Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
Mixer won't start
Hi all,
Mixer worked fine last time I used it (a few months ago). Now it won't start (nothing - no activity at all. Took it apart and found nothing out of the ordinary. transmission works smooth when disconnected from motor. Removed, checked, cleaned and reinstalled brushes. Replaced power control module - nothing doing. My next step is replaing the motor, unless someone else has an idea. The info I've seen on the hall field sensor impies this is a speed control issue, and I have no power at all. When I took the motor apart I checked for continuity across and amongst the contacts on the rotor (where the brushes contact). I was thinking that there should be no continuity between adjacent contacts but there was (no resistance at all). That is what makes me think it's the motor (lightning strike while plugged in but not turned on ?). There is no smeall, no marks or anything indicating what could have happened. Any help would be appreciated.
Thanks in advance
Rich
  • 44 Answers
Your problem sounds like the thermister is burnt out.
Posted on Dec 10, 2008
No power on kitchenaid mixer
Apart from checking a fuse, there is little more you can do. Did you notice a loss of power or burning smell the last time you used this? What make and model you have may help others identify a known problem with your machine.
Kind Regards, Dan.
Sep 08, 2014 | KitchenAid Classic Stand Mixer
I have a Viking VSM700 mixer that worked one day and was put under the counter. Next time it was brought out, it did nothing. No smoke, no noice, nothing. Any ideas?
On mine, one of the two brushes was NOT advancing to hit the motor armature as it wore. Had no power. Had to take unit apart to get to motor. We spread the metal brush holder slightly with a screwdriver and allowed the brush to slide so it can make contact with the armature. Motor now works fine. Shame on the Viking Company for dropping the ball on this product!!!
Jan 17, 2014 | Viking VSM700 Stand Mixer
I took my kitchenAid stand mixer (md# KSM5PSAC) apart to replace the plastic gear inside of it. When I put it back together it would not start. I took it back apart took a good look at all the connections,...
You need to either re-time the speed control switch at the back or replace it. If it worked great before then it is just an adjustment to get it back to running correctly. YouTube viseo available for timing the switch
Aug 06, 2013 | KitchenAid K45SS Classic Stand Mixer
My KSM150PS stopped working!! HELP!!
Yikes!!!!
Can you tell us what you were making last time you used the machine? Do you do pizza and other doughs a lot. The KSM150 is a 325 watt mixer with lots of power so;
1 first lets go back to the outlet and try anything that can show fast results like a hair dryer to test the outlet.2 The cord from the mixer, do you unplug it by pulling on ti? Or do you use the plug itself when unplugging. Do you have and know how to use a volt meter. If yes to both
3 Remove the rear cover and you will see a black and copper plate with a whole bunch of connectors on it. the left two bottom black and white terminals are the power for the mixer, turn the mixer on and test the terminals to make sure the machine is getting power, if not replace the power cord. You will have to open the machine and take it apart somewhat to replace the cord.
4 it could be the speed control plate itself (Most likely) there are three screws on the plate in an upside down triangle, turn the one on the bottom left a little bit while the mixer is on if it is the adjusting screws it should start again with less than a half turn.
5 Look at all the terminals to the speed control switch and make sure that they are connected if any one of them has come off then the machine won't work.
There can be other problems but this fix is the most common. Let us know if this does not work and we can go into it a little more in depth.
If you leave the machine on for a minute or more does it start to smell (burnt smell or hot electric) If you have a warranty (still within the first year of purchase ) get in touch with Kitchenaid they will send a new mixer with out question. If you are out of warranty then we can fix it, one step at a time, or you could take it to an authorized service center, if you live close by to one. Let us know.
Jan 19, 2013 | KitchenAid KSM150PS Artisan Series Stand...
My mixer worked fine, I took it apart for a really good cleaning and now it won't work at all. Please show me how to take it apart & put it back together correctly.
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It covers your model. Pay attention to the Motor Brushes, making sure
they are maiking contact with the Motor after re-assembly.
Aug 15, 2011 | KitchenAid KSM5PS Heavy Duty Stand Mixer
The mixing part of mixer not working motor is fine
Hi. Since I can't tell how much you have taken apart, I'll start from the beginning.
Remove the silver band, remove the top cover. At the top front of the mixer locate the transmission housing. If it's plastic, inspect it carefully for cracks around the screws and the body of this housing. If you find cracks, you have found the cheap plastic part that kitchenaid still installs in new mixers, and the cause of your trouble. They know that it's substandard but don't care enough to place a recall notice on this part. It may not please you to know that their replacement part is METAL like the original part should have been. "For the way it's made"! Indeed!
If you intend to repair the mixer yourself, go to kitchenaid's website, enter your model # and locate the parts list for your mixer. Download the drawings, they will assist you with your project.
Be sure to tell kitchenaid what you think of their cheap plastic part.
If this solution has assisted you, please rate it. Good luck! ricardok45
Apr 12, 2009 | KitchenAid KP2671 Professional 6 Series...
Panasonic MX-216E - work when you shake it or tap some times..
I used to live in Mtn. View on Bryant St. next to the P.G.&E office, great town.
I have had appliances go as long as twenty years and never had the brushes go out, but it sounds kie that is your problem alright, this is very unusual I would contact Panasonic and see what they will do for you there is usually a one year parts warranty on small appliances, call them you have nothing to lose. I would call this a factory defect.
Feb 28, 2009 | Food Mixers
My mixer wont start
First of all plug another appliance into the receptacle to make sure you have power there. If you don't have power at that receptacle you have blown a fuse or tripped a circuit breaker. good luck
Jan 16, 2009 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
237 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
