Question about Avaya Definity 6408D Corded Phone
How do you set automatic dial for this phone
I need to set the automatic dial for multiple line?
thanks
  • 3 Answers
If you have a definity pbx. i go in the gui interface on site administration and i just setup autodial next to lines i want. so when the user goes through the menu on the phone and select prog and when they select a line they can input whatever number they want on that line.
Posted on Nov 05, 2009
How do I set dial tone on line 3?
If you mean for line 3 to be selected when you pick up the handset, you need to program that as the "prime line" for that set.
Sep 30, 2015 | NorStar M7310 Corded Phone
HOW TO SEND A FAX
You can send a fax in a variety of ways. Using the control panel, you can send a black and white or color fax. You can also send a fax manually from an attached phone. This allows you to speak with the recipient before sending the fax.
To send a basic fax (single- or multiple-page black-and-white fax) by using the control panel.These features allow you to control the pace of your dialing. They are also useful when you want to use a calling card to charge the call and you have to respond to tone prompts while dialing. NOTE: If you need printed confirmation that your faxes were successfully sent, enable fax confirmation before sending any faxes. TIP: You can also send a fax manually from a phone or by using monitor dialing.
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed dial button to select a speed dial, or press Redial/Pause to redial the last number dialed.TIP: To add a pause in the fax number you are entering, press Redial/Pause, or press the Symbols (*) button repeatedly, until a dash (-) appears on the display. 3. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, it sends the document to the number you entered. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure your original is loaded print-side down on the glass, and then select Yes.TIP: If the recipient reports issues with the quality of the fax you sent, you can try changing the resolution or contrast of your fax.
Send a fax manually from a phone You can send a fax from a telephone on the same phone line if you prefer to use the keypad on your phone, instead of the keypad on the control panel of the device. You can do this by plugging in a phone into the 2-EXT port on the back of the device. When you send a fax manually, you can hear the dial tones, telephone prompts, or other sounds through the handset on your telephone. This makes it easy for you to use a calling card to send your fax. Depending on how the recipient has their fax machine set up, the recipient might answer the phone, or the fax machine might take the call. If a person answers the phone, you can speak with the recipient before sending the fax. If a fax machine answers the call, you can send the fax directly to the fax machine when you hear the fax tones from the receiving fax machine.
1. Load your originals. NOTE: This feature is not supported if you load your originals on the glass. You must load your originals in the document feeder tray. 2. Dial the number by using the keypad on the phone that is connected to the device. NOTE: Do not use the keypad on the control panel of the device when manually sending a fax. You must use the keypad on your phone to dial the recipient's number. 3. If the recipient answers the telephone, you can engage in a conversation before sending your fax. NOTE: If a fax machine answers the call, you will hear fax tones from the receiving fax machine. Proceed to the next step to transmit the fax. 4. When you are ready to send the fax, press START FAX Black or START FAX Color. NOTE: If prompted, select Send Fax, and then press START FAX Black or START FAX Color again. If you were speaking with the recipient before sending the fax, inform the recipient that they should press Start on their fax machine after they hear fax tones.
The telephone line is silent while the fax is transmitting. At this point, you can hang up the telephone. If you want to continue speaking with the recipient, remain on the line until the fax transmission is complete.
Send a fax using monitor dialing Monitor dialing allows you to dial a number from the control panel as you would dial a regular telephone. When you send a fax using monitor dialing, you can hear the dial tones, telephone prompts, or other sounds through the speakers on the device. This enables you to respond to prompts while dialing, as well as control the pace of your dialing. TIP: If you do not enter your calling card PIN fast enough, the device might start sending fax tones too soon and cause your PIN not to be recognized by the calling card service. If this is the case, you can create a speed dial entry to store the PIN for your calling card. NOTE: Make sure the volume is turned on, or you will not hear a dial tone. To send a fax using monitor dialing from the control panel
1. Load your originals. NOTE: If you are sending a multiple-page fax, you must load the originals print-side up in the document feeder tray. You cannot fax a multiple-page document from the glass. 2. Press START FAX Black or START FAX Color. • If the device detects an original loaded in the automatic document feeder, you will hear a dial tone. • If the device does not detect an original loaded in the automatic document feeder, the Fax from glass? prompt appears. Make sure that your original is loaded on the glass, and then select Yes. 3. When you hear the dial tone, enter the number by using the keypad on the control panel. 4. Follow any prompts that might occur. TIP: If you are using a calling card to send a fax and you have your calling card PIN stored as a speed dial, when prompted to enter your PIN, press Speed Dial or a one-touch speed dial button to select the speed dial entry where you have your PIN stored. Your fax is sent when the receiving fax machine answers.
