Question about Husqvarna Chain Saw 20" Bar
Throttle cable On a number 40 Husqvarna Chain Saw I need to replace the throttle cable. How do I access the throttle cable on the engine end?
  • Anonymous Mar 14, 2014
    how to replace throttle cable
    cable
  • 45 Answers
This advice is not model specific, but normally you would remove the air filter and access it that way.
Usually the actual fitting of the cable to the carburettor is pretty fiddly; sometimes it is easier to remove the carb, to do it.
Posted on Sep 28, 2008
How to replace a missing throttle push rod 141 husky???
It is very simple to re fit, you only need to lift the top cover off, the hooked end of the rod just engages into the hole in the throttle spindle, the other end with the plasric sleeve just sits into the groove in the tank unit, and is held down by the top cover, the part number of the rod is 530029869 the plastic sleeve is part number 530029863
Jul 10, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Hi, I am trying to purchase the air filter element for my Husqvarna 40 chainsaw. It appears to be just a foam insert profile but it has disintegrated. Cannot find replacement part.
This filter was only used on the early 40 ( 1985/6 ) it was part no. 506014801, there was a retro fit kit so as to fit the pent nylon filter from the later machine, it consisted of the carb plate, the carb back plate and the filter, the throttle cable outer was secured in the carb back plate, and not in the carb plate as on yours, all of these parts are still available, let me know if you need part no.s to convert it, try the web for the original foam filter.
Jan 18, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
No problem; using a borrowed Husqvarna 44-don't know fuel mixtures (if any). The chamber for "oil"-is that engine oil (if so, what do you recommend) or chain saw oil (if not, is there another...
The mix fuel mix is 40:1. Use Husqvarna 2 stroke oil not the cheap stuff on sale at car service stations. The chamber for oil is for chain oil which can be bought at most places that sell or hire machinery like chainsaws, lawnmowers etc.
Nov 14, 2010 | Husqvarna 44" Chainsaw Bar Fits Jonsered...
I have an old McCullough chain saw 12 or 14 inch chain length. What is the oil to gas ratio I need to use? 50:1? 40:1? What do you recommend? I can't see any serial number or identifying numbers so the...
Run 40:1 using fresh fuel and a modern synthetic saw oil--mix it in it's own can and be sure to shake the can thoroughly each time just before refilling the tank. Don't mix up more than a gallon unless your business is sawing. You may need to deal with a plugged fuel filter if it won't start. The oiler button was intended to supplement the pumped bar oil when cutting thick/difficult wood. Normally, it is not needed. To start, set the choke full on until you hear a pop, then back the choke off about half way before the next pull (don't forget to set the fast idle button near the throttle--squeeze the throttle, push the button and hold while releasing the throttle). As soon as you squeeze the throttle again, that will release the fast idle, so make sure the engine is warmed up and the choke off before hitting the throttle. This engine will drive a 16" bar and chain, so upgrade when the original parts wear out. Hope some of this helps!
Oct 19, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
142 chain saw. Starts but will not pick up when
Check the fuel lines for hardness, cracking, splitting, or end rot. Check the muffler for plugging. Check the carburetor fasteners for tightness. Are you using fresh fuel mix? If the carburetor jets have been adjusted, try turning both CW to stops (lightly) then back out each CCW 1-1/2 turns. Engine should start and run--allow to warm up. Pull the throttle full on, and adjust H needle CW until the engine starts to speed up, but still 4-strokes. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Let idle and adjust L CW for fairly smooth running, but still allows the engine to 'follow the throttle'. Hope this helps!
May 13, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Cutting a log with 455 rancher chain locked up took cover off replaced chain ,chain spins with cover off put cover on chain is locked up again husqvarna
It sounds like the chain is too tight. Loosen up the tension on the chain by turning the tensioning screw located on the end of the saw where the bar goes out.
Feb 26, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
353 husqvarna chain saw won't start.
did you try adjusting the throttle cable? does it start at all then die ?
Feb 27, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Chain Saw 20" Bar Logo
412 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
