Question about GPS
How i can update my lg destinator v5.7.4.46 - GPS
A route cannot be calculated to your destination. Please check your routing preferences and try again. Appears on screen with old and new destinations and Post Codes.Can you help please?
It means that no roads/routes exist to drive to the destination you inputted, sorry just the messenger. Is your map software up to date, if not update it, that may be the issue.. I update mine every 4 or so months.
Nov 18, 2016 | GPS
Avic s1
hello sir,
Portable Smart GPS Navigation comes with 3.5-inch Touch Panel Display, 2GB Flash Memory, Bluetooth Wireless Technology, and Scroll Wheel
  • 2GB Flash Memory contains the map data of entire US and Canada
  • Just unpack and use it � no PC connection is needed for startup
  • Future map data updates will be available by SD card � just load into the built-in SD card slot and the update will begin
  • Quickly set a destination by address, zip code, destination history, and more
  • Search for a gas station, restaurant or coffee shop using the POI Search � destinations are sorted into categories for short-cut searches, or use the touch screen to type in the name.
thanks for allowing us to help you
Dec 30, 2007 | Pioneer AVIC-S1 GPS Receiver
How do I know how far a destination is
your GPS will tell you trip millage to destination before you move, after you put the address in. It will also update millage along the trip, and before turns
Feb 16, 2015 | Garmin nuvi GPS
My LG superdrive connot read disk and when click his icon he automaticall eject the tray plz help me
Hi There
It seems to me, and I may be wrong, that you are trying to burn a incorrect disk. If ou want to burn a CD, you have to select a CD as destination disk, and if you want to burn a DVD, you have to select a DVD as destination disk. If you try to burn a DVD but LG program is set to CD, it will eject the disk and wait for the correct disk.
It will also happen if you try to burn a 8.5Gb DVD but have a 4.7Gb DVD in the drive.
Hope this helps
Andre
Sep 08, 2011 | LG Computers & Internet
Gps is not updated with new places cant get to final destination
You need to get your device updated - or - settle for a place 'near by' your destination.
When we updated our GPS, the price was near $100.00. You may want to sell your device (e-bar or craigs list) and just get a new device.
Feb 13, 2010 | GPS
LG LN735 updates map
LG LN735 map is compatible with "Desitnator"
Destinator released a 2009.q3 map upgrade.
Not sure if I'm allow to post a link, but if you do a little search, I'm sure you'll be able to find the files.
To upload the files onto your LG LN735, you will need either ActiveSync for windows xp or Windows Mobile Device Center for Vista. (you can download these program for free).
Now just CUT and Paste the map folders off your GPS onto your computer (this way you have some sort of backup). The map folders are located "/residentflash/lge/lgenavi" on your GPS unit.
Now just copy and paste the new map files (Destinator 2009 q3)back onto your GPS. Be warned, this process will take over 3.5 hours.
Reboot your GPS, and enjoy.
Oct 24, 2009 | LG LN735 GPS
Cannot select scan to destination
To get scan options on your unit you need to update the destination list on HP Solution Center. Please perform the steps given below to populate the destination list.
Populate the destination list:
You must populate the destination list in HP Solution Center for the Scan To options on the unit. Follow these steps to populate the destination list.
NOTE: HP Solution Center is the software that came with the product. You must make sure the software is installed on the computer for all the product functions to work correctly. The software is also necessary for completing this procedure. Install HP Solution Center if it is not already installed.
  1. From HP Solution Center, select the appropriate product, and then click Settings.
  2. Click Scan Settings and Preferences.
  3. Click Scan to... Setup.
  4. Click the Destination List tab.
NOTE: It might take several minutes for the list to populate.
  1. Click each program to include on the Scan To list.
  2. Click the Add arrow. The program listing moves from the left side of the screen to the right.
  3. Click OK.
  4. Now Press scan button on your All-in-One and check whether the scan options are updated.
  5. If the scan options are still not updated then turn off and on your All-in-One and verify the results.
Sep 04, 2009 | HP Photosmart C5280 InkJet Printer
Create a MS Word Report
This from the Word Help files - search for Embed.
