Question about HP Computers & Internet
How do I connect a wireless mouse to my HP dv 2000 laptop - have tried changing on the control panel (mouse section) but will not let me
    Sergeant:
    Champion:
  • 200 Answers
Posted on Sep 26, 2008
How can I get my pointer to click on as it used to
Which operating system you could use the system restore but f its a hrdware fault the fault might return or not be fixed.
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
Click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
Click on >> control panel all control panel items mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp.
In windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
Change Touchpad Settings
Nearly every modern laptop computer comes with a touchpad for on-screen interaction. Depending on your operating system and touchpad driver versions, you can update the speed, sensitivity, tap speed and clicking functions of your computer's touch pad.
Accessing these settings and updating them to meet your needs is a quick and easy process with both the Microsoft Windows and Apple OS X operating systems.
Open the Control Panel by clicking the Windows Start button and selecting "Control Panel." Depending on your Windows configuration, this option may be located within the Start Menu's "Settings" sub-folder.
Double-click the Control Panel's "Mouse" icon.
Click the Touchpad tab.
This tab can have one of several names, depending on your computer manufacturer, your operating system version and your device drivers.
However, the most common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see any option resembling these, you may not be able adjust your laptop's touchpad settings.
Refer to the "Warnings" section if this applies to your computer. Locate the "Scrolling Settings" area within the touchpad properties tab.
Adjust the settings to meet your needs and then click "OK" to close the dialog boxes and confirm your changes. Change touchpad settings in Mac OS X
Click the Apple menu and then select "Preferences."
Click the "Keyboard & Mouse" icon.
Select the "Trackpad" option from the top of the Keyboard & Mouse dialog box.
Adjust the trackpad settings to meet your needs, and then close the dialog box to confirm your changes.
Enable a Mouse for a Laptop
Without the ability to drag and drop and point and click, a laptop computer is merely a desk ornament.
Most laptops are manufactured with a built-in mouse in the form of a touchpad.
If the touchpad fails or if you just prefer working with a mouse, it is easy to enable a mouse for use with your laptop.
Purchase a mouse that is compatible with your laptop.
You can find compatibility information on the manufacturer's website.
If the mouse is wireless, make sure that the USB receiver is included, or purchase it separately. The mouse will not function without the receiver.
Insert the batteries in the mouse if you are installing a wireless mouse.
The battery compartment is generally located on the bottom of the mouse.
Connect the USB mouse to the USB port on the computer.
If you are using a wireless mouse, connect the USB wireless receiver to the USB port.
Turn the computer off and then on again if you are enabling a standard mouse with a wire.
This will instruct the computer to run the "new hardware" wizard, which will walk you through the installation of the mouse, and your mouse will be enabled.
Turn the wireless mouse over, and locate a small indentation with a button.
You may need to use the tip of a pencil or pen to depress this button.
Simultaneously press the button on the mouse and the small button on the USB receiver.
This will initiate communication between the mouse and the receiver.
Hold the buttons down for about 5 to 10 seconds until the light on the mouse comes on.
Test the connection by moving the mouse.
If the cursor moves, you have successfully enabled the mouse.
If not, check that you have the batteries installed.
Try pressing the buttons independently of one another.
Press the button on the receiver until the light blinks and release it.
Press the button on the bottom of the mouse until the light on the mouse is lit.
This should enable your wireless mouse.
sign up
http://ftp.pisd.edu/guide/wireless-keyboard/wireless-keyboard.pdf
Nov 19, 2013 | eMachines E Machines E525 Laptop Computers
Hp pavillion dv 2000 manual wireless switch not working
start >> control panel >> network and sharing center >> manage adopter settings "on the left side " >> double click on the wireless network connection
Dec 13, 2012 | HP Pavilion dv2000t 14.1" Notebook Laptop...
My HP wireless mouse all of a sudden stopped working (usb connection to my laptop.) I did change the batterie. Do you have any idea what is going on?
Try to completely shutdown your computer when you connect it and turn your laptop back on once the pc is already booted back up switch on the mouse...
Mar 19, 2010 | HP Wireless Optical Mouse
I am having problems connecting to wireless with my TI PCI-1420 Cardbus Controller on my Dell Latitude C510 after I reinstalled Windows XP. It is acting like there is no wireless adapters at all.
You need Service Pack 2 or above to use wireless on XP. I have always hated this problem and feel your frustration.
You will need to either hook your computer up on a wired connection to get the service pack or download it on another computer and transfer it by some type of removable media (CD, floppy).
Service Pack 2 download link:
http://www.microsoft.com/DOWNLOADS/details.aspx?displaylang=en&FamilyID=049c9dbe-3b8e-4f30-8245-9e368d3cdb5a
Oct 19, 2009 | HP Compaq 1701 17" Flat Panel LCD Monitor
The right click stopped working
have you replaced the mouse ????
If it is a laptop try putting an external mouse on it and see if the right click will work.
Hope this helps
Jul 28, 2009 | HP Wireless Optical Mouse
Mouse moves, click and drag by itself
That sounds a lot like someone has remote access to your computer. Try changing your Firewall settings or try to get a different IP address. Careful messing around with the IP though, it's easy to create a problem when doing that.
Jul 08, 2009 | Microsoft 2000 Wireless RF Optical Mouse
Left mouse button on touch pad not working
have u tried to check it on the control panel/mouse options.
if its not working though i guess the have reason about that.
Dec 30, 2008 | HP Pavilion dv4000 Notebook
Wireless mouse intermittent
try going into your control panel, go mouse/ settings change your mouse settings and get some air for computers clean everything on the mouse
May 18, 2017 | HP Wireless Optical Mouse
Wireless mouse KU916AA won't connect to our computer, this was working, the computer is only 3 weeks old
My new wireless mouse KU916AA won't connect to my HP Pavilion dv 2000. OS is Vista
Nov 11, 2008 | Computers & Internet
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
