Dvd has no color on my new plasma t.v.
This should be a no brainer. the jacks are yellow,white,and red. .plugged in to the color coded jacks.
    Sergeant:
    Champion:
  • 223 Answers
Check for loose connections or sockets either on the dvd player or the tv. If none exist try another lead. If this still does not work check the settings on both the tv and dvd player to make sure the input/output of the tv and dvd player are using compatible formats.
Posted on Sep 26, 2008
Can't figure out which color cables go where on tv to dvd
follow the color code, red white and yellow from dvd output to red white and yellow tv input, match the color of cable end to color inside the jacks of the units
Mar 10, 2013 | Philips Televison & Video
I have been given an Argos DVD Player. I have the lead with the red white and yellow plugs at both ends. No Manual, how to I attach it to TV. Do I use a Scart lead ? Thank you.
If your TV has what is called RCA jacks that is what red, white, and yellow color code is for. Red and white for audio, and yellow for video. If your TV does not have right and left audio in (red and white) There are adapters available at electronics store but not worth the price considering what a DVD player goes for these days.
Aug 21, 2011 | Computers & Internet
HOW DO I CONNECT TO TV
There are many methods to do this.
If your cable are ONLY RED,WHITE,YELLOW
1 Plug the red white and yellow cables to there corrosponding jacks on your DVD player
2 Plug the red white and yellow cables to jacks labled video IN, Audio IN. They will be colored on the back of your Tv
3 Plug in the power cable.
4 Turn it on and flip through the inputs on your tv until you see the picture
IF your cables are RED, GREEN, BLUE, RED, AND WHITE
1 Your are using what is called conponent video. This is a high definition video.
2 Three of your plugs are for video. They are Red(Cr) Green(Y) and Blue(Cb)
3 Plug the GREEN into the Y jack
4 Plug the RED into the Cr jack
5 Plug the BLUE into the Cb jack
6 Plug your power cable int o the wall if you havent alredy done so
7 Plug the other red cable into the audio right jack
8 Plug the white cable into the audio left jack
9 Turn it on and surf through the input until you find it
If you have a BLACK, RED and WHITE
Do the same as RED WHITE and YELLOW but
1 Put the black cable into the s-video slot
2 Surf through the inputs until you find the picture
If you have ONE BLACK CABLE
1 This is called HDMI(High-definition multimedia interface)
2 Plug one end into the tv and the other inte you dvd
Thank you for your time, Good luck and I hope this works
Jun 08, 2011 | Televison & Video
Trying to hook up panasonic veira flat screen tv without a manual. Not sure where to put the red, yellow and white cord.
These cable is to connect your tv to other hardware like a dvd player. Just plug the yellow cord on the yellow input in the TV and in the yellow output of the DVD, and the same thing for the other two colors. The yellow it's for the image, and the white/red are for the stereo sound (right and left channels).
If you don't have extra hardware you wont need to connect that cable.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
How do I connect DVD to TV please
on rear of tv you will have video and audio input jacks red and white are audio yellow is video , make sure they are input jacks the jack will be labled and and on back of dvd player will be red white and yellow jacks that are labled output using the cables supplied with the dvd use the red and white insert them on dvd out corresponding colors and the yellow into the video out, now on the tv take the other end of the cables and insert them into the audio and video inputs again with the corresponding colors audio red and white and video yellow ,,,I hope this helped
Nov 10, 2010 | TruTech Televison & Video
Dont realy have a problem just ned to know how to set up to my tv
There is an output for this device colored red, white and yellow. So the red and white is for the audio and the yellow is for video. Use an RCA cable with the same color. plug it at the back of your dvd matching the colors of the output jack and plug the end of the cables to the input part of your tv. So the red and white should be plug in to the "AUDIO IN" and the yellow should be plug in to the "VIDEO IN" on your tv, Set the tv to video and press play on the dvd.
Sep 09, 2010 | Haier Portable DVD Player PDVD7
Cannot get DVD's to play on our TV.