You can simply select an area in Excel copy it and paste it into your word document, but embedding allows the data in your Word document to be automatically updated as you change the figures in the Excel Worksheet.
From the Help pages:
You can insert objects (object: A table, chart, graphic, equation, or other form of information. Objects created in one application, for example spreadsheets, and linked or embedded in another application are OLE objects.) into a Microsoft Word document when you want to include information from files created in other Microsoft Office programs or in any program that supports linked objects (linked object: An object that is created in a source file and inserted into a destination file, while maintaining a connection between the two files. The linked object in the destination file can be updated when the source file is updated.) and embedded objects (embedded object: Information (object) contained in a source file and inserted into a destination file. Once embedded, the object becomes part of the destination file. Changes you make to the embedded object are reflected in the destination file.).
default.aspx?assetid=za060473201033 default.aspx?assetid=za060474651033 Embedded object
default.aspx?assetid=za060474661033 Linked object
default.aspx?assetid=za060474671033 Source file
For example, a monthly status report might contain information that is separately maintained in a Microsoft Excel worksheet. If you link (link: Used to insert a copy of information created in one program into a Microsoft Word document while maintaining a connection between the two files. When the information changes in the source file, the changes are reflected in the destination document.) the report to the worksheet, the data in the report can be updated whenever the source file (source file: The file that contains information that was used to create a linked or embedded object. When you update the information in the source file, you can also update the linked object in the destination file.) is updated. If you embed (embed: To insert information created in one program, such as a chart or an equation, into another program. After the object is embedded, the information becomes part of the document. Any changes you make to the object are reflected in the document.) the worksheet in the report, your report, or destination file (destination file: The file that a linked or embedded object is inserted into. The source file contains the information that is used to create the object. When you change information in a destination file, the information is not updated in the source file.), contains a static copy of the data.
default.aspx?assetid=za790050001033The differences between linked objects and embedded objects
The main differences between linked objects and embedded objects are where the data is stored and how you update the data after you place it in the destination file.
Linked objects When an object is linked, information is updated only if the source file is modified. Linked data is stored in the source file. The destination file stores only the location of the source file, and it displays a representation of the linked data. Use linked objects if file size is a consideration.
Linking is also useful when you want to include information that is maintained independently, such as data collected by a different department, and when you need to keep that information up-to-date in a Word document.
When you link to an Excel object, you can use the text and number formatting from Excel, or you can apply the formats supplied by Word. If you use the Word formats, you can preserve formatting when the data is updated. For example, you can change table layout, font size, and font color without losing those changes once the object in the source file is updated.
Embedded objects When you embed an object, information in the destination file doesn't change if you modify the source file. Embedded objects become part of the destination file and, once inserted, are no longer part of the source file.
Because the information is totally contained in one Word document, embedding is useful when you want to distribute an online version of your document to people who don't have access to independently maintained worksheets.
default.aspx?assetid=za790050001033Edit and update linked objects
To edit a linked object in your document, use the Links command on the Edit menu.
By default, linked objects update automatically. This means that Word updates the linked information every time you open the destination file or any time the source file changes when the destination file is open.
If you prefer, you can change a linked object's setting so that the linked object is updated only when you choose to manually update it.
To ensure that your document is always up-to-date, you can also update linked objects whenever you print the document.
To prevent updates, you can lock individual linked objects. When you lock a link, Word uses the last information available from the source file.
You can also permanently break the connection between a linked object and its source file.
default.aspx?assetid=za790050001033Edit embedded objects
To edit an embedded object, double-click it, and then make changes to it in the source program (source program: The program used to create a linked object or embedded object. To edit the object, you must have the source program installed on your computer.). If you don't have the source program, you can convert the embedded object to the file format of a program you do have.
Apr 13, 2008 | Microsoft Office Professional 2007 Full...
Destinator is not a valid Windows CE application
gps will not load said destinator.exe "destinator is not a valid windows CE application unit freezes up will not operate , no menu no nothing unit has a sd card could card be blank if so how can I get it reprogramed?...
Oct 27, 2007 | InVion GPS-7v1 GPS Receiver
GPS Logo
83 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
