Question about ASUS P5PE-VM Motherboard
Exe Well i think your best, how do I disable visual themes, desktop and display scaling. Please man...
    President:
  • 1,257 Answers
Right click on the nfsc.exe file and click properties.>goto compatability mode >right click on the check box for "Run this program in compatability mode for" and select windows 98 > also right click on the 5 checkboxes downside for settings.....
Posted on Oct 03, 2008
I have totalmedia 3,5 arcsoft per windows vista, but i need to use it with windows 7. Could you help me? Thank you Gennaro
The router may not be the problem. It may be the compatibility issue.
Here is the article that addresses running older program with Windows 7
Make older programs run in this version of Windows
Most programs written for Windows Vista also work in this version of Windows, but some older programs might run poorly or not at all. If a program written for an earlier version of Windows doesn't run correctly, you can try changing the compatibility settings for the program, either manually or by using the Program Compatibility troubleshooter.
getcontent.aspx?assetid=745c7204-cf9f-46fb-a86c-98d4b9c644cf&documentset=en-us&prod=win700&market=us Go to the Windows website to watch the video. (1:26)
If changing the settings doesn't fix the problem, go to the program manufacturer's website to see if there is an update for the program.
Warning
  • Do not use the Program Compatibility troubleshooter on older antivirus programs, disk utilities, or other system programs because it might cause data loss or create a security risk.
To run the Program Compatibility troubleshooter
  1. ?id=microsoft.windows.resources.shellexecutetopiciconClick to open the Program Compatibility troubleshooter.
  2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
Tip
  • You can also open the Program Compatibility troubleshooter by right-clicking a program's icon or shortcut and then clicking Troubleshoot compatibility.
To change compatibility settings manually for a program, right-click the program icon, click Properties, and then click the Compatibility tab.
Setting
Description
Compatibility mode
Runs the program using settings from a previous version of Windows. Try this setting if you know the program is designed for (or worked in) a specific previous version of Windows.
Run in 256 colors
Uses a limited set of colors in the program. Some older programs are designed to use fewer colors.
Run in 640 × 480 screen resolution
Runs the program in a smaller-sized window. Try this setting if the graphical user interface appears jagged or is rendered improperly.
Disable visual themes
Disables themes on the program. Try this setting if you notice problems with the menus or buttons on the title bar of the program.
Disable desktop composition
Turns off transparency and other advanced display features. Choose this setting if window movement appears erratic or you notice other display problems.
Disable display scaling on high DPI settings
Turns off automatic resizing of programs if large-scale font size is in use. Try this setting if large-scale fonts are interfering with the appearance of the program. For more information, see Make the text on your screen larger or smaller.
Privilege level
Runs the program as an administrator. Some programs require administrator privileges to run properly. If you are not currently logged on as an administrator, this option is not available.
Change settings for all users
Lets you choose settings that will apply to all users on this computer.
Article ID: MSW700015
Jun 08, 2011 | Computers & Internet
Tip
Make Windows XP smooth as Windows 7 part-1
If Windows XP works smoothly on the latest equipment, it can be trolling on an older machine or with economic components. For example Netbooks or nettops are not really swift and have limited disk space. If you start to open multiple applications simultaneously, you will soon experience slowdowns.
You can customize Windows to your material by removing or disabling everything that is unnecessary. You'll save responsiveness. Here are some of the tasks that you need to work on, just go through it:
Limit the Visual Effects:
Many visual effects adorn the Windows interface. You can disable to improve responsiveness. Below is how to do the same:
Click the right mouse button on the My Computer icon located on the Desktop and select the Properties command.
Open the Advanced tab.
Click the Settings button under Performance.
Then select the option Adjust for best performance. All visual effects are disabled.
Note that you can manually activate an effect that is important to you by ticking the box. Then press OK twice.
Rediscovering the classic theme:
The interface of Windows XP with all its colors and visual effects is consuming system resources. You can not keep clean and perfectly functional and interface.
Click the right mouse button on an empty space of desktop and choose the Properties command.
Scroll down and select Theme Windows Classic.
Click OK.
The theme of Windows XP Lite is immediately applied.
on May 19, 2010 | Computers & Internet
Tip
How to improve Windows XP performance in 6 short steps?
Though the computers of today are strong enough to handle and run Windows XP, with all the visual enhancements enabled, some old computers, or systems with low amount of physical memory and/or a "weak" graphic cards could (and would) run more smoothly with those "cosmetic visual enhancements" disabled.
The default setting is to let Windows choose what's best for your computer, but in 90% of the time, "helping" it a little will surely improve your computer performance!
To disable those visual enhancements, all you have to do is follow the following 6 short steps:
  1. Right-click on My Computer and choose Properties.
  2. Go to Advanced tab.
  3. Click Settings, under Performance section.
  4. Choose Adjust for best performance.
  5. If you would like to keep the "Windows XP Style" (as oppose to "Windows Classic" = Windows 98/Windows 2000 style), you will need to re-tick the 2 last options (Use drop shadows for icon labels on the desktop and Use visual styles on Windows and buttons). This will keep the nice graphical interface and will preserve Windows XP "fancy look".
  6. Click OK on Performance Options window, then click OK once again, to close System Properties.
  • You can always turn the visual enhancements on by repeating steps 1-4 and choosing Let Windows choose what's best for my computer.
