Question about Philips 50PF7320A 50 in. Plasma HDTV
Power issue on a Phillips 50PF7320A
An electricial was working on my house and caused a short somewhere which resulted in a power surge, which in turn resulted in my tv goin out and it wont turn on again. The tv was replaced by the company, but I was wondering if there was an easy fix or would something like this happening have done too much damage to even be worth it.
    Problem Solver:
  • 7 Answers
It is probably the power supply board, it has fuses on it, it can easily be fixed just take the back panel off and check with a multimeter, if good then the board is bad, the last two i replaced cost 200- 250 dollars
Posted on Sep 29, 2008
Phillips 39" tv problem
a power surge can do alot of damage but does your model have a fused plug? as would check this. if you have changed the power board for a know working one then the main av board has gone this is the board that tells the power board to turn on.
Jul 15, 2017 | Televison & Video
Tip
HOW TO PROTECT YOUR ELECTRONIC GOODS AGAINST POWER SURGES
I have only been giving advice on FIXYA for a very short while but have noticed that an awful lot of the people who relate their product issues , particularly complain about faults developing after power cuts / outages. It is apparent, from a description of the complaints, that damage is being caused by outages that may be a result of power surges blowing electricity sub stations.
There are a lot of damaged audio devices / tvs being affected. As such I advise you TO BUY SURGE PROTECTORS for all you valuable devices.
I have them around the house and although we only get an occasional power cut here in the UK I know that at times they have saved my equipment fron power spikes. The small cost is justified in the long run.
on Jul 20, 2015 | Yamaha Rx-v365 A/V Home Theater Receiver
Today my power went out for a split second and came back on I turn my TV back on it makes a high pitched whining noise and the screen wont turn on. Cant add picture but model number is MW30G71.
unplug your tv. let it sit for a good bit. 1/2 hour did your power just go out or did you have a power surge then no power. surges cause the grid to go down for a second too and that causes problems too. surge protectors are good for everything. also are you on cable? if so have the cable company check they're filters into the house may be an issue but check the tv after a half hour unplgged and then plug in and turn on normally? sometimes it needs a reset time period before the fuses inside will reset themselves.
Nov 17, 2015 | Televison & Video
A power surge zapped my TV, I turned it back on, it tried to bring up the picture but shut off again. A green light keeps blinking.
if a power surge shut down the unit than a circuit, capacitor or fuse is blown and or burnt and you wont smell that most of the time and since it does have power fuse wasnt blown so a circuit -diode-capacitor is fried somewhere problem is common for an electricial damaged tv but to diagnose an electronic tech would need to tear it apart
Aug 26, 2015 | Sharp Aquos Televison & Video
Why won't my Mitsubishi 73 inch tv come on? Model #WS73411
There may be a circuit board short and component problem that needs a technician to test and repair. This can be a result of a power surge whereby the house power failed and when it came back, too much amperage may have damaged the vital parts on the circuit board. Alwaus use a power surge protector or UPS.
May 10, 2014 | Televison & Video
Phillips 52pfl5704d turns on screen blinks, no video
The replacement board could be defective. Your TV worked fine until there was a power loss so its time to troubleshoot to find out how the power loss affected the original board in theTV. There could have been a power surge.
Dec 12, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
TV will not turn on.
Sounds like there is a short in the tv somewhere, the clicking is probably a breaker/fuse inside the tv cutting power to prevent damage to the components. Have you tried a different outlet as they can sometimes cause this to occur by surging power to the unit.
Dec 04, 2013 | Sony KDS-60A2020 60" HDTV
Power to dishwasher
Their is either a Short or an Electricial grounding taking place during the wash cycle. Don't take a chance on buring out your circuit  breaker in the house  panel box . Quit using it until the electricial problem is found.
Dec 15, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Power surge issue
This is a fault in the motor, could be a shorted turn in the motor windings. This has nothing to do with fuses.
Oct 06, 2007 | Eureka 4467AV Upright Vacuum
Blinking red light
If your Sony TV is hooked up to a good signal and is set up correctly, but only clicks and has no picture or sound, and even the menu will not show up on the screen, then it means that the main power supply has stopped working. I usually find that a small crack in the solder joint of the horizontal drive transformer or a shorted flyback will cause the large horizontal output transistor to short out, and this shorts out the switching transistors in the main power supply which then causes the Sony 0.1 ohm fuse resistor to open up. I have also seen power surges or power failures (brown-outs) cause the switching transistors to short out. In any case, the set absolutely should be serviced by someone experienced in repairing Sony TV's.
Aug 05, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Philips 50PF7320A 50 in. Plasma HDTV Logo
142 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
