Question about Philips Televison & Video
THE DISC TRAY WILL NOT OPEN. THE LED SAYS "BLOCKED" THE TRAY IS EMPTY.HAVE TRIED THE BUTTON ON THE UNIT AND REMOTE.
  • Anonymous Dec 27, 2008
    The Disk Tray will not open even when there is no disc inside - message reads BLOCKED. This seems to be an intermittent problem.
    Sergeant:
    Champion:
  • 223 Answers
It sounds like some kind of child safety feature has been activated. If you have the instruction manual check how to turn this feature off, usually achieved by holding down some buttons for about 5 seconds.
Posted on Sep 26, 2008
DVD tray will not open on my Toshiba DVR620KU
Googled this for two days with no success! Finally, out of despiration I took the screwdriver to the top cover. (four screws in the back, and two screws on each side) Lifted up the rear section of the cover which the released the front for removal. The input pc board is right on top of the dvd tray so little could be seen, so I removed the screws and clips holding the pc board. Make sure that you you disconnect the power before doing this however. Once you have removed the three screws, (two of which have attached grounding clips) you will need to disconnect the HDMI cable which plugs into the back of the board if you had not already done so. Now carefully plug the unit back into ac power, and while holding the board in your hand careful not to allow it to touch anything,press the open button on the front of the unit, and as you move the board slightly while pressing the button, the tray mechanism will start to try to release. Press the button several times till the tray opens completely and stops. Now comes the tricky part: Unplug the AC power plug while the tray remains open. (Otherwise the tray may close again and you'll have to go through the wiggle routine again to get it to open) Once it is open, remove the DVD Disk if there is one in there. OK, so now if you have followed these instructions so far the tray is open and empty, and there is no power to the unit, you can begin reassembly. Put the three screws and two clips back into the PC board loosely at first till you have all three started, then proceed to tighten each one. Replug the cable into the back of the PC board and then replace the top cover and the screws following the same procedure. Plug the unit back into the AC receptacle, and turn the unit on, then press the open/close button, and the tray should open and close as normal. I think what caused the problem to begin with is that I had left a DVD disc in the player for an extended period of time in the start play mode, and it either jumbled the programming or damaged the disc. I have not tried to put the original disk back in the unit to find out! I want to use it for awhile first!
Jul 10, 2012 | Toshiba DVR620 DVD Recorder/VCR
Locked dvd tray.
have you tried to unplug the unit from the mains power wait around a minute and power back on if not press the setup button on the remote and reset to factory defaults.
Thanks J
Feb 16, 2008 | Televison & Video
Tip
INITIALIZE THE DVD PLAYER -FIRMWARE UPDATE
FIRMWARE UPDATE
1. Turn the power on and remove the disc on the tray.
2. To put the DVD player into version up mode, press [9], [8], [7], [6], and [SEARCH MODE] buttons on the remote control unit in that order. The tray will open automatically.
The DVD player can also enter the version up mode with the tray open.
3. Load the disc for version up.
4. The DVD player enters the F/W version up mode automatically. If you enter the F/W for different models, "Disc Error" will appear on the screen, then the tray will open automatically.
5. After programming is finished, the tray opens automatically.
At this time, no button is available.
6. Remove the disc on the tray.
How to Eject Manually
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
on Jan 19, 2016 | Denon DVD-1740 DVD Player
Philips DVP5140/37 disc tray won't open. Hello! I have tried unplugging from the power source and waiting 10 seconds as their website says to do. I hold down the stop button on the remote 5 seconds...
What could be done is to leave the set Switched ON for many hours even overnight and see how it can change if there is a possible fault on the motherboard, a change of value in electrolytic capacitors.
If there is no result then there is fault in the motherboard and you need to take consensus for an estimate.
Nov 05, 2011 | Philips DVP5140/37 DVD Player
Hi - the CD tray cannot open. It is empty - no CDs in there. I hear a buzz, but an "error" message comes on. I tried pushing on the tray while turning on; I unplgged the CD player, I put it on...
The loading tray belt has more than likely stretched or snapped.
The buzzing you hear will be the motor spinning freely.
The 'ERROR' message will show up because the tray isn't opening
and activating the 'tray open' switch, therefore the 'tray closed' switch
is permanently activated after the 'open/close button is pressed.
Aug 20, 2011 | Marantz CC-4300 5-Disc CD Changer
3380 recorder cannot open tray says blocked
I had one just the same it appears to happen when the unit has been left on standby for a long while, on old players, and if you close the tray by pushing on the front instead of using the open button.
However, you can normally get the disc out if you press the eject key about 5- 6 times in quick succession. This is only a quick fix and the route of the problem lies inside. I think your player has a micro-switch that is on its way out. If you open the unit you can short this switch prevent the blocked message but this is a bit drastic.
Time for a service me thinks.
Aug 08, 2009 | Philips DVDR3380/05 DVD Recorder
Pioneer BDP-f1FD Disc Tray Won't open
I fixed this on my unit from a tip on AVS Forum
Unit has "Power on" msg, follow these steps:
1) Hit power button for 5 -10 sec unitl unit shuts off
2) Press open / close button unit or remote first (do not hit power button first)
3) On the third try, the disc tray opened
I had James Bond Goldfinger in the player ( not sure if this had anything to do with it), I put another Blu Ray in and it loaded fine and is playing fine, hope this works for you
Dave
AVS link below
http://www.avsforum.com/avs-vb/showthread.php?t=1054927&page=413
Apr 20, 2009 | Pioneer BDP-51FD Blu-Ray Player
Need region free codes
You can try this one it worked on my home threater system
  • Power On with empty tray (No Disc will be displayed in the DVD control panel)
  • Press the Enter button on your remote control
  • Press the buttons 8, 4, 2, 6, 9 and Enter button on your remote control
  • Tray will Open automatically
  • Close the tray on the DVD player
  • After 15 seconds have elapsed, power Off your player (switch the unit to stand-by mode) and then power On your player
  • Finished and ready to play all regions
hope this helps
Little Dish Fitter
Apr 20, 2009 | Samsung HT-TX72 Theater System
Philips DVDR3440H Our DVD recorder is playing up, insofar as the disc tray won't open. Each time I press the OPEN/CLOSE button on the front of the machine, the LED says OPEN and then BLOCKED. This then...
Disc loading mechanism fault. Might be of a broken gear wheel or a drive belt. In rare cases, the mechanism replacement should be done. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 08, 2017 | Philips Televison & Video
Televison & Video Logo
170 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
