Question about Canon Office Equipment & Supplies
Changed cartridges and now printer will not print. E 1 6 comes up. do not have a book to no what codes mean? please help
    Problem Solver:
  • 8 Answers
I don't have a book either but I'd suggest you ensure cartridge are installed per iinstructions.
Posted on Sep 26, 2008
My MX922 printer worked well this morning. All cartridges have ink but ALL lights under the cartridges are on and print comes out blank. There are no error codes or anything abnormal displayed
This problem is mainly happens to all inkjet printers. If your printer print blank pages then please at least once go to official site of Canon and check whether there is any printer/scanner drivers update is available or not. If yes then download it. Also check your ink cartridges. Because if there is no print on paper that means your ink might be dry.Sometimes it clog the print head. If your ink cartridges get dry change it. Or you should clean your printer's print nozzle by using printer's control panel. I hope all these suggestions helps you. If doesn't then watch Canon MX922 Manual English
Jan 12, 2017 | Canon Pixma MX922
Showing no print cartridge
Please check your cartridge. Just shake well and put once again and try to print the page you want. If the cartridge is full and if that printer repeatedly shows that error means please change the cartridge. Because some cartridge comes like this sometimes that powder will freeze.
May 02, 2016 | HP LaserJet M1005 Printer
When I go to print, the printer has a C 1 E that keeps coming up on it and the exclamation points are flashing next to the on off button what does this mean.
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
Good Luck!!!!
Sep 27, 2011 | Lexmark X2500 All-In-One Printer
I have the same problem but mine is with a canon mp190. also says E5 error on lcd and 2,114,0 eror when i try and scan. what can i do
According the Canon the error code means this:
E, 4/ E, 5 The FINE Cartridge cannot be recognized
The FINE Cartridge may not be installed properly, or the Cartridge may not be compatible with this machine. Open the Scanning Unit (Cover), and then make sure that the FINE Cartridges are installed properly and that the installed FINE cartridges are compatible with the machine.
If the error is not resolved, the Print Head may be damaged. Contact your Canon Service representative.
The "fine cartridge" means the black printing cartridge. The black should be installed on the left and the color on the right.
Double check to make sure your cartridges are installed on the correct sides.
After verifying that they are on the appropriate sides, then turn off your printer and unplug it from the power source.
Remove and reinstall the black cartridge.
Plug the printer back in and turn it on. If the error code is still there, press the menu button and scroll using the arrows until you see the "maintenance" area on your printers display. Then press enter or "ok". Continue scrolling until you find the "clean print heads" function and then again press enter or "ok" Follow the instructions and clean the print heads at least two times.
If the cartridge is full and installed correctly, the according to Canon the print heads have trapped old ink in them and this could be cloggin the ink flow. Cleaning the print heads should solve that problem. If you still get the error code after cleaning the print heads a couple times then I suggest contacting Canon for a possible warranty repair.
Nov 25, 2010 | Canon PIXMA MP190 All-In-One InkJet...
What does code 2114.0 mean
Hello. That is a print cartridge code. When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge. Regards, Joe
PS please rate my answer. Thank you.
Jan 06, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Green and orange lights flashing
Print cartridge
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
CF
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Aug 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
HP Deskjet 9300 - All leds blinking
Aug 24, 2009 | HP Office Equipment & Supplies
I have a Photosmart C5280 Have changed colour cartridge for the first time Alignment has failed twice Book tells me to contact you Print cartridge alignment failed.
then try to print if the alignment fails then you need to change the cart in the
printer if its original hp new cart then get replaced .....
Good luck..
Jan 06, 2009 | HP Photosmart C5280 InkJet Printer
Ink Cartage CYAN for Brother Printer Model MFG 440 CN replaced
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Dec 07, 2008 | Brother MultiFunction Center MFC-440CN...
Error 1203
You can try testing your Printer with another Print Cartridge and if the error message repeats, you should contact Service Center as then there would be a Hardware Problem.
Jul 15, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
old marine
old marine