It depends on what kind of inputs your TV has; here are a few of the most common, all of which your DVD player supports (best quality first):
1) COMPONENT VIDEO (Red, Green, Blue)
If your TV has three inputs for video colored red, green, and blue, this is your best bet for quality video from your DVD player. You may need to buy a component video cable from the store (somewhat pricey, but great quality) which consists of three cables (again, red, green, and blue) stuck together. Just plug the red/green/blue cables into their correspondingly-colored ports on both the DVD player and the TV.
That covers your video. To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the red/green/blue cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
2) COMPOSITE VIDEO (Yellow)
If your TV has a yellow input for video, just use a regular yellow RCA cable. Plug it into the yellow video-out jack on the DVD player, then plug the other end into the yellow video-in jack on the TV.
To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the yellow cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
3) COAXIAL JACK (Antenna port)
If your TV only has a coaxial jack that you currently plug your antenna or cable line into, you'll need to buy an RF modulater and a short length of coaxial cable (you can find these anwhere: Walmart, Radio Shack, etc).
Plug the RF modulater into an electrical outlet, then plug your antenna/cable line into the "antenna in" jack on the RF modulater. Take the coaxial cable that you just bought and plug it into the "antenna out" jack on the RF modulater, then plug the other end into the antenna/cable jack on the TV. The RF modulater should have a switch on it somewhere that sets either the number 3 or 4; depending on which number you pick, that's the channel that your TV has to be switched to to view the DVD player.
Now you're all set to connect to your DVD player. Just follow the instructions in section (2), only now you're going to plug your cables in the RF modulater instead of the TV.
(I hope this wasn't too confusing; it really is a lot simpler in practice than it is in explanation...)
May 04, 2009 | Televison & Video
Coby DVD player set up
Brenna,
Here are some things to remember when messing with cables TO and FROM electronic audio/visual
devices. YELLOW connectors are for what you SEE on the screen of your TV or other viewing device.
The RED/WHITE connectors are for what your ears will hear, LEFT/RIGHT in stereo or mono.
Now all you need to do is connect the YELLOW output jack of your Coby to the YELLOW video
input jack on TV. You must remember forever and ever that the YELLOW jacks and plugs never
contain or transmit or move TV channels or CABLE channels or DISH channels. The YELLOW cable
which has plugs at both ends goes to jacks (output to input) and carries/transmits BASEBAND VIDEO signals only. Now all you need to do is make the TV stop listening to it's antenna in, and to
start listening to the YELLOW/RED/WHITE jacks on the back of the TV. You will need find out how
to put TV into MONITOR mode, or AUX mode, or VIDEO INPUT 1. Basically just match colors and
OUTPUTS to INPUTS. Hope this helps you out.
louie12fix @ fixya
Dec 17, 2008 | Coby DVD-224 DVD Player
Sansui 42" Palsma
I assume you are saying that the DVD player only has RCA jacks. It would be good to know if the DVD player has Component output as that is the preferred output. You will know this if the RCA jacks on the DVD are color coded green, blue and red.... You would by a set of component cables, hook to DVD matching colors and then find the same color code on input of the TV. You must also run the red and white cable from the DVD output to the TV input for audio. The input on the TV would be labled component in or input and a #. Simply select the input, or source button on remote to select the input that matches your choice and all should function. If there is no component on the DVD output and only a composit hook up (color code by yellow, red, white) again just match that to the corresponding input on the TV.
Jan 06, 2008 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
Home theater sound
Most plasmas have set of RCA jacks beside or near each video input, be it a yellow composite jack, component (RGB) or VGA (15 pin monitor cable) there should be a red &white set of jacks beside each input. There should be a r&w set marked audio out.thats what you want goin' to the Hi-Fi a/v input. All this is on the assumption that the plasma has no speakers of it's own. if it does, you may need to go to set up menu and check audiosettings on the tv.Your best bet is to go HDVI between the DVD/Sound if you have the ability on both units. Better vid and audio that way.
Dec 29, 2007 | Audio Players & Recorders
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
