Question about GPS
Tomtom one It won't switch on. The green light lights up on the switch. The charger is definitely OK. How do I take it apart if it's the internal battery at fault
  • diggie1888 Mar 08, 2009
    tomtom 4N00.003. the green light comes on but the system wont turn on
  • mckoster4 Mar 19, 2009
    I have the same problem. Some days it will turn on others it wont. The charger light stays green but it will not turn on. It is so aggrivating!
E61N
  • 515 Answers
SOURCE: tomtom won't turn on
  1. Fully charge the unit
  2. Reset with paperclip at bottom of unit
  3. Hold down Power On for a longer period of time, about 10 sec.
It should start...
Posted on Apr 10, 2008
SOURCE: Tomtom not switching on
I had this problem. had it plugged in charging and then pressed the the reset and the power button at the same time for about 30-50 seconds and then after that pressed the power button and so far so good
Posted on Aug 14, 2008
  • 20 Answers
SOURCE: Tomtom go 730 will not power up.Brand new,used a coupla weeks.
you need to do a hard restart. find tiny hole on under side by bracket mount and press it with a tiny paper clip once. you have to look very very close to see it. you can also try to hold down on power button for 5 to 6 sec.
Posted on Dec 28, 2008
SOURCE: TomTom will not charge with car charger
Mine does the same, the light comes on on the charger, but not on the TomTom unit itself. There is clearly a loose connection in the cable somewhere as you can twist the flex and make it work, although this is not very reliable.
I just use a USB charger from an old phone instead.
Posted on Oct 30, 2009
SOURCE: my tomtom won"t turn on
If you have a tom tom from the GO models
they hace a reset button you can press with a pin were the mount fits.
When you plug in the charger the green light should come on to say it is chargeing.
Try the car adapter to charge the tom tom
Posted on Dec 13, 2010
My tomtom won"t turn on
Dec 13, 2010 | Tomtom GO 700 GPS Receiver
My TomTom One V3 won't switch on. The green light shows it as charging but it won't power up. Tried reset as discussed with TomTom
If reset not worked, then must open up, take out battery and then reset, then you must hook up USB and upgrade software, also maybe need to get new battery too, often battery seems OK, but not,.
Apr 10, 2010 | Tomtom ONE 3rd Edition GPS
Tomtom1version3 power on light on but will not switch on. Same problem using mains charger or in car power supply.Also computer is not picking the unit up as an external device
I'm afraid you have the green light of death. This happens when the car charger delivers more power than the TomTom can handle and it blows a couple of diodes.
Oct 14, 2009 | Tomtom ONE 3rd Edition GPS
Tom Tom not working
hold the power on button down until it turns on, does this help, also being plugged into charger with green light coming on normally means that the unit is charged.
Jun 21, 2009 | Tomtom ONE GPS Receiver
Tomtom wont charge.
If it is charging via a USB connection on your computer there is nothing wrong with the TT. It doesn't matter if you are trying to charge via USB, mains, or car charger the connection is the same for all in your TT. I would look elsewhere for the problem. More than likely your car charger is faulty.
Jun 07, 2009 | Tomtom ONE GPS Receiver
Mar 30, 2009 | Tomtom ONE 3rd Edition GPS
Tomtom Go 920 failure
The power light only shows that power is getting to the TomTom. It proves nothing else and doesn't even confirm that the internal battery is charging. If you have tried a reset ( by inserting a paper clip into the reset hole at base of your TomTom and that hasn't worked then it's likely you have blown internal components . Usually caused by faulty charger. I hope the reset works ... good luck
Oct 20, 2008 | Tomtom GO 920 GPS Receiver
CANNOT RECHARGE TOMTOM
If you have the green light lit on top of the tomtom but it won't switch on , then you have a condition commonly known as "the Green Light Syndrome". Most likely cause is blown components inside the tomtom that regulate voltage. The reason they blow is usually due to user connecting incorrect charger ( such as a 12v one for a phone ) or sometimes the tomtom charger goes faulty and instead of ouputting 5 voltas it outputs 12 volts and damages the tomtom inside. the parts are not easily repalced and require a specialist repair centre that has good experience of repairing tomtoms. You cannot repair it yourself using a normal soldering iron. Good luck.
Feb 16, 2008 | Tomtom One Europe v2 GPS Receiver
Tomtom go910
Try cleaning the TT contacts with alcohol, make sure the unit is off when you do it.
Feb 08, 2008 | Tomtom Go Plus GPS Receiver
TOMTOM GO 710
Could be a loose contact at the connection between the wire and at the gps unit.
Think the green light must be on at the charger port and also on the gps unit.
This green light can be found near the power button on the gps unit.
Nov 22, 2007 | Tomtom GO 700 GPS Receiver
GPS Logo
50 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
