Question about Canon ZR10 Mini DV Digital Camcorder
Eats tapes!! Every time I put a tape in, I get an error and must eject the tape. When I do, the tape has not rewound and I must do it manually. This happens every time I insert a tape. I cannot use the camera! Any help??
  • Canon Master
  • 2,794 Answers
Try using a DV tape cleaner to clean the tape heads first and see if that makes a difference.
Posted on Sep 26, 2008
Eject lto5
in the manual should be something like this:
Manually Removing a Tape Cartridge
If problem-determination procedures identify the tape drive as the source of the problem and you are unable to eject the tape cartridge using the eject button, reset the drive to recover the cartridge:
Press and hold the eject button for 10 seconds, then release.
The status light turns amber and the drive starts through its hardware test process.
When the hardware test completes, the status light turns green.
If a cartridge is in the drive the status light flashes green until the cartridge is rewound.
The status light turns solid green when the rewind is complete and the tape drive is ready.
Although it is from an older LTO version, it must work on the newer versions too.
I also did remove tapes, if nothing worked, but it is to much to tell and show here.
NOTE: Allow at least 10 minutes for the rewind process to complete.
Jun 09, 2014 | Computers & Internet
Stuck tape -- Zenith model VR4176
Remove the top cover to see the tape and get at it. Remove it there using plastic tools, not metal.
Dec 15, 2013 | Zenith Televison & Video
When cassette is ejected the tape loop is not rewound into the cassette. The display shows "ERROR 2"
The reel motor, idler or wheel is not winding the tape back onto the spool.
What is it? Make. model etc and I will see if I can help.
Nov 03, 2010 | Televison & Video
I have a Sony Handycam CCD-TR61. It has worked fine until today. It will not accept a tape. If I close the door without a tape it closes and completely shuts like it is supposed to. But if I put in a tape...
Many times it's a belt slipping. Since the tape isn't pulled into position, it's rewound and the tape ejected. A damaged or mal-adjusted switch could cause this too. The most you can do is blow it out with compressed air to see if that helps. I doubt there are many thing the end user could do.
Oct 29, 2017 | Sony Handycam CCD-TR618E Camcorder
Sony DCR-PC100 does not eject (well not really!)
Don't think this is a complete solution, but it might help. Try checking out the buttons on the camera. I've got one of those same cameras but my problem is the ribbon cable in the cassette carrier broke and I'm on the hunt for a new one, and a service manual. By the way, how about emailing a copy of the service manual to me at ljmagnuson@aol.com. Thanks. I might be able to help further with a copy of that.
Dec 24, 2008 | Sony Handycam DCR-PC100 Mini DV Digital...
Tape end camcorder
Have you tried different VHS tapes? If your VHS tape is too far rewound or at the very end your camcorder will display this problem. In a different VHS machine make sur the tape is rewound and then play the tape about a minute and then try it in the VCR.
If this doesn't work then there is a problem with the tape end sensors in your VCR.
Oct 04, 2008 | Video Cameras
Canon XM2 Chewing tapes
This seams to be the problem, all the time, plus the sound goes off on most of theses camcorders, and the only way they will work is with an boom, mic.
Could I use an tape clearer when it says eject?
Aug 02, 2008 | Canon DM-XM2 Mini DV Digital Camcorder
Cassette
Most VCR's will auto-rewind the tape when it gets to the end of a tape. Most will leave the tape in the unit assuming you may wish to view it again once rewound. Does the tape eject properly when you press the eject button? What does the manula say about the eject function?
- Jim
Jan 23, 2008 | Philips VR550 VHS VCR
Deck will not accept DV tape
most likely problem is a defective cassette housing. I've replaced about a dozen of these in AG-DV2500s.
Jan 12, 2008 | Panasonic AG-DV2500 DV/Mini DV VCR
Canon ZR10 Mini DV Digital Camcorder Logo
333 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
