Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Extension arm The extension arm will not pull all the way up from the holder and I cannot use it - is there a way to take this apart - or something that can be done to fix it?
  • 372 Answers
Try pulling wand up from hose with machine turned off.
Or are you saying that the wand & handle wont uclip from the body of the machine ?
http://dysonmanuals.llc.nu/
Posted on Sep 26, 2008
Motor stops and won't restart until a cool down
Bushings or bearings in the motor are no longer good, heat up as the motor turns and seize up.
They are probably replaceable but if the shafts are worn or there is other damage to the bearing/bushing holders then you'll have to replace that too and you might consider getting a whole new vacuum for the cost.
Of course, unplug it before attempting to take it apart.
Oct 08, 2016 | Vacuums
DC14 arm extension will not lock in place.
I WOULD CALL DYSON TO BRING IT IN THEY CHECK IT FOR FREE FOR YOU, AND WARRANTY IS USALLY 5 YEARS FROM PURCHASE.
https://www.dyson.com/support/warrantyterms.aspx
http://www.dyson.com/support/servicecenters.aspx
May 25, 2016 | Dyson DC14 All Floors Upright Vacuum...
How do I lock the dyson dc24 vacuum handle?
  • The handle/extension arm just pushes strait down and locks into place. The catch is at the same spot as the yellow button you push to release said arm/handle. See diagram below.
  • Hope this helps.
Oct 23, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
I have an upright bissell pro heat self propelled. I have had it for years and it has always worked wonderfully. Last time I was using it water started going everywhere. The self propel part is only...
If the top portion of the upright section is loose, there is a connector between the two parts that is also loose. No need to take it apart however beyond removing the black lower hose holder.
To remove the lower hose holder, just push in firmly on the tab that is the same color as the upright casing until you can pop the lower holder upward and off of the machine. Beneath the holder are four screw holes where you can tighten the upper and lower assemblies back together. This will reconnect the two connectors internally and take care of any power issue to the base.
Apr 02, 2011 | Bissell 1699 ProHeat Clear View Upright...
My daughter pulled to hard on the ceiling fan pulling out the chain. i have taken it off and apart, nothing appears to be broken but im trying to figure out how to put it together so it retracks, i...
Don't even bother to repair the pull chain switch, get a new one at KMart, HomeDepot or similar store for less than $2.
Two times I've repaired one, it comes apart when I need it the most.
Good Day! Don't forget to rate this post!!
Sep 09, 2010 | Vacuums
Hello. i only have one arm and am trying to figure out why my beater bar wont turn on my dyson dc14. the belt smells a little too. thanx, trixie
Sounds like the beater bar is frozen in place. This sometimes happens when the ends of the bar become stuck in the holders. The solution is to remove the beater bar and clean the small holders on each end removing any debris that has built up. Spray with a little WD40 and then manually rotate the beater brush around the holders until it is free, then replace. Be sure the belt is installed properly.
Sep 09, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
I can't get the top lid off my dyson dc17. It's
You need to get a long handled t-15 driver or a t-15 bit and a bit holder and extension for a 1/4" drive socket set (12" or longer extension) to get this apart. There are only something like 6 pcs in there and once you get it apart, cleaning it is very easy. Here's a good website on how to take it apart and put it back together. I have done this and it makes a difference. Be sure to sanitize everything once you have it apart. Takes out any funky smells.
May 14, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
How do you take the handle apart?
Take a box cutter blade or something razor thin and locate the 2 screw covers on the handle. Pry the two covers off and remove the 2 hex screws. Pull handle apart. Done. Might want to check your elbow down on the power nozzle before you rip apart that handle though. 4 out of 5 times, the problem is in the elbow.
Jul 10, 2008 | Electrolux Epic 6500 Vacuum
Kirby g5 vacuum
Either the cogged belt broke, or you will have to pull the transmission and see if something came apart. May have to replace the transmission.
Jun 01, 2008 | Kirby G5 Bagged Upright Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
180 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Dyson Solutions...
Dyson Solutions...
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
