Question about Grundig S350 AM/FM/SW Radio
Odd odor The radio had been playing and then suddenly stopped.I noticed that the wrong power connector had been used . I then tried to use battery power and still - nothing but a strange odor - Is the radio shot or can it be saved
  • carlos Oct 15, 2008
    same problem. Anyone could have ventured that the smell indicated something had crisped. Need info on disassembly, schemqtic.
    Brigadier General:
  • 5,158 Answers
Yes..... that odor you smell was a component burning out on the circuit board. if you were lucking it only burned out one thing. fixable....if you have the time. actually anything is fixable it usually boils down to the cost of fixing it vs replacing the item.
Robert
Posted on Sep 26, 2008
My radio in my 1995 lincoln towncar comes on but no sound comes out of it, please tell me how to fix this what's wrong
Your 1995 Town Car has a separate power amp, located in the trunk behind the rear seat back on the passenger side. It has a fuse in it. Replace that.
Jul 19, 2014 | 1995 Lincoln Town Car
Cd player does not work when engine started
There are possibly 3 wires that can do this if not connected properly. One (probably red) should go to the battery. (memory, settings, and clock) . The second one should come from the fusebox( usually yellow). This should be connected to acc to come on with the keyswitch and power it up. IF this is in the wrong connection, your problem would exist. The third one(only on some units) usually an odd color or striped, should come from a pin on the head light switch to dim the radio lights, when you turn on the car lights, so it won't be so bright in the dark as it is in the day. I would double check all of these, especially number 2 on the fusebox. Try different positions on the fusebox until you find one that works correctly.
Mar 31, 2013 | Music
My son was playing radio , now my keys are stuck in the ignition and all the power system is shut off. i started the car by jump start but all the power system is not working and the keys are still stuck...
When the PASS-Key® III system senses that someone is using the wrong key, it shuts down the vehicle's starter and fuel systems.
I suggest check in this link the 2007 SAAB 9-7X - Owners Manual, section THEFT and PASSLOCK SYSTEMS (page 90 and next).
Keep us updated.
Oct 14, 2010 | 2006 Saab 9-7X
Pioneer xm radio suddenly stopped playing through my car radio. Got xm to restart signal back to device but that changed nothing. Sometimes when I wave my hand near to the xm device the car radio receives...
I have same problem and sure connect did not help.
The unit works fine otherwise except will not send a signal to my car radio.
I will try removing the battery today & if this does not work I will do t paper clip reset in the battery compartment.
Sep 15, 2009 | Pioneer AirWave XM2Go Satellite Radio...
D300, SB-800 fires but no exposure.
Thats is odd.
When you hook everything up, do you turn on the flash last?
It sounds like the battery pack is giving the flash a different voltage then it should have causing incorrect readings and exposures.
I would send the pack back to Quantum(located in Ronkonkoma, NY) and have them check it.
Jul 13, 2009 | Nikon Speedlight SB-800 TTL Flash
Lost all electrical power while driving?
Sounds like a poor connection from either the positive or ground from the battery. Check connections at the battery, follow the cables to see if any other connections are loose.
Jun 24, 2009 | 1999 Ford Expedition
2003 ford escape, fuse keeps blowing for door locks, radio and dome light. y
check for a shorted to ground positive wire repair as nesseacry
Jun 01, 2009 | 2003 Ford Escape
Kenwood th - 79E playing up
Charger should be able to power the radio at 'EL' level, if NOTHNG happens, I'd say charger is on the blink.
Mar 05, 2009 | Kenwood ProTalk XLS TK-3131 (15 Channels)...
94 Dodge Spirit electrical problems
Car wont start when i turn they key. The battery is fine. Its a connectivity problem between the ignition and the starter. How do I go about fixing this?
Jul 12, 2008 | 1994 Dodge Spirit
Grundig S350 AM/FM/SW Radio Logo
98 people viewed this question
Top Grundig Audio Players & Recorders Experts
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