Apr 01, 2011 | HP Officejet Pro L7680 All-In-One Printer
How to program co lines on a Panasonic tda50
I love open ended questions with multiple answers. The appearance of CO lines under buttons is done from the set itself and involves PROGRAM a button and dialing 0 + the line number 001-008 and STORE.
That makes the line appear. Ringing and other functions are done from System programming and is way beyond the scope of a free forum to answer.
Carl
Oct 08, 2010 | Panasonic KX-TDA50 Phone
I have the panasonic handset phone. I have three lines. When I pick up the phone it goes automatically to line 3. If I have a call holding on line 1 from the desk phone how do I get to line 1 on the...
A lot depends on what sytsem the 7896 is plugged into. If it happens to be a TA series, you'll go into station programming mode (menu 99) and dial 11. The change this makes is that you will have to dial "9" to get an outside line, or 53x to pick up lines 1,2,3 etc. To get back to idle line preference, dial 12, but a cordless phone should never be set to ILP because you can't call internally or page.
Carl
Sep 21, 2010 | Panasonic KX-TD7896 Cordless Phone
How do I unlock and lock my nokia 1209 keypad to avoid **** dialing?
hi,
press MENU then asterisk * and your phone will be locked..to unlocked it just repeat the procedure...if you want automatic locked of your phone do this....
*MENU
*SETTING
*PHONE SETTING
*KEYGUARD SETTINGS
*AUTOMATIC KEYGUARD
*you have option there ON and OFF ,select ON
now your phone is in automatic locked status ,even you forget to locked it ,it will be safe and avoid dialing...
i hope it will help you ,thanks for trusting fixya..
Jun 20, 2010 | Nokia Cell Phones
Panasonic KX-T7433 - INTERCOM
It's easy to brush past the Preferred Line Assignment command as it's just 11 :-). From the phone, press PROGRAM 99 and dial 1 and press INTERCOM and STORE. Press PROGRAM to exit. 11 is no line, 12 is idle line and 13 plus a 2 digit number is a specific line.
Carl
Sep 03, 2009 | Panasonic KX-T7456 Corded Phone
HP officejet all-in-one...keeps saying phone is off of the hook and will not give me a dial tone to fax. Is there a particular setting I need to check ?????
The very first thing to check with a fax machine is that the line itself is OK. The possibilities are much greater that there is a problem with the LINE and not the HP itself.
Hook up a regular telephone to the fax line, disconnecting anything else that may be on the line. If the telephone doesn't have a dial tone, call the phone company. If you DO have a dial tone, then maker sure that the phone line is connected to the correct port on the HP. There are two, usually. One is for the LINE and the other is for an EXTENSION (a phone that is daisy chained off the fax machine). If you have the LINE connected to the EXT port, it may give you this error.
If you have multiple items connected to the same phone line, try removing all of them but one regular phone, and see if you have a dial tone. If so, add the other items back, checking for a dial tone after each one. If one of them causes a lack of dial tone, replace or repair it.
The phone company may tell you that the problem lies in your inside wiring. I have seen that before. You can take your phone out to the telephone service box on the outside of the building. These usually have regular phone jacks in them. Disconnect the jack wire that runs into your house, and connect the regular telephone into the box itself. If you have a dial tone, then there is indeed a problem with the wiring in your building.
Jul 16, 2009 | HP Office Equipment & Supplies
Panasonic phone
This system will have to be programmed to allow line 1 to ring on that particular set. When you pick up line 1 now and it dials out it is dialing the last number you called from the phone.
May 28, 2009 | Panasonic KX-T7730 Corded Phone
How do I change the default line on our phones
restore the factory settings of your mobile byentering the security code of mobile.
Feb 04, 2009 | NorStar M7310 Corded Phone
I would like to forward all calls to my cell phone
Which system do you have? IP Office?
If so, at your phone, you need to set the number to forward to:
Press: *07*9xxxxxxxxxxx#
(where 9xxxxxxxxxxx, is the dial "9" access code to dial outand the number how you would dial it, followed by pound)
so for 555-111-2222...
*07*915551112222#
Once that is done, you need to turn forwarding on:
*01
To turn forwarding off:
*02
Upon entering the codes, you will get a double "blip" tone to confirm the acceptance of the code.
Dec 23, 2008 | Avaya 5400 Series 5410 Phone
Avaya Definity 6408D Corded Phone Logo
266 people viewed this question
Top Avaya Lands Phones Experts
george  peters
george peters
Oloyede Monsuru
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
