Os instalation will not load - Computers & Internet
  • Anish M.
    Anish M. May 11, 2010
    PLEASE GIVE INFO ABT U R DESKTOP
    WHICH OS
    & WHT KIND OF CD U HAVE
    President:
  • 2,351 Answers
Hi Dobssand, the most common reason for a CD-ROM (With a Windows CD in it) does not start to load is the motherboard's bios is not set correctly. While in the bios go to the title Boot & enter boot order. This is a common boot order for a PC.
1st boot device = [Floppy disk drive]
2nd boot device = [CD-ROM drive] (Model number of the CD-ROM drive).
3rd boot device = [Primary Hard Disk Drive] (Model number of drive).
Second most common reason is the data cable to the CD-ROM drive is loose or not fully connected either at the CD-ROM or at the motherboard. (Check it).
If you choose not to enter your bios, you can still get the CD-ROM drive to boot the Win CD in this fashion. Load the Win CD into the CD-ROM drive. Power off the system. Than power on the system & start to press the F8 key once every two seconds. Windows "Please select boot device:" window will open. Using your keyboards up & down arrow keys high-light the CD-ROM drive that has the win CD in it & press the enter key. Windows should start to load. If you receive an error message stating windows can not find your hard disk drive. Than you must enter your bios & go to the title Boot. Your hard disk drive is not listed in the boot order section. Worst case! Your hard disk drive may be faulty. Find the manufactures name printed on a large white sticker on once side of the HDD. Go to the manufactures web site & download their drive setup software so you can create a bootable floppy disk. This will allow you to check/test the HDD & format it for a windows installation.
Or is this not the issue you are having?
Mike
Posted on Sep 26, 2008
How can i download falsh player on to 2011 imac desk top threw Linux ubentu browser ?
Ok, there are a number of issues with you spelling so I am going to assume you meant the Ubuntu OS. If that is the case the Flash Player install is done by the following:
If you are using the more modern versions of Ubuntu, simply install the Adobe Flash application from Ubuntu Software Centre.
If you are using a version that does not support the Software Centre, try:
Go to the Adobe website.
  • Click on "Download the Latest Player," and choose ".deb for Ubuntu" from the drop down list.
  • Choose "Save File" from the pop up window.
  • Open a terminal window.
    The terminal window will be found under Applications -> Utilities.
  • Change to the directory where your downloaded file was saved.
    cd Download
  • Install the libcurl3 library: sudo apt-get install libcurl3
  • Install the Flash Player: sudo dpkg --install install_flash_player_<version>_linux.deb
    Replace <version> with the latest version number.
  • Restart Firefox.
  • Check that Flash Player was installed.
  • Jul 08, 2014 | Computers & Internet
    HP vp17 screen is turned blue How to get back the colours?
    I recommend you check the signal cable plug (from the monitor) is fully inserted into the PC.
    Jun 10, 2014 | Computers & Internet
    How to load 3 hole punch paper in a copier
    Like normal. Those three holes should not affect the print at all as all of the rollers are flat. I would not not stick it in a dot matrix printer though.
    Jun 05, 2014 | Computers & Internet
    Screeen is upside down
    If you have a Windows OS, press and hold the ALT and CTRL (control) keys and then press the Up arrow. (If that doesn't work, try holding the Alt and CTRL keys and pressing the left (or right) arrow key twice.) If that fails, right click on the desktop (Windows+D will minimize all programs), anywhere with no running programs or icons. Then select the Screen Resolution option. Look for the line Orientation; use the drop down menu to select the correct orientation. Click Apply and then confirm the setting change if a confirmation window pops up. (This works in Windows 7 and 8.) For older Windows versions on laptops, you may need to select Graphics Properties (or a similar line) and then repeat this. The Windows screen rotation option is dependent on your video card. With some models, you'll need to open the graphics card properties to undo the rotation. You should see a line for the graphics adapter when you right click on the Display.
    For Macintosh OS, make sure that the System Preferences is closed. Then open it by pressing Option/alt + CMD . Select the line Display. Find the button labeled Rotation: Standard then choose the correct screen orientation.
    I hope this helps.
    Jun 01, 2014 | Computers & Internet
    Error code 0151
    hard drive failure. replace with new drive and reinstall whatever os you choose. i recommend 240-480 gb ssd.
    Apr 12, 2014 | Dell Vostro 1015 Laptop Computer (Intel...
    Toshiba Satellite A665 S6067 laptop wont recognize my SeaGate FreeAgent Go 500 Gb. device
    I had a similar problem and I had to "Delete Volume" when in DIsk Management. I then had a choice to "Create Simple Volume" which I did, and then a wizard created the correct partitions and assigned a drive letter to my external drive. Everything was them OK.
    Mar 21, 2014 | Computers & Internet
    Don't start up
    check that all removable media is removed from computer, flash drives etc,if this message still appears the reinstall your os, there are several reasons for this error. You may have to replace your hard drive if that is the issue- you would know because after reinstall (if it makes it thru it) it will only crash again, this is much too big of a subject to sum it all up here and now, good luck... more questions just ask
    Mar 30, 2013 | Computers & Internet
    How to install Anti virus on my desktop
    Following the steps to install antivirus on you pc.
    Compare antivirus software. Look at the features and benefits of each. Read reviews from authoritative editors from magazines such as "PC World," "Smart Computing" and "PC Magazine." Editors who write for these magazines typically test antivirus software as an unbiased outsider and write about both the good and bad sides of antivirus software. For example, the editors at "PC World" recommended Avira AntiVir, Avast Antivirus and Panda Cloud Antivirus in an August 2009 article. Visit the websites of each antivirus program to view screen shots and descriptions of how the program works. Make a final decision about which antivirus program you want to install.
    Navigate to the website of the antivirus program you've chosen. Go to the "Downloads" section of the site if you're obtaining a free antivirus software. Click on the "Purchase" section or "Buy" button if you have chosen licensed software; pay for and complete the transaction. Click the "Download" button or link for the antivirus program. Save the file to your computer desktop or to a computer directory or folder which you can easily remember.
    Find the antivirus program file you downloaded on your computer. Double-click the ".exe" file (which is an executable file that will install the antivirus program). Once you double-click the ".exe" file, the installation process will automatically begin. Click "Continue" or "Next" on each screen to complete the installation process. Enter your name and contact details if registration is required. Follow any other on-screen prompts to complete the antivirus program installation. Restart your computer if necessary.
    Feb 18, 2011 | Computers & Internet
    Using bluetooth on Vista with Itunes
    Apple update to Itunes 9-there's a bluetooth link on it
    Sep 20, 2009 | Toshiba Tecra 8100 Notebook
    I can't get my computer to accept my user password to logon to my computer; password is correct and is being typed correctly. I get that wrong username or password message. In addition to this, my...
    Please download the ERD Winternal Image from http://www.mininova.org/tor/857048 and burn it in a CD.
    Thenboot your PC from the CD. Select your Windows Media Edition for whichyou have forgot password. Without asking for any password you will getinto Windows. Then goto control panel->User Accounts->Select theUsername[for which u want to change password]. Then use change passwordoption to change password. Then Reboot the PC and remove the CD. Nowyour windows password will be reset.
    Thanks.
    Mar 08, 2009 | Computers & Internet
    Computers & Internet Logo
    265 people viewed this question
    Brian Sullivan
    Brian Sullivan
    David Payne
    David Payne
