Question about Nikon D200 Body Only Digital Camera
Can not format card for Nikon d200
Nikon d200 refuses to format the CF card. I tried to format one of my CF cards on the PC but when I put it in the camera I get the message that it need to be formatted and when I do it, it's not showing me the remaining shots but only "For". It never happened before.
    New Friend:
Is you camera plugged into you computer. If so, you cannot format the card from the camera, unless it is unplugged. This just happened to me (I was about to look for a bent pin). Unplugging solved the problem.
Posted on Jan 27, 2014
bmwrider
  • 215 Answers
SOURCE: CF Error - Card cannot be used
Your problem sounds as if there's a bent pin in the CF card holder inside the camera. To fix it you will have to be very careful with a long blade fine screwdriver. Remember you'll have to straighten it in one go. If you bend them twice you can bet they'll break. A powerfull light to see the bottom where the pins are is needed too. If you're not willing to do the job yourself there's a guy on Ebay USA who straightens them. BMW
Posted on Jul 04, 2006
Inky
  • 691 Answers
SOURCE: Camera read CF card, but cannot see on USB or other media
You can connect the camera to the computer via a USB cable and use the camera as the card reader. It will show up as a mass storage device. You should then be able to copy the images to your PC and format the card once recovered.
Posted on Sep 17, 2007
  • 33 Answers
SOURCE: nikon d70 firmware version 2.0
From your question it isn't clear whether or not you are formatting the card in the camera.  Is this how you are formatting it?  If not, you should try doing just that.
Do not use a computer to format the cards for your camera.  In the future, use only the camera's own formatting and do it after every time you transfer your images to your computer.  In case you don't know how to format the card with the camera, let me know and I will explain it.
Posted on Feb 03, 2008
mackcamera
  • 33 Answers
SOURCE: Can a SDHC card be used with a CF card adapter in Nikon D70s?
You would have to get an SDHC to CF adapter which could be pricey and they are hard to come by.
Posted on Dec 31, 2008
t00nz
  • 4738 Answers
SOURCE: CF Card is not formatting. When I try to format
Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, don't fret. Although professional repair would be more costly than the value of the camera, there is a very good chance that you can repair this yourself. Please see the following: http://camerarepair.blogspot.com/2009/06/fixing-compact-flash-memory-card-error.html
Posted on Jul 19, 2009
My nikon D200 shows CHA whenever I insert a CF card? How can I fix it? It shows that error even I use a different card.
Dear Sir e_jamandre, probably the connector memory card has one or more bent pins or cracked solder.
The worst thing would be that the memory compression circuit is damaged.
Greetings
Feb 11, 2011 | Nikon D200 Body Only Digital Camera
My Nikon D2oo is not working with Extreme 111 Compact flash cards that I just had the camera Format. There is an burn oder coming from either the camera or card.Wanting to put card not formatted with...
Hello, and thanks for using FixYa.
Please if the card contains any important pictures, connect it to a computer and copy them to the computer if they are not backed up. Then put the card in the camera and format the card in the camera, then you can connect it back to the computer, put those pictures in there and then the card back into the camera if that is what you wanted to do.
Note that the camera might not show your pictures, unless they are named the same way as original pictures taken with the camera.
Oct 22, 2010 | Nikon D200 Body Only Digital Camera
Nikon 4300 CF Card Erro
The Nikon Coolpix 4300 only supports the FAT16 filesystem, so it can only support a 2GB partition. To support 4GB you need a FAT32 filesystem.
Put the card in a CF writer and attached to a PC or Mac. Partition 2x2GB partitions, then format them as FAT16. Now put it into the Coolpix 4300 and it should work.
Jul 29, 2009 | Nikon Coolpix 4300 Digital Camera
Nikon D200 - problems formatting card
To use the two format buttons:
Press the "trashcan" format button and hold it. Then press the "mode" format button and hold it. Hold for approx 3~4 seconds. The screen will go blank and display "For" and the number of shots taken on the card.
Release both buttons. Then press the "trashcan" again followed by the format button. The screen will go back to normal, except the number of shots indicator, it will display "For". In a few seconds, your card will be formatted.
Although this may not solve your problem, you may have bad CF Card.
This is normal. Happens all the time.
Try another card. It should format fine. If it doesnt, take your camera to an authorized dealer/repair shop for maint.
Jun 27, 2009 | Nikon D200 Digital Camera
Format problems. every time I try to format the
Sound like a damaged card, can you try another card in the camera?
My D80 did this once and the card would work in other cameras but not the D80 again.
Jun 27, 2009 | Nikon D200 Digital Camera with 18-200mm...
CF light stays on, cards come out unreadable by computer
You may need to have your camera driver and software reinstalled. It seems that the internal writer capabilities are corrupted.
This is evident if each card you use ends up corrupted or unreadable, but the rest of the camera operates normal.
May 06, 2009 | Nikon D200 Digital Camera with 18-200mm...
Problem with importing images to laptop(macbook) from nikond200 trough data cable
Camera must be in point-to-point USB mode for remote tethering to work.
In menu with wrench icon, make sure USB is set to "P" point-to-point.
Apr 12, 2008 | Nikon D200 Body Only Digital Camera
Error CHR in D70s
try another cf card first. if the trouble is still the same,  there is an internal malfunction in the unit, you need pro fix then.. [:0(
Oct 11, 2007 | Nikon D70s Body Only Digital Camera
Nikon D200 Body Only Digital Camera Logo
106 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
