Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
The coffee is beginnign to have a metallic taste - how do i clean it? thanks. Rita Herndon
  • 8,596 Answers
Run 1 tsp lemon juice per 1 cup water to improve taste. Also, change the charcoal water filters inside the unit.
Posted on Dec 17, 2008
All of a sudden my electric percolator coffee tastes very metallic. i have been using this pot for 20+ years!
Try running white vinegar through it for a cycle to clean it then run plain water. If that doesn't fix it, and nothing else has changed, try buying a gallon of water at the store and making coffee with that. Something may have changed with your water supply. Water quality is one of the most important aspects of coffee making. If none of this helps, have someone else taste it. If you've started a medication recently it could be altering your taste as well. Good luck.
Jan 02, 2010 | Kitchen Appliances - Others
Strong metal taste, how do I get rid of it. Coffee tastes terrible with very strong metal taste. I have boiled kettle about 8 times, but am unable to get rid of bad taste.
Professional chefs face this problem many times over with their stainless steel wares. Fill the coffee pot with water. Add a tbs of bleach. Let set for 2 hours. See if that helps. If it doesn't, please let me know.
Oct 20, 2009 | Breville SK500XL Stainless Steel Cordless...
Coffee not tasting good
To make the self-clean light go off, just unplug the coffeemaker for longer than 20 minutes. As far as not tasting right, did you try flushing the vinegar out of the coffeemaker using plain water, or water mixed with 1 tbsp lemon juice per cup? Also, get rid of your current charcoal water filter - after time, it will disintegrate, and your coffee will have a hint of charcoal.
Apr 11, 2009 | Cuisinart DCC-1200 Coffee Maker
I just bought 1 electric kettle recently.
Run some white vinegar through the machine,.
Jun 21, 2017 | Kitchen Appliances - Others
Mr Coffee Maker FTX25 - coffee tastes bad
Try running a 1/3 white vinigar -2/3 water mix into the brewer, let it brew, then run several pots of clear water through it. This should clean up any bad taste.
Feb 09, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee tastes metalic
Welcome to FixYa! I'm the expert that has chosen your problem to resolve.
White vinegar (which is a very mild acid) is a good solution for those folks that clean their coffee pots about every two days, however, if you are like me (I drink about 2 pots a day), I usually don't get around to it until the coffee won't run any more.
So, I "kick it up a notch" with CLR (Calcium, Lime and Rust). It is perfectly safe to use in coffeemakers. Just look on the back of the label and you will see how to clean your coffeemaker with great results).
Thanks again for using FixYa!
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further. I am at your service.
Jan 31, 2009 | Black & Decker 12-Cup Programmable...
Bad tasting coffee
tell what does it taste like is it to hot burn let me now but i would descale it first not with venagar but with coffee maker descaler start with that and let me now what the taste
Jan 10, 2009 | Sunbeam COFFEEMAKER 10C BLACK DR13
Coffee tastes like metal
THIS HAS NOTHING TO DO WITH THE COFFEE. This has to do with water filter system and most importantly descaling of machine, as over time the metals in side machine and tubing get a mold type build up. Its a chemical reaction from the water and tubing and the coffee and metals. To 100% solve this, descale the machine with water and vinegar mixed. Do this a couple of times and use bottled water to fill water tank if you do not have a good water filter tap system. I have been the espresso business for over 16 years with 4 locations, and it has nothing to do with the coffee. If it was the coffee or poor coffee it would tasted burned or bitter, but NOT tasting like metal.
Please rate my solution as you see helpful, Thanks Mike Espresso Expert
Jul 02, 2008 | Dacor CM24P-1 Coffee Maker
Metal Tasting Coffee
vinegar is not the best it remove calcium in little piece descaler produit melt go buy the descaler produit 1part descaler 1 part water put in water container start the machine after a few second turn it off leave it there for 15 minute repeat untill empty rinse very good after that product is corosif 2 or 3 full rinse thanks for using fixya pierre
Feb 12, 2008 | Cuisinart 12 Cup Digital Thermal Coffee...
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
177 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
