No sound from my speakers
Please help me I have power on my dell mms 5650 subwoofer.You can hear a click from
the speakers when turned on. Have hooked the subwoofer with speaker
to other working systems but still no sound.
  • katee333 May 11, 2010
    mine isn't getting power when plugged in
5Line spekar work but sobwoofer not work
Posted on Nov 29, 2013
  • 77 Answers
Connect the speaker cord to the socket on the tower properly and check for the sound mute
Posted on Apr 07, 2009
  • GOWDA ASSOCIATES Apr 07, 2009
    connect the speaker cord to the socket on the tower properly and check for the sound mute
What type of fuse is used in the subwoofer?
Hugo Sepulveda,
The subwoofer uses the T1.6L250V fuse. You can get this at your local hardware store.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Oct 25, 2015 | Dell Mms 5650 5.1 Surround Sound Home...
I have a Dell subwoofer that has 2sets of speakers terminals on it.the speaker itself is made by Samsung and the model number is MMS 5650.why is this speaker designed in this fashion
one set is for the subwoofer itself and the other is for the tweeters or the voice coil you will see this a lot in car audio just find which ones which and dont put a lot of power to tweeter/voice coil
Nov 29, 2013 | Audio Players & Recorders
Mms 5650 small amplifier ic number required please.......
Would you please give me more information, as the number of pins of the ic,? does it has just one screw above in the metal flange?
TDA7293 comes to my mind...let me know to help further..
Oct 05, 2013 | Dell Mms 5650 5.1 Surround Sound Home...
Dell Home Theater Speaker System MMS 5650, subwoofer not turning on...fuse NOT blown. Has turned on for a second and then goes back out. What is the problem??
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
:((appropriate speakers)): also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 05, 2011 | Dell 5650 Computer Speakers
My DELL MMS 5650 Subwoofer fuse keeps on blowing out. Any suggestions?
well you might want to see what the output on your computers sound card is if it is to high that would explain it or if you have the base set to high that would also make the fuse blow on it
Jun 05, 2011 | Dell 5650 Computer Speakers
Clicking sound from Dell Speakers
How "often" does it click?
Internet Explorer does a "click" everytime you access a new web-page -- turn your speakers up/down to increase/decrease the sound.
Apr 25, 2010 | Dell 5650 Computer Speakers
Rear Speaker delay
It will not be the length of the wires, as the signal travels at close to the speed of light!
If the connections to the speakers are bare wires the cause is probably that you have wired the speakers with opposing polarity. Check the wiring and ensure that positive (red) is wired to positive on the speakers.
The speaker cable should be marked in some way to indicate which core is which. It doesn't matter which core you use provided that you wire red to red and black to black, or whatever other colours your output and input have.
Apr 01, 2010 | Dell 5650 Computer Speakers
Looking for schematic diagram for Dell MMS 5650
MY DELL MODEL 5650 SPEAKER SMALL IC HAS BEEN DAMAGE KINDLY SEND THE IC NUMBER
Apr 26, 2008 | Dell 5650 Computer Speakers
Dell 5650 computer speakers
Similar situation happened with me ... on the back of the subwoofer is a fuse,it's a little round button that actually can come out. Maybe that just popped. try pulling it out and putting it back in.
Oct 28, 2007 | Dell 5650 Computer Speakers
488 people viewed this question
 Grubhead
Grubhead
