Question about Car Audio & Video
Wiring diagram for f-150 with 6 disc cd changer
I have a 2000 ford f-150. I purchased a head unit and a cd changer that mounts in console to replace stock radio/cassett player. What do I need to install? Is the cable there already or do I have to purchase a cable? What is the part number? Can you provide a diagram? Thank you. R. Braziel at camarilloelectric@yahoo.com
SOURCE: Kenwood CD changer wiring diagram
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/#_
Posted on Jan 18, 2008
SOURCE: NEED WIRING COLOR CHART
http://www.the12volt.com/installbay/vehiclewiring/1/yeard/Ford.html
Here you go
Posted on May 31, 2008
SOURCE: Installing a cd changer into a 2002 Jaguar S-Type
SOUNDS LIKE YOU HAVE A VERY EARLY MODEL CD CHANGER ALPINE UNIT THE S TYPE
USED A AUDIOVOX CD CHANGER HOPE THIS IS USEFUL
Posted on Oct 19, 2008
alicantecoli
  • 22265 Answers
SOURCE: need a wiring diagram for
why not put a belson car radio that uses a sd chip card and a usb connection ,a 1gb sd card is about 30 cds so why mess about with the cd changer ,old technology ,would you put an 8track in it ?? or a mobile vinyl 45 record player
Posted on Jan 14, 2009
SOURCE: stock 1997 Ford Explorer 6 CD changer stopped playing CDs
We finally realized that all of the "advisers" on the internet want to charge for their advice, and their advice in this case is univerally that the unit should just be replaced. Ya think?! Could of figured that one out on our own.....what a joke...
Posted on Apr 01, 2009
Alpine CHM-S620 6 Disc CD Changer Components
sounds like the changer was plugged into the antenna jack of the radio. this means that you can run it through any radio simply by sending a signal to a preset station on the radio and listening to it through tuner. the control unit ran the changer itself. you may be able to obtain replacement cables from pacparts.com
Apr 01, 2010 | Alpine CHM-S630 6-Disc CD Changer
I want to install my sony cdx-757mx 10 disc cd player in my recently purcased 2000 expedition that has a factory non working 6cd player in the center counsul.Do I need a wiring harness to adapt the sony?If...
the best bet is sony to sony / ford to ford/ pioneer to pioneer/ you can go down to wally world and pickup a decent reciever for about $150.00 and you will save a lot of head aches tryin to adapt& cut and you will still not know why the factory cd changer quit working..
best to ya
Feb 23, 2010 | Sony CDX-757MX 10-Disc CD Changer
2000 jeep grand cherokee limited 10 disk cd changer says ''err''
The in-trunk units have a tendancy to go bad. you can take the cover plastic interior cover off to access the CD changer, un bolt the changer, and visualy inspect the two rollers for debris, or missing /broken gears that move the rollers to take the CD from the CD cartrage to the player. if that looks fine, chances are that the laser went bad (common in rear mount units) and you can order a new one from Jeep, or you can remove it and update the in-dash head to an aftermarket of your choice (& yes you steering wheel controls will still work). you could also fit a more modern MP3 unit where the Changer was.
Feb 20, 2010 | 2000 Jeep Grand Cherokee
I have a 6cd in dash changer in my 2006 F-150. I
Disconnect the battery and re-connect it and it will reset the cd player and it should acknowledge the cd and you should be able to eject it. Badly scratched cd's will mess up the player as will paper labels on c.d.'s. Good luck
Jun 02, 2017 | 2006 Ford F-150
Wiring diagram for jvc model no ks-fx460r
http://books.jvc.com/booklist.asp?Model=+ks-fx460r this should take you to the down loadable manual for that head unit.
Jan 12, 2010 | Car Audio & Video
CD magazine trapped in Ford CD changer, no power to release
there is a way to get it working with the ford radio as long as the ford radio is cd changer compatible. You can purchase an adaptor from a dealer of autoleads. They also have a website. http://www.autoleads.co.uk/ were you can find out if its compatible and what lead you need. As far as i can remember with the jvc changers there is a seperate lead for power for a changer which you have to earth to the body of the car aswell have you got this
May 19, 2009 | Car Audio & Video
Nakamichi MB-70 CD player - cannot get cd to eject
Having just removed three discs from an identical unit which also jammed, I will say how easy that was. I do not know if the unit will now function when reinstalled in the vehicle.
Remove the unit from its mounts, remove the outer "frame" (if fitted), remove the two #2 phillips pan head screws from the sides holding the face to the chassis, remove the four #0 phillips screws (black, flat head) from the top and bottom of the face plate.
Slide the face plate off and carefully handle it while tethered by its ribbon wire.
Turing the unit upside down, peer into the opening and observe the disc, gently press the carriage away from the top of the unit (now the bottom, as it is inverted) and allow the disc to be freed, simply pull the disc out.
If there are multiple discs stuck inside, oberve the large metal gear just inside, carefully rotate the gear to actuate the loading mechanism as needed to release addtional discs.
Feb 23, 2009 | Nakamichi MB-70 6-disc In-dash Musicbank...
I have a kenwwod ddx 6027 double din head unit in my car, what cd interchangers will work with my head unit?
Any kenwood changer will work. That head unit also supports DUAL changers
Any FM Modulated changer wil also work.
Changer Control Features
  • Dual Disc Changer Control Capability (CH1/CH2 & AUX)
  • DNPS (Disc Name Presets) with Compatible CD Changers
  • DNPP (Disc Name Preset Play) by Remote
  • CD Text Ready with Compatible CD Changers
  • Direct Access with Remote
  • Random/Repeat/Scan Play (Disc/Track)
Jan 09, 2009 | Car Audio & Video
6 cd changer
try to reset the cars computer. i had the same problem and it fixed it. all you need to do is unplug the battery for about 10 minutes and it may work. Good luck!
Oct 26, 2007 | Car Audio & Video
Car Audio & Video Logo
1,036 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
