Question about Epson Stylus Photo R220 InkJet Printer
EPSON R220 - Open
Dear Techs:
I am trying to retrieve an object that fell into my printer and it is not visible from just lifting the usual lids. Do you have any diagrams/instructions that show how to open this printer? Any help will be appreciate.
Thanks.
Ken
tactful4u@yahoo.com
  • joaovas1 Nov 09, 2008
    An object fell into my prinater that is not visible howerver stoped machine printer. Do you have any a Photo R220 Exploded Diagram to help me?
    Att. João V. Neto
    joaovas1@gmail.com
  • Epson Master
  • 691 Answers
Get a service manual for the R220 from http://www.tradebit.com/filedetail.php/4544461-r220-r230
Posted on Nov 09, 2008
    Genius:
  • 1,447 Answers
Hi-
For an exploded diagram, try their distributor site. compassmicro and look for the product model and the exploded diagram.
Hope this helps
Posted on Oct 19, 2008
Printer TX550W has message "A printer error has occurred. Turn off and then on. See your documentation".
Hi, this error message usually caused by jammed papers or foreign objects inside your printer. To resolve this issue, please try the following steps.
1. Turn off the printer.2. Open the scanner unit.3. Check for any jammed papers or foreign objects then remove it.4. Check the ink cartridges and lids if push down fully.5. Close the scanner unit.6. Turn on the printer.
If the same error reappears, try the following.
1. Turn off the printer.2. Open the scanner unit.3. Remove all the ink cartridges.4. Turn on the printer >> your printer will display install ink cartridges.5. Install all the ink cartridges, make sure it clicks into place and also the lids should be push down fully.5. Close the scanner unit.6. Press the Start or OK button to charge the cartridges.
If the issue persists, your unit will require service. Please contact Epson so they can check if your printer is still under warranty or ask them for the nearest service center in your area.
Nov 23, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
I'm trying to change an ink cartridge. Cartridges
Usually the printer manual will have instructions on changing the cartridge. If you don't have a manual, there is a chance you can find one online by googling the make and model number. On some printers the cartridges center when you open a door to access them, or lift a lid or a scanner deck, or turn off or turn on the printer.
Oct 03, 2009 | Office Equipment & Supplies
When i try to reset counter, it comes up communications error
A communications error usually means that there's a problem with the connection between the printer and the computer.
This could be because of a duff USB cable or something pulling on (and damaging) the connections. However I've also heard of this behaviour when using the SSC utility in an attempt to reset the waste ink counter which I'm guessing is what you're trying to do.
If you are based in the USA I'd recommend filling out the form for this utility:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
It does invalidate your warranty but the R220 is that old that you won't have anyway.
If that doesn't work then you could try looking for an adjustment utility but be warned they are a lot more complex and it's easy to bork your printer if you're now careful.
Keywords: "eserviceinfo r220 adjustment utility"
Feb 21, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus R220 Photo InkJet Printer
Check for obstructions (ie tiny pieces of paper and other foreign objects)
Clear the obstructions.
Turn it off then do the self test and check if the printer will printer without using computer
self test (press and hold the paper button and press and release the power button, if you can see the green light is flashing release your hold on the paper button. By the way make sure there is paper on the printer)
If it prints good then you need to check the settings on your computer.
Nov 10, 2008 | Epson Stylus Photo R220 InkJet Printer
EPSON R220 - Open
HI,
Do you know what it was that fell inside?
Thanks,
Worldvet
Sep 26, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Photo R220
epson printer R 230 flash how
Aug 29, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson r220
The printer may have an internal error or a hardware issue already.
Ink pads full usually indicates if all lights are flashing and an error msg would pop up in your computer screen "parts inside..."
Here's what you may want to try.
Just turn off the printer.
Checked for obstructions or any foreign objects inside the printer.
Try to check from inside the printer where the ink cart holder is, from where you load the paper and from where the paper comes out.
Jun 05, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson stylus photo r220
Open the printer Properties, Under quality there should be a box
that you can check (print in greyscale) or (print in black & white).
You have to remembe to uncheck to print in color.
Feb 04, 2008 | Epson Stylus R220 Photo Printer Color...
Can't install printer drivers for Vista
It complicate the data , If you have cd for r220 delete data in computer you must back first before you deleting that file , reintall r220 CD again , reintall epson support , then ok.
Dec 27, 2007 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
122 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