  • To make ALL visual enhancements on, choose Adjust for best appearance instead.
Note: Changes take effect immediately, no reboot required.
Another side-issue regarding visual styles is the wallpaper, or Desktop Background.
Having no background (a solid color. Select None in the background's settings under Desktop tab in Display Properties) will demand less resources from the computer and increase response time when showing the Desktop. On the other hand, having a large-size (both in scale and in file size) photo will need more resources (especially memory) to rescale and view/reload it, every time the Desktop is shown.
on Mar 06, 2010 | Computers & Internet
Does not work on windows 7
Right click on the EXE File and select properties. Goto Compatibility and run it in compatibility mode for Windows XP. Disable visual themes, disable desktop composition, and disable high DPI scaling. That should resolve your problem.
Jan 22, 2011 | Broderbund Generations Family Tree Plus...
IS NOT CAMPATIBLE WITH WIN 7
Run the Program Compatibility Wizard
  1. Open the Program Compatibility Wizard by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Programs, and then clicking Use an older program with this version of Windows.
  2. Follow the instructions in the wizard.
If you cannot install a program, insert the installation disc for the program and, using the wizard, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The wizard is not designed to work on programs that have an .msi file name extension.
To change compatibility settings manually for a program, right-click the icon for the program, click Properties, and then click the Compatibility tab.
Setting
Description
Compatibility mode
Run in 256 colors
Turns off automatic resizing of programs if large-scale font size is in use. Try this setting if large-scale fonts are interfering with the appearance of the program. For more information, see Make the text on your screen larger or smaller and Ways to improve display quality.
Privilege level
Show settings for all users
Dec 27, 2010 | Computers & Internet
Can not reopen Cal Creator 10 On my new windows 7 computel please help
Make older programs run in this version of Windows (from help section in Windows 7)
Warning
Tip
?id=microsoft.windows.resources.collapsearrow?id=microsoft.windows.resources.expandarrow To change compatibility settings manually
Setting
Description
Compatibility mode
Run in 256 colors
Privilege level
Dec 18, 2010 | Broderbund Calendar Creator Deluxe 10 Full...
Does sacred plus work on windows 7? If it does, then how do you fix it? PLEASE HELP!!
Open up compatibility mode and check to following: Visual themes disabled, desktop composition disabled, set to run as administrator, XP SP3 compatibility mode.
This makes both plus and Gold work on my Windows 7 machine
Jul 06, 2010 | Ascaron GmbH Sacred Plus for Windows
Soft ware for window 98.ihave windows visa
When an application fails to run, start the Program Compatibility Wizard by clicking on Start \ Control Panel and select 'Use an older program with this version of Windows' listed at the bottom of the side bar.
-Click Next to start the wizard.
-In the next screen, I like to choose the first option instead of hunting around for the program executable. If you do know where the executable resides, select the third option. -Click Next to continue.
-Once the list is displayed, scroll through and find the application you want to run in Compatibility mode. -Click Next to continue.
-Select the version of Windows, the application was originally written to run on. If you do not know, start out with Windows XP (SP2). One advantage of using the wizard is the test mode functionality shown later.
--The next screen list options if your program has problems handling the higher quality video of Vista. For now, click Next to continue. After the wizard completes and the test fails, you will have the option to return to this screen. Experiment with the settings by starting off with disabling visual themes and desktop composition, if you can't get things working.
The below table list definitions for each setting:
  • Run in 256 colors - This forces the entire screen to 256 colors while the application is running
  • Run in 640×480 screen resolution — Runs the program in a smaller-sized window. Try this setting if the graphical user interface appears jagged or is rendered improperly.
  • Disable visual themes - Disables themes on the program. Try this setting if you notice problems with the menus or buttons on the title bar of the program.
  • Disable desktop composition - Turns off transparency and other advanced display features. Choose this setting if window movement appears erratic or you notice other display problems.
  • Disable display scaling on high DPI settings - Turns off automatic resizing of programs if large-scale font size is in use. Try this setting if large-scale fonts are interfering with the appearance of the program.
-Next, if the application requires Administrative privileges, select this option. --Otherwise click Next.
--NOTE--: You will have the option to return to this setting if the program fails to run during the test.
-On the next screen, click Next to test the application. If successful select the first option and click Next to continue.
-If the application failed to run or has problems (such as video), select the second option to go back and make additional changes.
---After a successfull test, select either Yes or No to send information to Microsoft, then click Finish to save your settings.
To reset the compatibility settings back to the original settings, run the wizard again and in the 'Select a compatibility mode for the program', select the last option to 'not apply a compatibilty mode'.
-One big advantage to using the Program Compatibility Wizard, is that you can view which programs or applications are running in compatibility mode by running the wizard and checking the settings column.
-If running an older software application in compatability mode fails, check the software manufacturer site for information or updates to the software.
Oct 03, 2008 | Computers & Internet
Exe
Right click on its .exe file and goto compatability mode > select "Run in 640*480 Resolution" , "Disable visual themes ", "Disable desktop composition", "Disabe display scaling ..." and give it a try ..........this will resolve the issue if not you don't have the proper hardware requirement for the game.......also don't use internet while you play.....turn off the adsl.......
Sep 26, 2008 | ASUS P5PE-VM Motherboard
ASUS P5PE-VM Motherboard Logo
401 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
