Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Ice maker I returned from vacation and turned the ice maker on. It has ice in the tray but does not dump. What can I do to get it restarted?
I disconnected the refrigerator from power, then used hair dryer to thaw the ice in the tray that would not dump. After waiting 15 minutes for further melt time, I replugged the cord and the icemaker began to function normally. The help desk at Whirlpool had no suggestions, other than I should call a service technician to solve my problem. So, using a little engenuity I saved myself the price and delay a service call would entail. I am not sure I spelled engenuity correctly, but that is not my problem.
Posted on Sep 27, 2008
Ice maker on whirlpool quit working .
If it's like my Samsung, there is a reset micro switch button in front of the box containing the ice cube tray. Press it and the machine resets, the ice cube tray rotates, dumping the cubes. It then rights itself and fills with water. Hope this helps.
Sep 03, 2017 | Whirlpool Refrigerators
Why doesn't my ice maker dump the ice out into the ice bin?
several reasons. 1) the ice level sensor bar is pushed up. 2) the motor may have accumulated ice inside it causing it to stop turning. 3) Ice tray thermostat may be bad not heating the tray just prior to dumping.
Aug 18, 2014 | Kenmore Refrigerators
Returned from vacation and can't get the ice maker to restart. It was working fine before vacation. I emptied the bin and clean it and put the refrigerator on vacation. When I returned the ice maker...
ice maker only works if tempt is cold enough . 15 deg of colder . ck the fans and ck the coil /to see if clean these are very common maintaince problems that cause your problem .. mm
Aug 17, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ice maker has ice motor doen't dump the ice
Your ice-maker may need to be "hard-reset". To do this, perform a manual-defrost by emptying out the freezer (and fridge) and shutting all power off to your unit for several hours (at least half a day unless you can be sure the temp in the freezer has fully reached ambient. Next, with freezer empty, restore power, make sure the "ice" setting is set to off, then set the forced power-freeze mode (you can refill the fridge, but leave the freezer empty for now. When the power-freeze completes (at least 2.5 hours) you can refill the freezer, set the "ice" mode to block/crushed (IE something other than off) and then hit the "black reset button" to restart the ice-maker. IF it still will not dump the cubes then the ice sensor/control board may have failed.
May 24, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
KitchenAid ice dispenser tray is dry - not working
Put some water in the ice mold is what I would try. wait and see if the ice maker harvest a batch. If it does drop a batch but no more then the water valve is probably shot. The ice maker itself controls the water. It does this by filling the ice mold for 7.5 seconds. Here is your Ice maker repair manual and some repair photos along with a pictorial which snows how to check the water valve.
Ice maker quit making ice
Apr 05, 2010 | KitchenAid KSRS25IL Side by Side...
Ice maker has ice in the tray, but will not dump or do anything
"Ice in the tray". Do you mean ice is in the well of the ice maker, or in the tray or bucket that collects the harvested cubes from the ice maker?
If the problem is the ice is in the ice maker well, and will not dump, then, if the ice maker is turned on, and the temperature in the freezer is 14 degrees or colder then the ice maker has failed.
In rare occasions an ice maker can be repaired but is rarely done, and is a repair only someone with strong working knowledge of ice makers can perform.
If you are handy with tools you can remove the icemaker. 3 screws and power plug. Once out you can check the well to see if something has jammed up the rake, but that's about all.
Oct 28, 2009 | Maytag MSD2454G Side by Side Refrigerator
Samsung Refrigerator makes ice, but then quits.
I have this same thing happening, also. I have not been able to find a solution to this issue, however. The ejector blades push against the ice, apparently a gear pops loose with a loud clicking sound and the heater either does not work or never turns on. I end up killing the breaker to thr refrig,`removing the icemaker, letting it wrm up dumping the ice and putting it back in.
Aug 21, 2009 | Samsung RF265AA Bottom Freezer French Door...
ICE IN TRAY BUT WILL NOT DUMP
This is a problem with the icemaker. You will need to replace it.
May 21, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
70 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
