Question about Whirlpool GEW9250 Electric Dryer
Has power,no tumble
Dryer turns on, timer will count down. But no tumbling or heating. gives 3e code, already replaced control panel same thing. What now?
Try a belt
Posted on Sep 26, 2008
I have a White Knight tumble dryer with reverse action, model 0312 44A 15003. The timer does not count down. It heats up fine. The reverse action never happens now. Any idea what needs fixing?
You need to check your schematics on the electrical and find, then replace the sensor that controls the timer, then the reverse action. It may need removed then replaced to reset. Be very careful and aware of the eletricity going through the system.
Jun 12, 2017 | Dryers
The tumble dryer timer dial won't count down now the dryer won't start
Sounds like the timer is shot Stuart. An easy job to replace yourself as it is accessible if you take the top off the dryer after unplugging. Just take plenty of photos or notes of where the push on connectors go.Plenty of videos on how to do it on you tube-search "timer on tumble dryer". New replacements are ridiculously priced at £40 to over £100 but fortunately many people give up on repairing dryers due to cost of spares or call-out fees.For this reason there are plenty of people who make a good living on ebay stripping spares off such discarded dryers and you should get one for £20. Hope this helps .
Jul 06, 2016 | Dryers
E15 error code on hoover tumble dryer
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
Dryer will not stop running
Your machine may have a feature called wrinkle guard or wrinkle shield, which basically keeps tumbling the clothes without heat to prevent wrinkles from setting in. Turn that feature off and see if that does the trick.
May 15, 2010 | Frigidaire Electric Dryer
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Dryer turns on but won't heat up or tumble
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Nov 03, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Dryer runs but does not get hot
if timer runs thru cycles then it is the element sounds like timer
Oct 30, 2009 | Whirlpool LER8648P Electric Dryer
Why no heat
Absolutely. A bad timer will not initiate the element function once the load has started. there is a point on the timer board where, the timer sends a heat signal to the element and it also controls the shutdown signals as well. the high limit thermostat controls the actual temp once the timer initiates the heat signal. if the timer is bad or malfunctioning, the element will malfunctioning as well.
Replacing the timer will fix this issue.
May 18, 2009 | Whirlpool GEW9250 Electric Dryer
Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Jan 21, 2009 | Dryers
Whirlpool GEW9250 Electric Dryer Logo
90 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
