Question about Avermedia AVerTV GO 007 Plus/FM Plus (MTVGOFMPS) Video Capture
AverMadia GO 007 TV card does not initialize with 2Gb of RAM
I have installed 2 x 1Gb DDR I 400MHz RAM instead of the old 512 (266MHz) set-up I had.
Now the TV card fails to initaliza on start-up.
Could it be related to the RAM upgrade? The enlarged address range? Speed? What else? Could it be that the TV card decided to croack right now?
  • tsvisi Sep 29, 2008
    1. I was trying to avoid reinstalling the windows at the time. However it was long overdue so I did it anyway.
    2. I them replace the new 2Gb RAM with the old 512Mb. The problem disappeared. I will seek now RAM installation tips.
    3. Thanks anyway.
  • 158 Answers
Remove the tv card and put it another pci slot and start your computer if again its fail then reinstall your windows
Posted on Sep 26, 2008
Mercury PVCLE 266M L is support DDR 400MHz RAM?
Memory Support
♦ Two DIMM sockets for DDR memory modules
♦ Supports 200/266MHz DDR memory bus
♦ Maximum installed memory is 2GB
There you have it. I'm sorry but that motherboard does not support 400 MHz.
Hope that helps, give me thumbs!
Aug 23, 2010 | Mercury PVCLE266 Motherboard
Emachine 4250 wont boot gives 3 beeps
beeps indicate a hardware fault, go to the manufactures sight to determine the nature of the fault
Jan 25, 2010 | Computers & Internet
I have a intel 845gvsr board, want to replace a Ram. What type of RAM is suitable for this board?
Your Intel D845GVSR has,
1. Two ram slots.
2.Maximum Amount of ram is 1GB for EACH ram slot.
3.Maximum TOTAL Amount is 2GB, (1GB in each ram slot)
4.Uses DDR Sdram at 400MHz, (PC3200), OR
DDR Sdram at 533MHz, (PC4200)
This is an example of DDR Sdram at 400MHz, (PC3200),
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1354&name=PC3200-DDR-Dual-Channel-Memory&Nav=|c:1352|&Sort=0&Recs=10
(Not advertising for this website. There are many places to buy ram memory)
512MB + 512MB = 1024MB, or also stated as 1GB
1024MB = 1GB
Nov 13, 2009 | Intel D845GVSR Motherboard
Is their a special make of memory card, ie: ddr
According to: http://www.shopping.com/xPF-VIA-MB-FOXCONN-VIA-KM400A-400M01-G-6L-R
this motherboard has 2 slots for DDR (184pin) RAM,
and supports a maximum of 1GB of RAM per slot.
Note that DDR RAM comes in 3 speeds: DDR266 (slowest), DDR333, and DDR400 (fastest).
Buy the fastest RAM -- if the motherboard cannot run the RAM at "full" speed, the RAM will automatically slow itself down to a speed that the motherboard will support.
Sep 15, 2009 | Foxconn 400M01-G-6L Motherboard
RAM Upgrade
let them install it for you. Go for DDR2 667. If it works, gret, if it doesn't scale down... But DDR2, and DDR 400 aren't nearly the same, they won't fit onto the same system, as their pin configs are different.
If the DDR2 doesn't fit, you'll have to go for the more expensive DDR 400.
Jan 05, 2009 | Intel Computers & Internet
Intel D845GBV Motherboard RAM
You can use only DDR 266Mhz dimms maximum upto 2 GB. i.e. one DIMMS of 266Mhz of 2GB or two of 1GB each. For more details read bellow:
System Memory Features
  • The D845GBV board provide the following memory features:
  • Two DIMM sockets supporting 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with gold-plated contacts
    Unbuffered non-ECC DIMMs only
    Maximum total system memory: 2 GB; minimum total system memory: 64 MB
    Serial Presence Detect (SPD) DIMMs only
    Suspend to RAM
  • CAUTION:
    Do not use ECC DIMMs with the D845GBV board. Using ECC DIMMs could damage the Desktop Board.
For more details click here.
Thanks
Iqbal
Apr 01, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Its about the memory card
The board supports upto 4 GB RAM. PC3200 RAM is supported.
1. Reset CMOS settings by CMOS jumper.
2. Try updating BIOS of your motherboard from :
http://support.asus.com/download/download_item.aspx?product=1&model=P5GL-MX
Best of Luck,
rajesh_im
Feb 13, 2008 | ASUS P5GL-MX Motherboard
RAM upgrate
you can upgrade to a max of 2gb on that board. These are your 1gb options: 1GB PC2700 333MHz DDR Memory, 1GB PC2100 266MHz DDR Memory, and 1GB PC3200 400MHz Non-ECC Unbuffered 184-pin DDR DIMM Memory. Install a set of any of these and your off and running.
Dec 22, 2007 | FIC P4M-800T Motherboard
Avermedia AVerTV GO 007 Plus/FM Plus (MTVGOFMPS) Video Capture Logo
407 people viewed this question
Top Avermedia Televison & Video Experts
Alun Cox
Are you an Avermedia Televison and Video Expert? Answer questions, earn points and help others
