have clicked the back button, you should now be at the edit firewall settings screen. All you have to do now is select your computer from the list that is listed After you have selected the computer that Utorrent will be hosted on, all you have to do is find the recently created user defined definition from the list under number 2. After you have located the Utorrent port forwarding application simply click on the add button, which should assign the Utorrent port forwarding application to your computer. After you have completed the above steps, you should be all set; now your Utorrent program should download and upload at a faster speed.
I have used Uttorent as an Example for you to have an idea how to do the work.. if you still have any problems or question just send a message i will get to you as soon as possible..
If you like the answer and it helped you please like the answer, it will be a great help.. Thanks
Jun 01, 2011 | 2wire (2701HG-B) Wireless Router
How do i turn off my security for my belkin wifi?
Open INTERNET EXPLORER and. (In the URL address field), enter the IP address for your wireless router ( the DEFAULT GATEWAY. This information should be contained in your router's manual. If you cannot find it, enter "198.168.1.1" as the address. This is usually the default IP address for most routers.do not type "www" just the number
Enter the username and password for your router. This should also be supplied in the router's manual. If you don't have this information, go to routerpasswords.com and find the brand and model of your router. This site lists the default login information for most wireless routers you can try "ADMIN" for user name and "PASSWORD" for passsword.
You should now be able to see your wireless router settings. You can configure your network ports, as well as SSID (wireless network name) and passwords.
Jan 17, 2011 | Belkin (F5D8231-4) Wireless Router...
My wireless adapter light is green, yet i cant connect to xbox live!
first check whether the gaming ports for xbox have been forwarded in the belkin router or not....if not do it first....if you dont know the port numbers call xbox support and get the list of port numbers to be forwarded....
then enable DMZ for the ip address of XBOX in belkin router...
then enable UPNP in belkin router....
atlast Disable firewall in belkin router.... your XBOX will go online and GET UPDATE..... you can call belkin tech support of your country to assist you to forward ports for XBOX in belkin router... if you reside in USA/Newzealand/Australia/Canada you can call this toll free 1800 2 BELKIN(235546)...... or you can call my personal mobile... Im from India country code +91 Mobile number 9003593572
Apr 08, 2010 | Microsoft Wireless Network Adapter Xbox...
How to port forward for microtorrent on belkin n1 vision
Here is a good walk-through how to set up utorrent on your router.
Enjoy!
PS: Make sure that utorrent is not blocked by your Windows firewall!
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jul 12, 2009 | Belkin N1 Vision Router
Weird problem. IE works, but other internet-using programs don't
The firewall is turned on on you router and can be disabled by changing the firewall settings on your router. utorrent and online games have to use ports for incomming and outgoing data transfer and should be listed as exceptions on your router. go into utorrent options and check what port is being used and do the same for your brothers game if you want to keep the rest of the ports blocked from potential attacks.
Feb 26, 2009 | D-Link DI 514 Wireless Router (DI-514)
Setting up port forwarding: belkin wireless g plus mimo router
candice,
you can go to this links click here. Select the model of your belkin router and it will give you a guide on how to enalbe port for warding.
Aug 01, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Downloading music from utorrent.com - port is blocked
hi i went through ur problem ....i am really glad to assit u with this issue ...If u hav got the port number for the utorrent website go on with the following steps:
Step 1: Connect modem>>belkin>>computer
Step 2: On the computer open the browser page and type http://192.168.2.1
Step 3: Towards the left corner check for virtual servers under firewall
Step 4: U will hav 20 check boxes
Step 5: Check the first enable box and enter ur port number and the type either tcp/udp
Step 6: Private port and the inbound port are the same
Step 7: Disable firewall also
I hope that this would surely help u out
May 20, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Help
There's a possibility that torrent is being block by the router where your computer is connected to , if internet is working on this computer and torrent is the only one not working you need to open the port for torrent on your router....
Apr 28, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Cant get decent speeds from u torrent
I recommend checking out http://portforward.com/english/routers/port_forwarding/Belkin/F5D7230-4/eMule.htm
This is a great tutorial on configuring port forwarding on your particular router. This example is for emule but it will be very similar to uTorrent. You will want to determine what port uTorrent is configured to send data on and use that accordingly.
Jacob
Mar 18, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D7231-4) Wireless Router Logo
32 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
