Question about Intel Motherboard
Computer my processor fan gets heated often,is there any solution?
  • ash_speed123
    ash_speed123 Sep 26, 2008
    i tried solution 1.it worked for me.i just cleaned the processor fan.there was lots of dust.and then i fixed the fan.now the sound is minimized and i can feel the change.thank you sir.
    Scholar:
  • 68 Answers
If your processor fan is heated often.....then the solution is.....you have to remove the fan first and clean it....as possible as you can.....then there is gel available in the computer shop...it is cheap only...you have to buy that and apply at the back of the processor fan.....instructions manual will be available with that gel....you can follow that....after applying the gel....fix the processor fan in the motherboard....you will find the difference.....i am a software engineer and i have experience in this....try this....it will work 100%.....
Posted on Sep 26, 2008
Attached cabinet fan with your system. after that if the problem will not solve please change the processor fan.ok bye
from bhim, bankura
Fan runs hard computer is slow hp compaq nc6000
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
- Shut down your computer at least two hour a day.
Hope these tips will help.
Jan 05, 2014 | HP Compaq 6735s Notebook
Its beeping and beeping and beeping
- Shut down your computer atleast two hour a day.
Aug 04, 2013 | Gigabyte GA-H61M-DS2 Motherboard
Bad processor on my hp compaq
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
The "CPU" or central processing unit, otherwise known simply as "the processor," is the primary "brain" of the computer.
Processors are very finely engineered components that are not repairable.
But replacing a failed processor is an option for the owner of any model Compaq Presario desktop computer.
Just check with HP/Compaq for the correct size and speed of processor for your motherboard before purchasing a replacement.
Turn off the computer and disconnect all cables.
Remove the cover.
Lay the computer down flat.
If there is a plastic hood covering an exhaust fan, remove it by pressing in on the indicated release tabs.
Examine the processor assembly.
The processor is a square chip that is covered by a metal heat sink with fins.
A fan will often be mounted on top of the heat sink; unplug its connection to the motherboard.
Two clips usually secure the heat sink assembly to the top of the processor.
Gently press down and slightly away on the flat end of a clip to release it.
Avoid using a screwdriver to release a clip a slip could scratch the motherboard.
Release the clips and gently remove the assembly.
The heat sink should separate, leaving the processor behind in the chip holder.
Clean the bottom of the heat sink.
Use a paper towel and a dab of solvent cleaner to remove the old thermal paste.
Set the clean heat sink aside.
Lift up the lever to unlock the old processor and remove it from the pin mount.
Insert the new processor chip.
Align the pins on the processor to the "cut off corner" or dot on the pin mount.
The processor should drop into the pin holes easily.
If the processor won't drop in easily, check the pin alignment.
Once the processor is inserted correctly, pull down the lever to lock in the chip.
Apply thermal paste to the bottom of the heat sink.
Apply enough paste to cover the area of the small gray rectangle on top of the processor.
Apply the paste with a spreader made from a piece of flexible plastic.
Spread the paste evenly to a thickness of two sheets of paper.
Check the heat sink mounting alignment and lower the heat sink onto the top of the processor.
Reinstall the mounting clips.
Reattach the heat sink fan to the motherboard if necessary.
Plug in the computer and monitor and boot.
If the machine won't boot or it emits warning "beeps," unplug the power and monitor, and troubleshoot your work until the computer boots successfully.
Shut down again and replace the exhaust fan hood.
Close up the computer and reboot.
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Hope this helps
Nov 11, 2012 | HP Compaq dc5100 Microtower PC Desktop
Pc suddenly powers off
that can be meaning if the processor is Not Supported with your motherboard,or the New Processor is not in good condition (can be Over Heat or damage).
Processor over heat or damage can be because the HEAT SINK (white or grey pasta at the top of processor) is not enaugh to cooling the processor or,the fan Proseccor is Dirty.
Jan 18, 2012 | Computers & Internet
Hi....how can i repair my processor it is very fast to heat..then my computer is shut down....but i try to change my board... it is sane problem
remove the processor heatsink and the processor clean the surface and apply a thin layer of heat sink compound and fix back the processor and also check the processor fan is working if the processor is fauly the processor heats up quickly and shutdown the computer
Aug 04, 2011 | Compaq Pentium II , 266 MHz Processor
Hp a6320in processor fan air flow direction?
Processor fans are setup to nearly always blow air inward onto the heat sink that sits on top of the processor. The heat sink pulls heat off of the processor and the processor fan blows air onto the heat sink to cool the heat sink so that it can pull more heat off the processor. However, read the following link to see that it probably doesn't matter that much which way you put it: http://www.overclock.net/faqs/14695-opinion-****-vs-blow-way-do.html
I would definitely set it up with the processor fan blowing inward onto the CPU. If you're experiencing overheating you can try switching it to see if that helps. Use a program such as SpeedFan to monitor your computer's temperatures.
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
Jun 01, 2011 | HP Compaq Fan Assembly
My fan is making so much noise but stops sometimes when i shake the system
you will have to dismantle the laptop remove the processor fan and clean the surface of the processor and the fan and apply a thin layer of heat sink compound and fix them tightly to the socket when the heat sink compound gets dried up the heat dissipation of the processor changes the thermostat in the processor fan send to increase the speed of the fan as the processor heat rises to cool the processor
May 01, 2011 | Computers & Internet
HP stops giving input to mnitor, have to reboot whole system.
that is problem of processor when processor is overheated it do so there is a white heat sink compound between processor and heatsink detach heat sink and apply new heat sink compound on the processor and look properly that heatsink is firmly fixed to processor or not .it may problem of fan if fan is rotating with low frequency then also it happens replace new fan the frequency of fan can be seen in setup
Apr 03, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
CPU Fan Doesn't Spin
First time that I had heard of a Sony Vaio VGC-LS1, so I had to go take a look. Pretty Cool!
I can only tell what I think from a tech standpoint of view on it's processor fan.
1.This computer is housed in a housing that incorporates the LCD screen also. It's set up just like a laptop, except the LCD screen is in the body. (Housing)
This means you not only have the heat of the processor when it's running, you also have the heat of the LCD screen.
Plus it's all packed into one tight 'box'.
Processors give off a lot of heat by themselves. If they aren't kept to a certain thermal limit, they will burn up. Literally! Like ON FIRE!
When a processor goes beyond that thermal limit, there is a built-in Fail Safe feature that turns the processor off.
In ANY computer I've seen, or worked on, the processor fan is constantly spinning. As the load for the processor increases, so does the heat given out by the processor, and the fan spins faster.
It is my contention that you have a bad processor fan. I would at least ask a tech in your area, and see if this is so.
If your computer is turning off on you while you are using it,
Apr 13, 2009 | Computers & Internet
Computer restart
yes the problem as you discussed was the processor's overheating. first, you need to open up the side cover of your casing then switch on check vissually if the fan of the processor is spinning if not then you need to replace this. and if this is spinning upon power on, the power supply will be checked its voltage.
Mar 25, 2008 | Computers & Internet
Intel Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
