Question about Olympus Stylus 710 Digital Camera
Write protect written across screen,will not allow me to view or take pictures,why??
Hi with my 1030sw olympus when i go to take a picture it says write protect on the screen and when i go to view previos pictures it says no picture,any suggestions
  • Anonymous Mar 28, 2009
    Same problem. Can still view pictures via computer but not on camera. Tried a different memory card and after transferring files back, same problem.
  • 4 Answers
Try taking the xd card out and take a pic if the camera works i would try a new xd card faulty cards are pretty comon allthough i havnt seen that message before
Posted on Sep 28, 2008
Olympus stylus 1030 SW purchased in 2008 won't download to my Windows 7 computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa:
Organize edit and share your photos
Feb 13, 2014 | Olympus ? 1030SW Digital Camera
Remove picture protection
Select the key icon from the Playback menu to protect/unprotect pictures. See page 33 of this manual: http://www.olympusamerica.com/files/oima_cckb/Stylus_1030_SW_Mju_1030_SW_Instruction_Manual_EN.pdf
Aug 16, 2013 | Olympus ? 1030SW Digital Camera
Blurry out come
Hi George
It sounds like a lens issue... Try:
1. cleaning lens (carefully!)
2. Could be condensation I suppose. Unlikely but make sure its fully warmed up and dry.
3. It could be a lens element misaligned possibly due to impact damage. Needs pro repair then.
4. Just a wild thought - it's not been left permanantly in some close-up mode giving a very out of focus effect?
Hope this helps,
Regards
Martin
Jun 21, 2009 | Olympus ? 1030SW Digital Camera
Olympus 850sw- write protect and picture error
Sounds as if the memory card has corrupted data on it now. You will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup Menu - right arrow to Format- Press Ok. You will see format yes or no. Choose Yes and press ok. This will clear the write protect and picture error messages and the card can be used again.
Dec 29, 2008 | Olympus Stylus 850SW Digital Camera
Write protect message appears on screen
Sounds as if the memory card may be corrupted. In order to remove the write protect, make sure you have downloaded and saved all of the images from the memory card to your computer and then having the card in the camera you will need to run the format option and this will permanently remove the write protect as well as all of the images from the card.
The card should be able to be used again after the write protect is removed.
Dec 14, 2008 | Olympus MJU 400 Digital Camera
Olympus Stylus 1030SW. The LCD monitor is pixelated. The pictures that are taken with the camera are crisp and perfect. When reviewed on the camera, they are very pixelated. When searching through...
You can try to reset the camera to factory defaults to see if this improves the monitor. You go to Menu and then left arrow to Reset and press Ok. Up arrow to Yes and Press ok this will put the camera back in factory default settings. If the screen still shows as pixelated, you might try to do a function of the camera called Pixel Mapping. Go to Menu and then right arrow to Setup then down arrow to Pixel Mapping - right arrow to Start and then the camera will try to repair the CCD processing chip inside the camera. If after this completes if the screen is still pixelated, then you want to send it to an Olympus service center for repair.
Aug 30, 2008 | Olympus Cameras
Cant take picture
The lens assembly and or microprocessor has failed.
Contact Olympus
Good luck, Paul
Jun 06, 2008 | Olympus FE-230 Digital Camera
Olympus FE-170 6.0 will not take pictures.
I had the same exact problem.The lens is not extending out fully or correctly, probably has broken or damaged gear or gears and needs to be replaced. Expensive repair done by Olympus. It is a very tricky and fragile repair on your own, requiring micro screwdrivers and soldering tool. I replaced my own lens but it was hard to find one.
Apr 28, 2008 | Olympus FE-170 Digital Camera
Olympus Stylus 710 Digital Camera Logo
301 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
