Question about Canon CanoScan 8400F Flatbed Scanner
CanoScan8400 Suddenly Doesn't Work
For some reason, my 8400F doesn't turn on.  I've tried it in several different outlets.  Is there a fuse that could be blown?   Any other thoughts?
It has worked perfectly for some time.
  • 8 more comments
  • mo99 Oct 14, 2008
    I have the same problem. My CanoScan8400 no longer turns on.
  • tmarsden Oct 14, 2008
    I have the same problem. I took the unit to Best Buy GeekSquad and the technician determined that the AC power adapter is shot. I'm on the hunt to locate a new adapter and expect to not only find a supplier but also pay less than $20. Not bad compared to the price of a new scanner.
  • disanders Nov 24, 2008
    After not using my Canoscan for awhile it won't turn on now. I reinstalled it but still no results. I only had this one year...
  • dmcfad Dec 02, 2008
    Same problem. Canon replaced scanner twice under warranty, but same problem again. Now power adapter dead again. Something in the scanner must be killing the power supplies. Canon won't help now that warranty gone.
  • mistersquid Jan 18, 2009
    Dead in December 2008. No power up. In process of buying new power adapter.
  • RepeatGuest Feb 06, 2009
    January 2009, haven't used it in a couple of months, now it won't turn on. Funny, I was thinking it might the power adapter even though these don't often go bad. One possible cause is that I swapped out the surge protector recently. However the scanner and the surge protectors were switched off at the time all plugging/unplugging was done.
    January 2009, haven't used it in a couple of months, now it won't turn on. Funny, I was thinking it might be the power adapter even though they don't usually go bad. One possible cause is that I swapped out the surge protector recently. However the scanner and the surge protectors were turned off at the time all plugging/unplugging was done.
  • ajluk Mar 11, 2009
    Scanner has just failed to power up - am assuming it's the power supply (though am getting old one tested). Any of you managed to source a new supply? If so, where and how much?
  • Sinky1956 Apr 08, 2009
    Hi mistersquid
    I have the same problem and was in the process of looking on eBay for a new adapter / power cord. Can you post the model / make and perhaps the seller's name. It would help me to ensure I get the correct one. cheers deltic11
I had the same problem about a year ago. The solution was to replace the power cord AND don't leave it connected to the powers source when the scanner is not in use, or it will burn out again.
Posted on Mar 17, 2009
Need power cord
Posted on Jan 17, 2011
You can find a new power adaptor on eBay. Mine cost about $20 US.
To prevent future problems, I plugged my replacement adaptor in to a power strip that is normally powered off, which should extend the life of the shoddily-engineered CanonScan 8400F power adaptor.
There oughtta be a class action.
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
2002 Pontiac Grand Prix - I put the key in and turn to start, I hear a click, then it doesn't start - in fact the entire car suddenly goes dead and the key gets stuck in the ignition. I can press the...
The first thing I would do is clean your battery connections very good. you may have to remove the plastic covers off the cable ends to get them cleaned good. Also make sure you get the connection bolts tight.
Sep 04, 2011 | 2002 Pontiac Grand Prix
Dear Sirs, I have a Mac OS X Version 10.6.8. So far I was able to create my own films and burn them on a DVD-R. Suddenly this doesn't work anymore. When I want to burn a DVD, I get the DVD is thrown...
it could be several things
1. dvd drive may be going out & needs to be replaced
2. it could be that perticullar dvd was bad--try a different one--had this happen to me before
3. there are different types of dvd-----I've got dvd-r & dvd-rw & dvd DL
Aug 26, 2011 | Apple (M7164LL/B) DVD Drive
Curling Iron will not turn on.
Lots of interesting problems in the Shavers category :)
Make sure you plugged it in. (I know, seems like a no-brainer, but you'd be surprised how many times this is the cause of a problem!) If it is plugged in, and it still doesn't work, try plugging in a lamp or something else by which you can make sure the outlet is operable. If the outlet works, return your iron or buy a new one. If the outlet doesn't work, try using a different one. Otherwise, you're going to have to get into fuses/circuit breakers, ets, or call an electrician. Good luck!
Jun 23, 2011 | Health & Beauty
My Belkin F5D8236-4 v3 Router won't turn on. We had a storm last night and the power went out but the router won't turn on. I have tried to plug it into different outlets to see if that would work...
Try resetting the router. There should be a little hole somewhere on it with a button inside that you can press with a paperclip. Try holding that button down while you unplug then plug the router in while holding it (if possible). If that doesn't work, I'd suspect the storm might've damaged the router somehow. Was it plugged into a surge protector, and/or have you noticed any other issues with anything else that was turned on at the time?
Jun 16, 2011 | Belkin F5D8236-4 Router
I put my memory card into the Dynex reader and nothing is happening
Move the reader to a different USB port. If that doesn't work, the reader's probably given it up. I've seen several of this brand reader die an early death, for no apparent reason.
Jun 16, 2011 | Computers & Internet
THE T V WILL NOT POWER ON
plug the cord into the outlet. If the wall outlet doesn't work find a different one. If the tv doesn't turn on with the remote take the plastic off of the batteries in the remote. if this all doesn't work, then there's something wrong with the tv and you should return it and get a new one.
May 16, 2011 | Tatung LD30HL Television
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
CanoScan8400 Problem
its a build up of gas inside the system. look online for the cleaning procedure
Jul 03, 2008 | Canon CanoScan 8400F Film Scanner
Canon CanoScan 8400F Flatbed Scanner Logo
639 people viewed this question
old marine
old marine
