Question about Hitachi CP-RX60 Multimedia Projector
Not displaying on laptop
When turning on the CP-RX60 projector it will display the windows desk top icons on the wall/screen, but not the on the laptop.
Have you tried pressing the Fn key in combination with the Monitor key (F4 or F7, varies by laptop)?
Posted on Oct 26, 2008
Laptop on, presentation loaded, projector funtioning and will show menu on projector screen but no presentation will display. What else do I need to do, please?
You may have to adjust the resolution your notebook is displaying at in order to make it compatible with the resolutions that will work with your scanner.
For example, most new notebooks display at 1380x760 or 1440x900, which are 16:9 ratios most suitable for movies.
Most projectors display at resolutions with ratios of 4:3, like 1024x768.
For Windows, right-click on a clear area of the Desktop and choose Properties... or Screen Resolution. Change the resolution to match your projector.
Feb 28, 2011 | Computers & Internet
I have a Hitachi LCD projector model No. CP-RX70. When I connect with my laptop (Compaque) and start both then only starting window XP message appears through projector and laptop works normally but again...
The setup is not correct. Check the requirements of the projector, (size, refresh rates etc.) and set the laptop up accordingly.
You will se the XP Screen because the laptop hasn't loaded any drivers yet and the screen is low resolution.
Hope that helps.
Dec 06, 2010 | Hitachi Performa CP-RS55 Multimedia...
My projector does not display my laptop screen
Follow the step by step procedure if you are using win 2000 or XP or 2003 :
Start menu -> Settings -> click Control Panel.
In Control panel double-click the Display icon.
On the Settings tab, click the image of the second monitor, and then select the Extend my Windows desktop onto this monitor check box.
Your problem will resolve.
Regards
Ashly
Feb 05, 2010 | Toshiba TDP-S8 Multimedia Projector
I have the Optoma Model EP719 running. When I turn on my computer the projector shows my computer screen as it boots up. As soon as my desktop wallpaper and icons appear on the laptop screen, the...
right click on main screen, then go to properties, then you can adjust resolution, color, contrast, hue, and much more. You can also do this from control panel and under display.
Oct 08, 2009 | Optoma Office Equipment & Supplies
Hitachi projectors cp rx60 cp r555 same remote control?
Specifically i don't know. What i do know is mfg's use the same codes, whether they map them to the same functions across a series of remotes can't say for sure. Experiance tells me it will be just fine...
Jun 10, 2009 | Hitachi CP-S335 Multimedia Projector
MacBook connected Hitachi CP x301 Icons do not appear
Ok what's happening is that you have it set up as an extension of your desktop, you need to mirror the displays. when your projector is plugged in and it is showing only the desktop background, open "System Preferences," click "Displays," click "Positioning" and check the box that says "Mirror Displays." This should do the trick.
Mar 28, 2009 | Hitachi CP-X301 Projector
Laptop computer connected to projector.
When the projector displays the background image and the lcd displays the desktop as normal you can drag the open windows to the left or right and display them on the projector. it sounds like this laptop has an internal video card. If you right click on the desktop it might give you options to configure the display settings for the video card. Not sure how you will get to it if it does not show up on the right click menu. Probably through the start menu or in the control panel there should be somewhere to change the settings for the video card. This will no be under the display settings though.
But once you find your dual display options you will be able to change it to make both displays the same
Jan 21, 2009 | Dell Latitude D600 Notebook
Hitachi CP-X445W Multi. Projector
I have the same problem with a Hitachi CP-X345 Multimedia Projector. My Acer Aspire 3630 Laptop cannot be detected but it works without incident with a Dell Vostro 1500; just plug and play. Desktop settings to second screen doesn’t seem to help.
May 16, 2008 | Hitachi CP-X345 Multimedia Projector
Resetting the air filter timer
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Apr 22, 2008 | Hitachi CP-S335 Multimedia Projector
Laptop powers up but does not display desktop
How to enable / disable windows active desktop. Open Display Properties. Click the Web tab in the Display Properties window.
DirectX Help Get the computer into Safe Mode. In Safe mode, click Start / Settings / Control Panel and double-click on the display icon.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Acer Aspire 3680 Laptop
Hitachi CP-RX60 Multimedia Projector Logo
195 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
