Question about Lands Phones
Rca visys model 25450
We have 4 base units and two lines coming in. Is this phone set up to only have one base and use the handsets? If not, How do you transfer a incoming call on one line so another person on a different phone can pick it up?
  • duff351 Nov 20, 2008
    We also have the same problem but line 1 is always unavaiable
5 Suggested Answers
  • 7 Answers
SOURCE: RCA 25450RE3 - Incoming Call Ringer Setting
try turning ringer speaker volume down. if that does not work, then remove battery for 10-15 minutes and replace and try again.
Posted on Oct 12, 2007
eagle338
  • 4889 Answers
SOURCE: faulty phone
Sure sure i will help you out but please specify the model of your phone..If its GE then you will need to keep it connected to the power supply...If the power supply is cut it will br un-registered automatically..
Posted on Oct 30, 2007
SOURCE: No ring on handset
It may have lost the link to the base unit. Make a note of all the personal details, stored number, etc., then reset the handset. Do this by pressing the spanner button until the display changes, then press and hold the 'R' (delete) button until the handset resets. You'll have to set it up again, but at least it will link.
Spanner then 1 for ringtone, CID for volume.
Spanner then 2 for keypad bleep, 1=off, 2=on.
both cases press spanner to confirm changes.
Posted on Dec 04, 2007
SOURCE: RCA ViSYS 25450 cordless handset
handset is not receiving no dial tone
Posted on Jun 14, 2008
Quickly, return this Phone is you still have a chance, my small business used this phone for EXACLY 2 years, and now all lines are DEAD, NOT A SINGLE ONE WORKING. LINE ONE AND THREE HAVE NO DIAL TONE EXCEPT EXTREMELY LOUD STATICS. AND LINE 2 AND 4 ARE TOTALLY MUTED.
A lot of my customers are complaining about not being able to reach me in my office.
Posted on Sep 12, 2008
Instruction manual for RCA visys 6.0
Good morning,
How do I retrieve voicemail messages on this system?
Sep 08, 2014 | RCA ViSYS 25255RE2 2-Line DECT 6.0 Digital...
Compatability
can you tell me me the main problem? or your question?
Oct 12, 2007 | Lands Phones
Connecting to base
read the user manual as the handsets have to be registered by the base unit to be connected
the main base is the operational unit
the other bases are just cradles to hold the phone while it is being charged
May 03, 2017 | GE / Rca Visys 25424re1 4- Line Corded...
We have two newly purchased base units that can't pick up a line that has been placed on hold by the main reception desk phones. If you try to pick up a line that is open from these phones, they work fine....
You can't pick it up on another unit unless it is transferred from the original phone. I HATE that about this system. I have a question - we are trying to use a second base unit and are having a terrible time getting it to work right. Is it possible to use more than one base unit?
Jan 11, 2011 | RCA 25450 4-Line Extended Range Multi...
Do you have any dealer in new york area for repairing my rca 25450 phone system? The unit is out of guarantee and RCA do not make repair. In fact, how much should be the cost and if you consider appropiate...
Before you call a technician (which will probably cost as much as just replacing the phone) do some diagnostics to see if it's the phone, the phone wire or something in the office wiring.
Jun 15, 2010 | RCA 25450 4-Line Extended Range Multi...
Need to set time & date on the cordless. RCA Model No. H5401RE1-A
From page 14 of the manual: "The time cannot be set manually in the handset, only at the base. Any update to the base time will be automatically sent to the handset."
Apr 08, 2010 | RCA ViSYS 2-Line Speakerphone
Where can I buy battery 5-2670 for RCA odel 25450 base unit
You can buy a replacement batter at WalMart or Radio Shack.
Or here - http://www.batterycanada.com/RCA-cordless.htm
Note;
Thank you for posting your question on FixYa.com
We are helping people on a points system.
If the information provided here was at all helpful,
please be kind - rate well and close the post.
Thank you – and enjoy your day ;o)
Aug 05, 2009 | RCA 25450 4-Line Extended Range Multi...
Apr 10, 2008 | RCA 25450 4-Line Extended Range Multi...
Oct 12, 2007 | RCA H5450RE3 Accessory Handset For -25450...
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
