Question about Brother MFC 210C All-In-One InkJet Printer
I have mfc210c that come with three color of ink,two of them ran out which is fine because i just want to use the black ink only but it with not let me use it what can i do to use just the black ink, i push black start but a error message keep jumping up out of ink and i just brought the black ink and install it.
I bought new ink for my brother printer there not name brand when I replaced all ink cartridges, on the small screen its says to replace ink why doesn it say that??? agnes
Posted on Sep 27, 2008
Whenever you want to print, before you click the ok button, go to options then advanced and click on the option that lets you print in greyscale.
hope this helps.
Posted on Sep 26, 2008
    Problem Solver:
  • 8 Answers
See if there is a printer software setup option that will allow you to set B/W printing only. If not you may be out of luck. Could be this particular print device requires all colors available.
Black not printing, other colors fine, replaced cart and deep cleaned several times, no result
Assuming genuine ink cartThis worked for me on a HP printer 1.Try print black text ,and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Good Luck Inkypete
May 01, 2009 | Canon PIXMA iP3500 Printer
RX680 shows ink is full but will not print lt mag, mag, or cyan
usually the problem occurs when the ink is running low and a big print job is being done. by then, the printer runs out of ink and starts sucking air into the tubes. If several cleanings dont help, try leaving it off for a couple days, turn it back on, try another cleaning and see what happens. if it still does not work, most likely the printhead will need to be cleaned which will cost about $40 - $65 if cartridges are need too.
If you are you using generic ink, that can cause the problem too.
Feb 10, 2009 | Epson Stylus Photo RX680 Printer
Black and white not printing correctly, color is fine
If you are not using Epson ink, your printer will do this. Epson printers hate knock-off ink. Always use Epson ink if you want to keep your printer working properly. To solve the problem you are having, try cleaning the ink tubes. Make sure you re-install them properly. Hope this helps. Charlene
Feb 10, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Borther mfc210c black ink not printing even after cleaning
if your brother machine is within warranty, give the tech support a call. if not,replace the black cartridge with a new one. it may be a defective cartridge that you have or if you are using refilled cartridges, it will also give the same problem
Nov 18, 2008 | Brother MFC 210C All-In-One InkJet Printer
My ink ran out and I replaced both the black and color inks. The black is ok, but the color still show that it needs ink. Now my printer won't work. Can you help me?
Yes, I got it solved. I returned the first ink cartridge and got a new one, Ir works fine now, except the red is more pink than red.
Nov 04, 2008 | Office Equipment & Supplies
I have a epson stylus printer C65 series. I ran out of black ink so i changed the ink cartridge and it will only print colour not black now.
I have an Epson stylus 6000 series, second hand but was working just fine. I changed the ink cartridges and now the color won't print. Utilities shows all cartridges full, but only black and pale green-blue print. While it was printing color it was drinking the ink, but that's another story.
Yvonne
Aug 09, 2008 | Office Equipment & Supplies
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
hi,
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Mfc210c cannot print black if other colors are empty
see first picture how to cheat the printer:
http://www.fixya.com/support/t273678-brother_mfc_5460cn_print_w_full_black
plz note:
This trick might destroy the function of the color ones (c/y/m) if you doesnt replace them within time because the ph needs the ink to keep the nozzles wet! if it drys out the ph for the color ones is rotten and cant be fixed anymore!!!
Nov 29, 2007 | Brother MFC 210C All-In-One InkJet Printer
Black ink not working; but colors are
Use a original brother ink cart. Do the cleaning twice. If there is no more black blocks to see, the printhead is crashed!
Aug 25, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 210C All-In-One InkJet Printer Logo
64 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
