Question about Gateway MX6445 Notebook
DVD player won't recognize a disc, CD part works fine
The DVD part won't play a disc. I've tried several. The CD part seems to work fine.
Problem started with a disc skipping and sounding bad. When I switched discs it wouldn't read at all.
The CD part will read, install programs etc.
The troubleshooter says that the device is working properly. What do I do now?
Gwen
  • gbbeck2 Sep 29, 2008
    Would any one know: if the driver for this drive is corrupted would it cause the drive to mess up like this? If so, would it be possible to uninstall the drive, shut down, re-boot, let the hardware be found again and let the system install a fresh driver? I'm a tad nervous about doing that because I don't know if it would work, or if it would mess up my computer even more.
    Any ideas about the above?
    Thanks navidh! I'll probably end up doing that, but I want to explore all options.
  • 65 Answers
There might be problem with the DVD drive.... so better contact the manufacturer about this.. servicing might help it
Posted on Sep 26, 2008
I have a 2001 Honda Crv, the cd player keeps ejecting CDs before it has the chance to load them. The radio works fine, and I gave tried burnt and original disc CDs. Can anyone suggest a solution?
Are these CDs that you burned yourself? Older CD players won't recognize the audio file format of this kind of recording, only the established file format that typical retail CDs have used for years. In recent years, CD players have been developed to recognize more file types than just the old format; but with an older player like you have in your car, it wouldn't recognize what you were trying to play, as if you put a DVD in. It balks, and spits it out. You can burn CDs with the correct file format, you just need the appropriate software or file translator.
Apr 14, 2012 | Car Audio & Video
Drive won,t play discs and sometime won,t reconize that a disc is
If the "bad" disks work fine in some other DVD-player, then it's time to spend $40 and buy a new DVD-writer.
Or, if your current DVD-player is under the manufacturer's warranty, exercise the warranty, to get it repaired/replaced.
Dec 28, 2009 | Fantom Drives DVD-RAM Burner
No disc error video and audio cd works only dvd gets nodisc error
Did you try to test it and play another using another disc?
You may try to clean the optical lens of the unit using a optical disc cleaner available on any electronic shop, it seems that the drive lens is dirty and can't recognize the disc inserted.
Hope this helps.
micro
Jul 19, 2009 | Philips DVP3020 DVD Player
Disney dvd player wont play movies (dvd) but plays music (cd) fine
Might be the type of movie - some of them are only able to play "G" ratings. Try this: click <play> 1234 <play> It will likely unlock the dvd that is in and will begin to play. You will have to do the 'code' each time, or there's an unlock program you can purchase.
Aug 07, 2008 | Disney Princess DVD Player
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Sony Player
THAT AINT THE PROBLEM
OLDER CD PLAYERS REQUIRE A SLOW BURNT DISC
SIMPLY BURN AT A SLOW SPEED
1 x , 2x, 4x. 6x. might work 1 X and 2 x WILL FOR SURE
Nov 18, 2007 | Lite On LH-20A1H DVD RW Dual Layer Burner
SAMSUNG DVD R120 error EC:0207
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
Toshiba SD-K860 DVD Player wont load DVD's
Having the same problem. DVD player loads enough to identify it is a DVD or a CD, but won't actually start playing anything.
Oct 29, 2007 | Toshiba SD-K860 DVD Player
Gateway MX6445 Notebook Logo
184 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
