Question about Microsoft Xbox 360 Console
Signal isnt getting through to my tv.
My xbox loads up buy theres no picture on the tv and tv says chek signal cable but ive tried it with new leads and my mates tv but it still wont work and there is no red lights green lights are on as normal and i can still turn off my computer with the controller can u help me out or any suggestions thanks
  • Anonymous Sep 27, 2008
    i have exactly the same problem my x-box turns on and my sound is working but no picture is on it. i have tried four different t.vs' but nothing seems to work.
Have u tried overloading your x-box with towels i had the problem and i did that and it worked. if you want to know how to do this you tube have a lot of fine examples on that are better than words
Posted on Sep 27, 2008
  • 3 Answers
Try asking your local xbox 360 support group they are good help or have you sent it out to fix
Posted on Sep 26, 2008
I have an xbox 360, but i have a ps3 connect to the tv via hdmi. i swapped the hdmi cable to the xbox and powered on. i had all the cables in the correct position, the correct av selected on the tv, but...
Have you tried disconnecting the HDMI cable from both the TV and the console and then trying to reconnect?
Y+RT does not reset controllers for the Xbox 360, so not sure what you are attempting there?
What type of TV do you have? It appears the issue is with either your cable or the TV seeing that you are having the same issue with both your PS3 and Xbox 360.
I still think your first step should be to disconnect all cables from both ends and reconnect. (with poer off of all sytems of course) If this doesn't solve your issue then submit further information on your setup such as TV make and model and I can research other possibilities.
Jul 16, 2011 | Microsoft Xbox 360 Elite Console - Black
Hello, i am trying to hook up my xbox 360 to my
Make sure the tv is set to A/V 1 if it has multiple A/V hookups make sure the tv is on and set to the A/V channel you are trying to use. And make sure your cable is set to tv if you have a composite cable. If that does not work try buying a composite cable (thats the yellow red red blue green white cable). If that does not work. There might be something wrong with the xbox or tv.
Jun 26, 2010 | Video Game Consoles & Games
Have got no picture on my tv xbox 360 is loading
you probably have a broken video or hdmi cable. somtimes the cables can even break at the connections or under the plastic coating, making the video going from your xbox to your tv not work.
Sep 14, 2009 | Microsoft Xbox 360 Console
No picture just sound.
I have two consoles that quit in 30 minutes of each other. the graphics chip is fried. go to www.xbox.com and file a repair ticket. you will get a tracking # to mail in the defective consoles.
Aug 19, 2009 | Microsoft Xbox 360 Console
Insignia ns-lcd15 no picture
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Jan 13, 2009 | Insignia IS-LCDTV32 32 in. Television
Just bought xbox 360 to play on my hd ready 32"samsung tv,the console came up with message thatgames need to be played at 60 pal,so i changed it from 50 to 60 and now the picture(mostly the writing)is...
ive the oposit problem i want to play hitman which is 50hz game but im using a hdmi cable and it isnt possible to run it in 50hz , 60hz only i think so if you get the new hdmi cables it should fix your problem (if you have a hdmi port you should be using it anyway for the best picture)
Dec 14, 2008 | Microsoft Xbox 360 Console
No picture
try using different A/V cords or a different tv. if your hooked up to HDMI then you should just try using a normal A/V tv and see how that goes.
Oct 20, 2008 | Microsoft Xbox 360 Console
Just bought a samsung ps50a557s3f 50" plasma tv and the picture isnt very good.Have only got normal sky at the moment and i was wondering what the best settings are
Hi Smudger
Not sure if you still have this issue, but i have just bought this TV & also use sky (not + or HD)...
I got myself a Monster Cable Home Theatre surge protection unit from comet, basically it helps filter out all the background interference (picture & sound) & helps boost the signal sent to the TV..
I use a gold plated scart lead from the sky box to the TV & the picture is spot on.......i've not noticed any ghosting/pixeling etc & am well impressed...
The unit came with a top end HDMI cable & cost £135 (bit excessive you may think, but to buy the unit & cable seperate would cost £250!!) + the cable is a 'cable for life', so you can get a free updated cable as technology progresses :-)
My sky signal was always at half power (you can view this from the sky menu options) & now its almost full signal
Oct 06, 2008 | Samsung Televison & Video
Un recognisable picture
try a different set of av cables and or input on the tv and see what u get
Jun 21, 2008 | Microsoft Xbox 360 Console
My Thompson Freeview box keeps stuttering/time lapse freezing.
Hi Ive just bought a thomson dtr box and the picture keeps freezing .new arial new cable etc.well ive just tried a £20 freeview box and its fine good clear picture and dosnt freeze.I had a good signal when using the thompson box and its the box load of rubbish taking it back to shop.
Apr 14, 2008 | Televison & Video
Microsoft Xbox 360 Console Logo
81 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
