Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Everything freezing in vegetable and Custom Cool compartment
We bought our GE profile sid by side stainless steel refrig 4 years ago and about 3 months ago everything keeps freezing in the vegetable and the custom cool compartment. Even when we turn the temperature up the the Custom Cool it keeps freezing every thing so now we can not use those two compartments unless we want them to be frozen.
I came home the other day to find some of the items even on the door on the bottom shelve frozen. What do you think is wrong?
Cathy M
  • 2 more comments
  • annkon Oct 15, 2008
    Same problem -- stuff keeps freezing in the vegetable bin. The fridge will not hold a constant temp...even when try to adjust the freezer temp to compensate.
  • cmonta Oct 31, 2008
    We have tired that. We have even tried to turn of the custom cool compartment so we could use it just for normal use but again every time we set the temp to have it where there is no set chilling or thwing, it still freezes everything.
    cat
  • Anonymous Mar 17, 2014
    Kitchenaid double-door built in fridge seem to leaking oil from the back bottom. Is leaking on the slab onto the front porch of house. So far - things are working. Have found a couple of vegetables frozen! Please advise!
  • Anonymous Mar 20, 2014
    In the vegetable compartments (two lower one)temp to low ,every thing getting freeze .Upper part is fine
Them you have a broken damper that lets the air in and closes when temp has reach you need call a tech if you dont know how to repl the damper
Posted on Nov 01, 2008
  • 120 Answers
You have a temp setting above those shelves left side has a porkshop and left side has a carrot i belive set to to the left side to vegies and see if it helps if still all freezes the you have a broken damper on top that letts air in when it does not needed
Posted on Oct 31, 2008
The custom cool bins on my ge profile refrigerator freezes anything i put in it. The rest of the fridge is normal temporarture.
Did you ever find a fix for this? I have the same problem, it even freezes items in the produce bin above the custom cool bin.
Dec 25, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Items in refrig are freezing when they're not supposed to.
thermostat has failed i'd say..its not turning off at the requested temp.
Jul 24, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
GE Profile french door refrig not cooling but freezer is cold
your damper vent door is not opening to let the freezers cold air in to the refrigerator compartment,its located between the refrige and freezer,also make sure the evaporator fans are running to move the cold air
May 16, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
My GE Profile Performer refrigerator is freezing fruits and veget
PUT THE REF. ON 5 AND SET THE
FREEZER ON 2 1/2 AND SEE IF THIS WORKS
Apr 23, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
Vegetable and fruit crisper drawers freezing foods
You have a defective thermistor and damper control in the fresh food or a bad control board.
Check the thermistor first.
Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
Feb 21, 2009 | GE PSS25SGN Side by Side Refrigerator
Fan not working. Turbo cool reads error
Verify you have voltage at your fan. If you have voltage and the fan is not running then it will need to be replaced.
Feb 17, 2009 | GE Profile Arctica Stainless Steel Top...
No water from door dispenser
you have a frozen wtr line inside door turn it off for a day or 2 then try it again but this time palce a thermometer in frezeer and keep temps at 0 to 4 degrees if it drops below 0 then the line will freeze again
Oct 30, 2008 | GE Profile PSW26P Stainless Steel Side by...
Custom cool drawer excessivly cold
Check your thermostat setting it may be too cold try to set it higher. If your setting is ok then your thermostat or control is defective
Jan 13, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
380 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
