Question about Panasonic KX-T7633 Corded Phone
Picking up calls while caller is leaving a voicemail
Hello there! Is there any way I can pick up the line on my phone while the caller is leaving a voicemail?
  • Elina1977 Oct 02, 2008
    didn't realize this was ebay
  • Panasonic Master
  • 2,460 Answers
Only if you turn on Live Call screening or executive override. Both of those options require some system programming and have some negative features.
Carl
Posted on Sep 26, 2008
  • Carl Navarro
    Carl Navarro Sep 29, 2008
    It's amazing that this solution rates a TFT. What are you looking for? You asked a question and got a valid response. On a TDA system there is LCS. If you ask your installer or check out the manual, you can get the steps to program it on your phone.
    There is no other option, so "thanks for trying" means you don't get any more answers.
    Carl
  • Carl Navarro
    Carl Navarro Oct 02, 2008
    It isn't ebay, so perhaps you can ask your next question there.
Voicemail rings busy and will not pick up incominig calls
Is this the Automated Attendant (AA) not picking up? If so, check your voicemail extensions (#505, Group 7). If this is for an extension, make sure a mailbox has been setup.
Jul 04, 2014 | Avaya Partner 34B Corded Phone
We have a Uniden DECT 6.0 series phone and voicemail service through AT&T. For some reason, the base answering system has been picking up calls, seemingly at random. Sometimes the base picks up, s
Hi Jessica,
I would suggest contacting Uniden rather than AT&T. I included their contact information below as well as 3 issues that may be going on here.
Uniden Technical Support
1.800.297.1023
M-F 8:30am-11:45pm CST & 2:30pm-4:45pm CST
Ask a Question: http://mycusthelp.net/UNIDEN/_cs/QuestionAsk.aspx?sSessionID=&
1. Are you getting messages? If not, the voicemail may have set to "Announce Only." This means the Answering system will answer the call, but will not allow callers to leave a message. If so, there may be an LED "A" lit up on your base. You can change this setting in the Answ setup --> record time.
2. Does it occur after a particular number of rings? You can set the voicemail to answer after 2, 4, or 6 rings. This may be the problem.
3. Does the phone ring at all? It is possible the phone is in Silent Mode. You can set silent mode to last anywhere between 1-9 hours or keep it on all the time. If it is set to a particular number of hours, the phone will exit silent mode automatically. If not, you need to hold # to deactivate it. I don't think you can set silent mode to turn on automatically on a schedule, but this is something you could ask Uniden about.
I hope that helps. Good Luck!
Jan 08, 2014 | Uniden D16602 Twin Cordless Phone
My answering machine won't pick up to external callers
Try Googling (Panasonic)(KX-T7456)(manual) without parens to get instructions.
Jun 05, 2017 | Panasonic KX-T7456 Corded Phone
As the receptionist I take calls and then transfer them to the person the caller disires to speak with. For example, if I am on a call and the person I am speaking with would like to speak with my boss, I...
A couple of things, but first. When you TRANSFER a call to your boss using the transfer button, he key to getting rid of the call is to hang up. But that's not your problem. When we install voice mail systems, we reserve 3 buttons; one for VM TRANSFER, one for 2 WAY TRANSFER, and one for VM RECORD. It's easier to link you to the OM of a TDA system than explain it, so here's the link http://www.public.carl.airpost.net/Pana/TDA/200_TDA_OM_06-121.pdf
Pdf page 170 will give you the table for setting up your 94,91 and 90 codes for the above features.
Basically, you press PROGRAM, the button, and dial, for example, 94 500 SAVE to store the VMT . You use it by pressing that button while you on the call (no hold) and either dial your boss' extension or press his DSS button. If you use the 2-way transfer, you can actually put his number under one button and carry on a 2-way conversation with the outside party. Kind of like you would do with the old 'pink slip' messages.
Carl
Mar 16, 2011 | Panasonic KX-T7630 Corded Phone
All the calls we recieve in the office go through me. I greet the caller and then transfer them to the person they want to speak with. When I transfer a call, let's say to my boss, my boss will pick up...
Haven't you solved this yet? When we install a system, we reserve THREE buttons for voice mail functions. One is VM Transfer, one is 2 Way Transfer, and one is VM Record. In order you pick 3 buttons press PROGRAM one of the buttons and dial in order 94 500 STORE 01 500 STORE and 90 500 STORE, assuming your voice mail is on the default extension of 500. To send a call to someone's voice mail you press VMT and his DSS button or dial his extension and hang up. The outside party will get all of his greeting. If you want to prompt the user, like you would if you were taking a pink slip, you press 2W Transfer and his extension and carry on a conversation with the outside party. The message records in their mailbox as a new message. If you want to silently record into your OWN box, you press the VM Record button and your conversation is recorded into your own box as a new or old message, depending on how the system is set up.
There are other variations, including a single button transfer into someone's mailbox and some other features that are covered in you telephone sytsem OM or User's manual under Customizing your phone.
Carl
I can record an OGA, but when people call they get the automated default message. How can I set the OGA so that it replaces the default message?
Once you record your own message, it replaces the default one. If callers are still getting a different announcement, it's likely they aren't ever reaching your machine. Make sure that your telephone line voicemail service isn't picking up the calls instead. I've known several people with this same trouble, and they needed to modify their home voicemail (or whatever your service provider calls theirs) settings or turn it off. Then their phone answering machines worked properly.
Jan 01, 2011 | RCA 25250RE1 2-Line Cordless Phone
I have voicemail through my telephone company. Recently my panasonic phone system kxt7731 has been answering the calls for voicemail, instead of going to my phone company voicemail. I am being left...
I have voicemail through my telephone company. Recently my SAMSUNG SGH-D980 phone system has been answering the calls for voicemail, instead of going to my phone company voicemail. I am being left messages that I cannot retrieve! I would like to "turn off" the voicemail function of my phone system. I'm not sure why the phone changed from working "properly" to now picking up voicemail calls. Thank you for any help you can give me!
Sep 14, 2009 | Cell Phones
Model KX_T7630 Need to find the voicemail function???
Apart from needing more phone lines, the main solution was to use the TVM50 Voicemail instructions and not the guide that came with the KX_T7630 so the earlier Panasonic is a good place to start!
Apr 15, 2009 | Panasonic KX-T7630 Corded Phone
Alarm messes phone system
It sounds like your alarm is picking up the phone. How many rings before it picks up?
Mar 18, 2009 | BellSouth BELL SOUTH CI-36 Caller ID with...
Oartner ACS - Voice mailbox
If you go into system admin in voicemail, you have to edit the mailbox and give it a name.
intercom 777, 0#, 123456#, 9, 4 (mailboxes) enter the mailbox number and follow prompts to change the name.
WWW.telemanuals.com
Nov 21, 2007 | Avaya Eurostyle 18D Corded Phone
Panasonic KX-T7633 Corded Phone Logo
69 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
