Question about Panasonic DMR-E55 DVD Recorder
Self check keeps repeating it self many times before it will come on
  • bsrowe Dec 04, 2008
    When you insert a dvd self check appears and continues sometime for hours
  • Vicki Smelt
    Vicki Smelt Dec 08, 2008
    Insert any disc CD/DVD and keeps going in to to self check for sometimes minutes and sometimes hours. Very annoying as the DVD recorder is connected with the sky and keeps flashing sky up for 1 second then off again.
Put in dvd starts off read then self check over and over again up to 1 to 2 days then press record then cuts out
Posted on Dec 03, 2008
    Sergeant:
    Champion:
  • 223 Answers
Please be a bit more specific if you can. In what way is it repeating itself? And once it comes on does it stay on? It could be a component faulty on the power supply side.
Posted on Sep 26, 2008
Where is the obd2 connector location on holden ra rodeo v6
Connect white (test lead) and black (ground lead) wires that are branched from harness approximately eight inches from ECM. After leads are grounded, the "Check Engine" light will flash the diagnostic trouble codes. The DTC's are indicated by the flashing CEL.
FLASH, FLASH, pause, FLASH, FLASH, FLASH = Code 23.
If only one diagnostic trouble code is stored, the DTC will repeat continuously until test leads are disconnected. If more than one diagnostic trouble code is stored, each DTC will repeat three times, starting with the lowest, then proceed to the next DTC. After all DTC's have been displayed, the pattern will repeat.I-MARK 84-85
Connect male and female test leads taped into wire harness near ECM. After leads are connected, the "Check Engine" lamp will flash the trouble codes. The DTC's are indicated by the flashing CEL.
86-87 Impulse located near the ECM connector, is used to actuate the Engine Control Module (ECM) trouble code memory within the module. Two terminals (A and C) of this connector are used to activate the diagnostic trouble code system in the ECM. With the ignition switch turned On, engine Off, connect a jumper wire between terminals A and C. The "Check Engine" lamp will begin by flashing a DTC 12. DTC 12 = flash, pause, flash, flash. There will be a longer pause and a code 12 will repeat two more times. This code indicates the self-diagnostic system is operating. The cycle will then repeat until the engine is started or the ignition is switched Off. In most cases, DTC's will be checked with the engine running since no DTC's other than DTC 12 or 51 will be present without the engine running. Remove jumper wire from ALDL connector before starting engine. Reconnect jumper wire after engine is running.
Throttle Body Fuel Injection
The ECM test connection is located under the center console.
A built-in, self diagnostic system will identify problems in the throttle body fuel injection system. When a problem is detected, the diagnostic system will illuminate the "Check Engine" light.
When the engine is started, the Check Engine light should turn off.. If the light remains lit, the self diagnostic has detected a problem. To determine where the problem exists, ground the "Test" terminal of the connector with the ignition On, engine Off and watch the check engine light. Each DTC will flash three times (lowest to highest).
Aug 21, 2014 | Holden Rodeo Cars & Trucks
Recorder won't boot up
Last time we had one of those doing that, it was the laser assembly that needed replacement. It's doing what is called POST. "Power On Self Test" and not able to get a "status" from the laser. It will keep trying indefinitely, repeating "Hello". Hello, is just it's way of saying, please wait while I check every little thing and confirm I am ready to operate safely and efficiently.
Nov 02, 2017 | LG DR787T DVD Recorder
Sony trinitron kv-36fs13 standy by blinks 5 time then stops buts keeps repeating steps
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. If you wish to get more details about blinking codes to Sony TVs, check this link.
Feb 19, 2013 | Televison & Video
I have a 1999 7.3 f350 and the 0603 code came up so I had the idm checked and it was fine. also replaced gaskets and inner and outer pig tails as well as fuel pump on rail under driver side and fuel...
DTC P0603 - Internal Control Module Keep Alive Memory (KAM) Error
The P0603 is usually a internal fault in the PCM. Here is the pin point test from the Ford manual.
MA1 CONTINUOUS DTC P0603
Note: This DTC may have set if the PCM or the battery(s) were disconnected.
Possible causes:
battery or PCM was disconnected
battery cables loose or poor connections
battery discharged
KAPWR circuit open
central junction box fuse #15 (5amp)
DTCs not cleared from a previous vehicle repair
PCM
Check and repair all other DTCs.
Key off.
Disconnect all diagnostic test equipment.
Disconnect the battery(s).
Wait 45 seconds.
Reconnect the battery(s).
Key on, engine running.
Wait 45 seconds.
Cycle key off and then on.
Clear DTCs.
Retrieve the Continuous DTCs.
Is DTC P0603 present?
Yes- GO to MA2.
MA2 CHECK THE KAPWR FUSE
Note: Refer to the wiring diagram at the beginning of this pinpoint test for fuse numbers.
Key off.
Measure the voltage between both sides of the KAPWR fuse and ground.
Is battery voltage present on both sides of the fuse?
Yes - GO to MA3.
No - REPAIR as necessary. RESTORE the vehicle. CLEAR the DTCs and REPEAT the self-test.
MA3 CHECK THE PCM KAPWR CIRCUIT FOR VOLTAGE
Key off.
Disconnect the PCM.
Measure the voltage between the PCM KAPWR circuit pin 55, harness side and ground.
Is the voltage greater than 10.5 volts?
Yes - RESTORE the vehicle. CLEAR the DTCs and REPEAT the self-test. If DTC P0603 is present again, INSTALL a new PCM. RESTORE the vehicle. CLEAR the DTCs and REPEAT the self-test.
No - REPAIR the open KAPWR circuit. RESTORE the vehicle. CLEAR the DTCs and REPEAT the self-test.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jan 04, 2012 | Computers & Internet
DVD stuck in player and cannot get it out. SELF CHECK keeps repeating but nothing else happens.
due to belt damage and gear lock. player will not open. just open the player chasis just manually rotate the gear open. check belt and gear maybe some are broken.
Jun 07, 2009 | Televison & Video
Reset service date on 2006 passat
press your mileage reset button then turn key on then off,then repeat,2nd time keep mileage reset button pressed(keep pressed all the time basically)while holding mileage reset left turn your didgital clock then your service light should be off! ive done it on my 05 plate passat.
Mar 11, 2009 | 2006 Volkswagen Passat
Monitor keeps saying self test everything working check plugs
The self test thinks nothing is connected to it
it might be the cable or the input circuit.
not an easy issue to verify if you only have one input.
most often its is the internal board with a failed input circuit.
you can only open the unit and test the vga cable continuity.
as most have a 1 year warranty you might want to check on yours.
Nov 13, 2007 | Acer AL1912 19" LCD Monitor
Panasonic DMR-E55 DVD Recorder Logo
180 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
