Question about Sharp AR-BC320 All-In-One Led Printer
Prints a skewed image
Our printer recently developed a problem with skewing the image on sheets fed from the lower trays and duplex unit. Bypass does not seem to have as severe of a problem.Techs have replaced the transfer belt, clutch packs, rollers, feed mechanisms and guides without any resolution. This has been a really great copier and a good printer. It has 150,00 color prints and 350,00 BW prints on the counter. Still under service contract. Any suggestions? gosprint@mac.com
  • Jayson Gossett Sep 26, 2008
    Thanks for the response. I guess I was just hoping that this is a common problem. If it was not for the significant value of the components being replaced, a person might think they were not sincere in their efforts. Our tech is scheduled for a return visit!
    Problem Solver:
  • 8 Answers
Your paying good money for that service contract. I'd have them send a tech and have him stay there until it's fixed or find a new service provider. Questions like this drive me nuts. Were not talking rocket science here, these devices are not that complicated. Hold contract providers feet to the fire until this is solved. I'm really sorry.
Posted on Sep 26, 2008
Km c253.. all colors skewed
Black image unit is the reference for registration might have a bad unit.
Jun 12, 2014 | Konica Minolta Office Equipment & Supplies
Duplex feed not working
Check the C6200 Device Settings in the properties and make sure that the Duplex Unit is installed.
original?v=mpbl-1&px=-1
Dec 09, 2013 | Brother HL 5250DN Laser Printer
HP 4250 SKEWING PAPER
Yes, it is possible to be the problem. Most of the time you would replace the whole fixing unit, it could also be the paper feed rollers in the paper tray or the manual feed tray. Good Luck
Sep 04, 2012 | HP LJ 4250 Printer
Image is skewed from platten or dh
Make sure that your paper trays are lined up correctly and tight against the paper in the tray. Also, I would make sure there is not any paper jammed behind the paper tray and make sure the paper is in the paper tray correctly... Good Luck
Aug 16, 2012 | Canon imageRUNNER 2200
Hi there. Our Canon ImageRUNNER 3235i has been skewing papers about for months. Service techs can't seem to find the problem as it is sporadic. Any suggestions?
These can be a quite pain, this copier when it works it works it fine, but when it doesn't works it doesn't work with style.
Please give me more info, where the paper is skewing? in duplex assy or before or after the fixing unit or while going out of paper drawer...?
I had a problem that paper was skewing in duplex and I've chaneged the duplex vertical roller axis.
Sep 20, 2011 | Canon ImageRUNNER 3235i Black and White...
HOW DO YOU CORRECT A SKEWED COPY ON THE COPIER? HAVE CHANGED REGISTRATION ROLLERS, SKEW IS SAME FROM ALL TRAYS & BYPASS. TRIED ADJUSTING THE FOCAL LENGTH ON THE MIRRORS, AND STILL HAS ABOUT 1/8 INCH...
First you need to determine if it is optical skew or mechanical skew.
If the machine is used as a printer then do the computer prints come out skewed? If it is not connected to a PC then print out the counter list using UserTools/Counter. If that prints straight then you are dealing with optical skew. Ricoh's in general are bad about the left front corner of the machine drooping from someone pushing down on that corner. If you have optical skew try lifting up the left front corner of the copier and try making a copy. That might fix your problem.
If the UserTools/Couter print out is skewed then your back to a mechanical skew and there are numerous causes for that.
The optical skew is more likely so let's start there.
Nov 18, 2009 | Ricoh Aficio 1018D Copier
HP laserjet 3050 prints skewed vertically
250-sheet input tray (tray 1)
The input tray holds up to 250 pages of 80 g/m2 or 20 lb paper or fewer pages of heavier media
(25 mm (0.9 inch) or less stack height). Load media with the top forward and the side to be printed
facing down. To prevent jams and skewing, always adjust the side and rear media guides.
NOTE When you add new media, make sure that you remove all of the media from the input
tray and straighten the stack of new media. This helps to prevent multiple sheets of media
from feeding into the all-in-one, which can cause jams.
Hope this helps if not you may have a registration roller problem.
Dec 15, 2008 | HP LaserJet 3050 All-In-One Printer
HP 4250 - always prints askew with left margin at bottom approx 5mm greater than at the top. Any help greatfully received. John
It sounds like the paper is skewing as it is picked up by the roller - watch a sheet go through and see if thst is the case. Make sure the paper guide in the paper tray is pushed solidly to the left edge of the paper and check if it is loose. If it is loose then it might allow the paper to skew as it feeds in
May 09, 2008 | Office Equipment & Supplies
Printing out of square
If the problem is with the single sheet feeder try running regular paper through it - does it have the same issue? Is the paper skewing as it is fed in or is the print itself. If the paper is skewing look for problems with the feed rollers possibly a label has become attached to one of the rollers. If not try cleaning them with (90% or better) isopropyl alcohol on a soft rag
Jan 13, 2008 | OKI B4350 Laser Printer
Crooked Copies
dear sir please check the upper heat roller claws set,may be one of them is bended up
Sep 27, 2007 | Panasonic Workio DP-4530 Copier
Sharp AR-BC320 All-In-One Led Printer Logo
119 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
