Question about HP Officejet Pro L7580 All-In-One InkJet Printer
HP OfficeJet Pro 7580 Scan Cover Installation
Error says scan cover installed wrong. Where do I find diagram to see how to install?
THE PROBLEM IS THE POOR DESIGN OF THE FEEDER TRAY INTO THE SLOTS. RESEAT THE TRAY AND THE ERROR GOES AWAY.
Posted on Jan 02, 2009
  • JMS6449 Jan 02, 2009
    TO ADD A LITTLE MORE TO THE ABOVE. THE TRAY WILL FALL OUT AND SLIGHTLY LIFT COVER. WHEN YOU CLOSE THE COVER THERE IS A DOUBLE DETENT(SNAP), YOU MUST BE SURE BOTH CLICKS ARE HEARD.
    Scholar:
  • 63 Answers
Hp links to the manuals for your printer. I would check to make sure you unlocked the scanner. make certain the scanner cable (is applicable) is connected in the rear properly.
Best Wishes
Here's the manuals for the printer you own.
http://h10032.www1.hp.com/ctg/Manual/c00862808.pdf
http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
Posted on Oct 31, 2008
Trying to install software for HP officejet L7680 on widows 7 system 64 bit. When installed printer and fax works well. When attempting to scan error message appears. "hp Imaging device not...
when installing the drivers turn off the antivirus software. download the latest drivers from HP, also down load the HP software on the main software page. this is the latest HP firmware and diagnostic firmware.
Jun 21, 2017 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One printer. copies come out black
Probably either the scan lamp or the sensor bar has failed. Do you see the scan lamp glowing under the cover when you try to scan a document? (Lift the edge of the cover slightly and watch the underside of the cover, you should see the reflection from a bright bar of light moving from one end of the original to the other. Do not look directly down into the light if it is on!)
Nov 25, 2011 | HP Officejet Pro L7680 All-In-One Printer
Scanner not found on computer
Try un-installing your 8500 related software, re-boot and re-install from disk.
If you don't have the installation disk go to:-
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3752459&lc=en&cc=uk&dlc=en&lang=en&cc=uk
and start by entering your operating system details
Nov 21, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My Officejet Pro 8500 won't scan, says "no scan options"
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 23, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
How to scan with hp officejet j4680
Please install the printer software and try to scan via the installed software from the computer. Or, start scan using scan button from printer; after installing software.
Regards,
Rizwan
Mar 02, 2010 | HP Officejet J4680 InkJet Printer
Want to scan from hp officejet pro 8500 to computor hp pavilion entertainment PC tx2000
There are 2 ways to scan from a HP AIO printer. This depends on your installation.
If you installed the full software set, you can press the PC Save/Scan to PC (each model the button is called different) button on the scanner. This will start the communication process and you follow the prompts on the screen.
If you didnt' install the full package from HP you can see if your printer is listed in the My Computer panel. Open my computer and look for the Scanner. double click it and it will open a option box, select how to scan then follow the prompts
Feb 11, 2010 | Computers & Internet
IseMY Hp all in one 4355 printer is unable to scan
The HP Officejet 4355 can print, scan, copy and fax.
You need to install the printer software to print and scan. Copy and faxing does not required software installation.
Regards,
Rizwan
Feb 11, 2010 | HP Officejet 4355 All-In-One InkJet...
When i want to scan at the time press Scan button on HP officejet 4255 all in one a message shows "you need to install or run software or device
Install and run HP solution Center given in the full installation of software, the scan button will work thereafter.
Sep 24, 2009 | HP OfficeJet 4255 All-In-One InkJet...
I want to use the scan and I get a "No Scan Options" message?
i think wrong installation of drivers
i hope i can solve your problem
Aug 26, 2009 | HP Officejet 6310 All-In-One InkJet...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
607 people viewed this question
Ben Johnson
